Question about Chi Ceramic 1 inch Flat Iron GF1001USA
Does this unit have an automatic cutoff in case it is left on by mistake?
  • 38 Answers
No, this flat iron does not have a shut off feature. If you're looking for one that does, the InStyler has the shut off feature and it's one of the best I've had (plus it doesn't burn my hair as bad). Hope this helps! :]
Posted on May 25, 2011
Where is the speed sensors located on a 2001 Tahoe
Vehicle Speed Sensor (VSS) - Allison
On the left side of the transmission
Automatic Transmission Electronic Component Views in Automatic Transmission - Allison
Automatic Transmission Inline Harness Connector End View in Automatic Transmission - Allison
Vehicle Speed Sensor (VSS) - 4L60-E
Automatic Transmission Electronic Component Views in Automatic Transmission - 4L60-E
Automatic Transmission Related Connector End Views in Automatic Transmission - 4L60-E
Vehicle Speed Sensor (VSS) - 4L80-E
Automatic Transmission Electronic Component Views in Automatic Transmission - 4L80-E
Automatic Transmission Related Connector End Views in Automatic Transmission - 4L80-E
Vehicle Speed Sensor (VSS) - Transfer Case
On the top left side of the transfer case
Transfer Case Control Component Views in Transfer Case - NVG 246 - NP8 (Two Speed Automatic)
Transfer Case Control Connector End Views in Transfer Case - NVG 246 - NP8 (Two Speed Automatic)
Vehicle Speed Sensor (VSS) Adapter (4WD Only) - 4.8L,5.3L,6.0L
Engine Controls Component Views in Engine Controls - 4.8L,5.3L,6.0L
Engine Controls Connector End Views in Engine Controls - 4.8L,5.3L,6.0L
Vehicle Speed Sensor (VSS) Adapter (4WD Only) - 8.1L
Mar 07, 2016 | Cars & Trucks
Bmw technical support
check with BMW technical division on the net and there may be a genuine unit that will fit in . IN most cases if it fits in another car similar to the one you bought then it is not an added spec but that does not mean that the unit will not be available for your car.
Mar 03, 2014 | Cars & Trucks
Engine was running perfectly but left overnight the fuel tank has emptied the fuel into the oil, the engine is now full of an oil fuel mixture
This unfortunately is a problem with carburetors on a Yamaha. The float sticks and allows fuel to seep past the needle valves and it ends up draining into the cylinders where it escapes past the rings and down in the oil sump. You are going to have to work on your carburetors and put a positive cutoff valve on your fuel flow or repair your automatic cutoff petcocks. You also will have to drain the oil sump and put fresh oil in as the fuel/gasoline mixture is too thin and may cause a fire.
Two essential problems: 1. Automatic petcocks not working properly, and 2. The float is not cutting off correctly.
Apr 11, 2011 | 2001 Yamaha YZF-R6
Is there a reset button on this fuel pump
CHEVY DOESN'T USE A FUEL PUMP RESET/CUTOFF SWITCH, FORDS USE THIS FEATURE, ON A CHEVY IT IS DONE WITH THE OIL PRESSURE CUTOFF SWITCH, SO IF U LOOSE OIL PRESSURE THE FUEL PUMP CUTS OFF, THIS OIL PRESSURE FUEL PUMP CUTOFF SWITCH AND IT'S WIRING ARE NEAR THE OIL FUILTER UNDER THE TRUCK.
Apr 21, 2010 | 2000 Chevrolet Blazer
Amana Ultron Compressor cycles on for 20-30 sec. then turns of for 5 min. Thermostat is set at 70F and indicates temp is currently 78F.
Thermostat settings mean little. Mainly because thermostats are usually not level, or they're dusty inside. The way to test is turn the thermostat all the way hot, or all the way cold.
None of which has anything to do with your problem. First of all, is the unit covered with snow? If so, that's your problem.
Otherwise, it sounds exactly like your compressor is coming on as it should, then being turned off by a safety cutoff.
In this case the high pressure safety cutoff. That is, refrigerant pressure is building up inside the copper lines beyond design pressures, so the cutoff shuts things down. The cutoff is doing its job.
The usual reason for excessive line pressure is an outdoor fan that's not coming on. The usual reason for an outdoor fan not coming on is a failed relay (electrically-operated switch), or a failed capacitor. Fan motor failure is possible, or other problems, but none of them are first on the list.
I'm sorry to tell you that both relay and capacitor replacement are easy repairs, and the parts are not expensive, but both are dangerous if you don't know what you're doing. You can receive a serious electrical shock. Also, a mistake in replacing wire connections can be expensive.
A handyman neighbor with a multimeter (electrical test meter) would be ideal, and you could buy him a lot of beers for the cost of an HVAC service call. But if you're not accustomed to working on electrical appliances, then a service call would be much cheaper than making mistakes--possibly life threatening mistakes.
BUT REMEMBER that I'm just guessing here, from your description. This ain't gospel.
Mar 28, 2010 | Heating & Cooling
2001 corolla's automatic light control busted
The light control unit, on the left side of the dashboard, might be blocked by a windshield sticker on the left side of the windshield.
If this is the case relocate the sticker elsewhere.
Lajar5
Mar 23, 2009 | 2007 Toyota Corolla
HOW TO REPLACE A THERMAL CUTOFF ON ELECTRIC DRYER
you will need too take off your back panel of your dryer and the heater is on your right the thermal cutoff is on the left of the heater housing at the top and then there is a little white thermal cutoff on your blower housing in the bottom left of the dryer now if this is not how your dryer looks let me know cause there is several different style of kenmore dryers but this is the most common one
Dec 29, 2008 | Kenmore 67082 Electric Dryer
Chi Ceramic 1 inch Flat Iron GF1001USA Logo
195 people viewed this question
Top Chi Health & Beauty Experts
ray gallant
Don A
Don A
Are you a Chi Health and Beauty Expert? Answer questions, earn points and help others
