Question about RTO Amcells Total Body Physican Digital Scale
Have error1 on scale - RTO Amcells Total Body Physican Digital Scale
Machine error1 broke needle then machine come error1 can i override
Look for Error 1 in the troubleshooting section of your owner's manual or search for:
Make Model Error 1
May 26, 2018 | Sewing Machines
Error1
Your logic board needs aligning of needs replacing.
Aug 07, 2012 | Exercise & Fitness
Error-1
Hi there:
Manual says Error1 is a damaged or dirty CD. Suggests reinserting. If that doesn't work, it suggests returning to the dealer.
Hope this helps.
May 21, 2012 | Cars & Trucks
Nothing happens escept error1 when print button is pushed
Tape jam or battery low. Please clean the printer and/or exchange the batteries.
Aug 20, 2011 | Dymo LetraTag QX50 Thermal Label Printer
The labeller says "Error1" when I press print. I have changed batteries. Not sure what the problem is?
Error 1 indicates a tape jam or low battery. To resolve, try removing the cassette and clearing the tape or replacing the battery.
Aug 20, 2010 | Dymo LetraTAG Thermal Label Printer
How to solve error1 problem
Error 01 means that communication between camera and lens is faulty. Try to clean lens contacts.
May 25, 2010 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Network occured while connecting to the server
network error1
Whis server? while connecting with what
Oct 13, 2009 | Labtec 961307-0914 Webcam
When putting in a cd screen shows error1
Is it with all cds? Also what is the make & model this would help in tracking down your error code
Aug 06, 2009 | Car Audio & Video
Need help in Special Formatting Number
Here is one solution. You might consider adding more robust error handling.
if the decimal numbers passed to the div function are multiples i will be a non-zero number of that multiple otherwise i will be zero.
Dim i As Integer
i = div(12, 0)
If i = 0 Then
'not multiple
' do this
Else
' is multiple
' do something else
End If
Function div(ByVal numerator As Object, ByVal denominator As Object) As Integer
dim n , d decimal
Dim result As Decimal
Dim remainder As Decimal
If IsNumber(numerator) Is True _
And IsNumber(denominator) Is True Then
If numerator <> 0 Then
n = numerator
d = denominator
Else
GoTo error1
End If
Else
GoTo error1
End If
result = Decimal.divide(n, d)
remainder = Decimal.remainder(n, d)
If remainder = 0 Then
div = result
Else
div = 0
End If
Exit Function
error1:
msgbox("Numbers must be non-zero numerics", , "Multiple check error")
div = 0
End Function
End Function
Aug 06, 2008 | Computers & Internet
RTO Amcells Total Body Physican Digital Scale Logo
29 people viewed this question
Top RTO Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
