Question about Coleman Air Tools & Compressors
Manual for coleman air compressor inflationmate compressor will not fill with air
5 Suggested Answers
  • 104 Answers
SOURCE: coleman powermate inflationmate pump
The ring is gone on compressor. You can buy replacement pistons and rings from colemen. Comes with instructions.Good luck
Posted on Oct 26, 2008
SOURCE: Need a manual for a Coleman Powermate air compressor Model #VP0200608 Elec.
I'm looking for a owners manual for a colman powermate air compeser modle cl0502710
Posted on May 04, 2009
  • 98 Answers
SOURCE: I turn on my Coleman
needs valves rebuilt in the head of the compressor
Posted on Jul 21, 2009
protek480
  • 1723 Answers
SOURCE: Coleman Powermate Inflationmate portable 4 gallon
Use a 15 amp 'time delay fuse'. Any time you start a motor, the inrush current will blow a regular fuse. Motors pull high current to start then drop to normal after 1 or two seconds. The time delay will fix it up!
Posted on Sep 20, 2009
How to change oil in sandborn compressor?
Coleman/Sanborn Compressor Owners Manuals - Air ...
www.aircompressorpartsonline.com/coleman-powermate-and-sanborn-ai...
Coleman/Sanborn Compressor Owners Manuals. Download to your computer and keep it handy. - Air compressor parts for most makes and models of air ...
Sep 12, 2015 | Air Tools & Compressors
Coleman Powermate VP201 will not go above 40 lbs.
Hi mjschulte815
Here are a few things to check, you may have already checked some of these.
Electricity...Compressors will run best with full 115Vot 15AMP/Or 220V electrical supply from a circuit, over the shortest electrical cord as possible.
Air Leaks..Place your ear close to the compressor and listen for air leaking, if you hear air that is not normal and means you have to locate and repair whatever it is that is leaking.
Check the air unloader valve... The air unloader valve will blown out air when you turned off the compressor, that is normal.
But it should not have air leaking out of it all of the time. If so then it is faulty and in need of repair/replacement.
Valves...If either the intake or exaust valves fail, breaks, or fails to seat, then your compressor will run 24 hours a day and never build up to the correct pressure for shut-off.
Gaskets...Check to see if your gaskets have failed.
You could have a gasket failure between the pistons and you will never know it because it shows no external air leak.
If this situation happens then the air will only cycle between cylinders and never build up the correct air pressure.
One way to check the gasket is remove the air filter, then put your hand over the intake.
Please take time to rate me
Bud
If correct then it will **** you hand against the intake.
If the valve or valves have failed then you will feel the air sucking in and blowing out.
Piston Rings and Cylinder...The piston rings could be stuck,broken, or worn and not allowing the correct pressure to build up in your tank.
A worn cylinder will also contribute to the problem of pressure build-up.
Pressure Switch...Check for air leaks at the pressure switch, it has a rubber diaphram that can fail and leak air out of the system.
Bud
Oct 17, 2012 | Coleman Model Vp0200406 Powermate...
I want a operators manual for a coleman powermate air compressor 20 gal tank
You should be able to download a manual from this site:
http://www.powermate.com/productmanuals.php?cat_id=1
The VLF1582019 is a 20 gallon model but you should confirm if this is the model number of your unit.
May 23, 2011 | Coleman Powermate 02 - Gallon Air...
I have a 5 HP Coleman air compressor. I was using it to provide air to my plasma cutter which requires 60 psi to operate. Basically, air compressor's motor keeps running, but it's stopped creating air...
You did not list model number, however if you have oilless type check the cylinder/piston by manually turning crank until piston is at top and examine cylinder for wear or scratches. If worn replace cylinder kit for full pressure. If ok check reed valves /valve plate for wear or broken reeds. If oil bath type, problem is usually air leak or reed valves / valve plate. As a general rule, you can keep track of wear by noting how many minutes it takes to fill the tank to cut-out. As the compressor wears it will take increasingly longer to fill. When new, and depending on tank size/ hp, most compessors fill within 2 ~ 5 min. Good luck
Sep 24, 2010 | Coleman Air Tools & Compressors
Manual for coleman vp201 air compressor
THE PSI RATING IS 70-100PSI. I WASN'T ABLE TO FIND THE SCFM AT THEIR WEBSITE. NO MANUALS AVAILABLE AS OF YET.
Jan 11, 2010 | Coleman 10' X 10' Sundome Tent 9160K101
Coleman Powermate Inflationmate portable 4 gallon compressor. Model VP0200406. See image at http://www.yotatech.com/f5/how-fix-compressor-111315/ . Coleman lable on back says 120 v, 15 amp, single phase,...
Sep 20, 2009 | Air Tools & Compressors
Apr 18, 2009 | Air Tools & Compressors
Black Max air compressor (old coleman model)
Needs 30W Non-detergent oil, and if there is a sightglass, fill to half-way up that glass. Otherwise, try mastertool repair or need a manual websites.
Dec 22, 2008 | Air Tools & Compressors
Coleman powermate inflationmate pump
Sep 29, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
157 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
