Question about Fun Rise Tonka Titan Mighty Motorized Fire Rescue Truck
The boom ladder will not raise / lower. I can hear the motor running and a 'clicking 'in gear box assembly. Also the swivel doesn't move all the time ( also Clicking sound).I cleaned the inside of the swivel base and it helped but not perfect. Is there a child safe lubricant I can use.
My Sole f83 will not start. initially Fans run, can raise/lower. will act noemal until motor should run/doesn't. then raise/lower function stops. If I try to use speed buttons LS light shows. moto
LUBE or wax the deck belt, this happen because you do not have schedule maintenance according with the owner manual. The machine shut down for autoprotection in electronic system Do it NOW.
2) LUBe the rollers bearint too with WD-40 only for rollers
3) Test the drive belt motor, for worn or cracking belt, replace or adjust it
4) Test the input voltage motor, if there are the motor need repair, see my personal TIPS for troubelshooting help.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 15, 2012 | NRS Sole F83 Treadmill
My rain train has worked great for years. Now it clicks when it get in a bind and doesn't move. Like a tooth is missing on one of the gears. Haven't taken is completely apart yet. Just learned
Individual gears are not available, you Will need to replace the entire motor section.
You can purchase the part from Nelson directly.
http://www.lrnelson.com/replacement-parts/
Current price for the #77376 Plastic Motor Assembly is $21.57 + shipping.
(I just replaced the motor assy. on the one I use for my front yard - figured 15 years is enough. Works like new again).
Jul 06, 2012 | Nelson Sprinkler: Traveling Tractor
Blade won't rise
it lowers easy because of the weight of the motor. What I would try and do is unplug tool first and lay on its backside and try and blow all the dirt from the gears/slide assembly. Look for a broken part where the shaft goes thru and if none use a DRY LUBE spray and also check for proper meshing of the gears. After lubrucating while saw is laying on its back look at the gear for any possible binding. Set upright and try again.
Feb 19, 2012 | Bosch 4100 09 10" Worksite Table Saw...
The blade is hard to raise and lower
Check the threaded rods that turn to move the motor assembly up and down. These rods are sometimes oiled or greased and this just attracts saw dust and eventually binds up the system. Clean as best you can and the threads they turn in to raise the blade. Also check the tilt rods.
Another thing to check is the joints everything pivots on. Occasionally a small peice of wood can get in just the right (or wrong) place and the motor assembly won't move because it's blocking the pivot points.
Jan 06, 2012 | Ridgid Heavy Duty 10" Portable Table Saw...
Treadmill only hums when turned on, tread does not work
Hello, it seem there could be something jamming the tread mill belt or the transmission gears coult be broken. There is a very good possiblity that the electric motor has goine south, it doesn't work, or seeze up might have to be replaced.
GB...stewbison
Oct 19, 2011 | Cars & Trucks
Raising and lowering the head lights for 89
check power to assembly- see if motor runs--if it does, gear must be rebuilt. parts thru Rodney **** follow instructions
Apr 24, 2010 | 1989 Chevrolet Corvette
How do you take off the sunroof of a 1986 944 porsche turbo?
Turn ignition on, make the sunroof go up and all the way down, turn off ignition and press the sunroof button to go down. Then unclip the 2 front hooks and push up.
Jul 07, 2009 | 1987 Porsche 944
Third row seat in ford explorer stuck in down
my third seat is stuck in the down position . press switch to raise i hear the motor but nothing happens. 2006 ford explorer
Apr 27, 2009 | 2003 Volvo XC90
Driver side seat
the motor or gear has went bad...the only fix is to replace the seat track assembly...the motors are not available from chrysler
Nov 30, 2008 | 2000 Jeep Grand Cherokee
1989 ford Van passenger side power window will not raise or lower. Glass is intact, in bottom support arm, and in tracts. Motor makes sound like it is raising or lowering window but window does not move.
The problem is the power motor gear that raises and lowers the window is worn out. The motor runs, but the gear cannot engage with the gear on the window regulator.
Jul 02, 2008 | 1989 Ford F 250
Fun Rise Tonka Titan Mighty Motorized Fire Rescue Truck Logo
44 people viewed this question
Top Fun Rise Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Fun Rise Toy Expert? Answer questions, earn points and help others
