Question about Samsung LA26A450 26 in. LCD TV
Can't turn it on - the power lught is flashing
  • 53 Answers
It is possible that the tv is in its power management system because it was over heated. Leave it alone for a couple hours and if it still doesn't turn on, try unplugging and plugging it back in.
Posted on May 24, 2011
Magic chef freezer model HMCF7W2 stopped working. Red power light on, freen lught off!???
I think if it is full of food I would call for service instead of using a website that may be able to help or not.
May 05, 2017 | Magic Chef Freezers
I am not sure how it work, and the orange lught indicating the hot water is constantly on wuth no sound indicating the water is being boil! is there a problem with that.
The light is either a standbye light, or liklly a fault, problem light, Turn off power at the unit, wait five minutes, and watch what the light does. It will blink, or change color, and the manual will tell you what the code means. It may be listed right on the unit, The light is a fault light, or a indicater light. Find out what it means.
Jul 18, 2015 | Heating & Cooling
Dash lights not working 2001 gmc sonoma
Check power in and out of dimmer switch.
Dec 24, 2013 | 2001 GMC Sonoma Extended Cab
My interior lughts won't go out when the doors are closed after the van is shut off
Could be the front electronic module. The module has a timer that holds the lights on for about 60 seconds after you exit the van.
Aug 09, 2012 | 1996 Ford Windstar
I can't get the blue light to come on top of the base. The red lught keeps flashing and the amber light is lit. Plantronics 500a headset
The Plantronics 500A is the base for the 510S system, the headset may need to be re-paired to the base unit to make sure that it has a strong link or connection. Here are the links below for the pairing instructions, and also the user guide.
http://www.headsetsdirect.com/pdf/Voyager%20510S%20Bluetooth%20Headset%20System%20pairing.pdf
http://www.headsetsdirect.com/pdf/510_print_en.pdf
Good luck from Headsets Direct - 800-914-7996.
Aug 23, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Have a fryer that i have a problem keeping lit. the reset button when oushed keeps clicking once you get it to stop the fyer will lught however only stays lit a few minutes. not sure if its that swutch or...
Unless the fryer is running at 400 degrees or higher its that switch that is bad. That is a high limit and should not trip off unless the fryer gets close to the flash point of cooking oil which is in excess of 400 degrees for most oils. If I'm not mistaken the high limit is set to trip at 450. It's also a good idea to check the temperature of the oil when its working properly. It should run at 350 and its common to see the flames go off at about 360 and then come on again around 340 to maintain an average of 350. A bad high limit is a common problem.
Aug 06, 2011 | Pitco Frialator 35CS Deep Fryer
WE DISCONECTED THE TERNINAL TO CHANGE IT TO A DIFERENT PLACE , IT WONT TURN ON WHEN PLUG ONLY A GREEN LUGHT BLINKING BUT NOTHING ELSE ON , NTHING ON SCREEN ,TRIED A DIFERENT POWER CORD FOR SAME MODEL AND...
was the unit drop or damage and anyway cause sound like a tamper problem you need to send this to a repair shop to get it check if you need help call us @ 775-358-2922 hope this help : - )
Jun 29, 2011 | VeriFone Omni 3700
2008 3500 HD dually diesel. Check engine light
there are a couple of hunderd diff things that can turn this light on, u need to have the system tested to determine what the code is that was stored with the when the light came on.
Jun 28, 2009 | 2008 Chevrolet Silverado 3500HD 2WD
Parking lughts wont go off
 I had the same problem with my Outback but the solution is very simple, turn off the parking light switch located on the top of the steering column. See chapter 3 page 23 in your owners manual.  This has to be the dumbest and most frustrating feature EVER!
Nov 23, 2008 | 2002 Subaru Outback
Samsung LA26A450 26 in. LCD TV Logo
124 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
