Question about Packard Bell Computers & Internet
My monitor will not start when I press the button
  • 56 Answers
If the moniter has an external power supply then there is a chance that it has gone bad. If it does, check to see if the light on it is on when plugged in. If it doesn't then you may have to check the internal one. If you are not comfortable with taking a moniter apart then your best bet is to take it to a local shop for diagnostics.
Best of luck
Posted on May 24, 2011
I have a hem Omron hem 712c automatic blood pressure monitor. it turns on but nothing happens when I press the start button
can you hear a motor sound when u press start?...can you hear a beeping sound when you press the start key?...if no, then your problem might be the contact of start button...but if there is a beep when start is pressed but no motor sound, then your pump must be in problem.
Oct 30, 2013 | Omron HEM 650 Wrist Blood Pressure Monitor
Instructions to reset a nordictrack cardio track watch
You may have started wearing a Polar F11 Fitness heart rate monitor to help you keep track of your pulse during cardiovascular exercise. The monitor consists of a strap with electrodes that you attach to your chest, which transmit heart rate data to a receiver worn on your wrist like a watch. The wrist unit stores data and settings that you can customize, such as your weight, height and target heart rates. However, you may wish to reset the unit and start over with new settings. You can reset your Polar F11 by following a few easy steps.
Instructions:
    • Press any button to activate the Polar F11 Fitness heart monitor unit.
    • 2 Press all buttons on the Polar F11 Fitness heart monitor simultaneously, except the "Light" button. There are five buttons and the "Light" button is at the top left side of the unit. Continue to hold the buttons until the display fills with digits.
    • 3 Press the "OK" button, which is located on the right side of the unit in the middle of the up and down buttons. The Polar F11 Fitness heart monitor will reset.
  • Oct 02, 2011 | Nordic Track NordicTrack Treadmill, A2550
    How do you set the time and date on blood pressure monitor model DS-1902
    Use memory M1 button to increase the flashing year and memory M2 to decrease the year. Press START button to confirm and go to the next step. Day flashes. Press M1 or M2 to adjust and then START to confirm. Month flashes. Adjust with M1 and M2 buttons and then press START to confirm. Hour flashes (the clock operates in 24hour mode). Adjust with M1 and M2 buttons and then press START to confirm. Minute flashes. Adjust with M1 and M2 buttons and then press START to confirm.
    The clock is set and the unit is turned off.
    Please rate if this helped. Thank you
    Jan 15, 2011 | Mark Of Fitness DS 1902 Blood Pressure...
    I can't get my icons and taskbar to center on my monitor. The start button is off screen to the left. How do I center everything so I can access them?
    Press the OSD (On Screen Display) button on the monitor.
    Use the UP/DOWN and LEFT/RIGHT buttons to navigate through the menu, to get to the "horizontal position" menu.
    Press the OSD button to "select" that setting.
    Press the LEFT/RIGHT buttons to "move" the image LEFT/RIGHT.
    Press the OSD button to "apply" the new location.
    Wait a few seconds, and the OSD menu should close itself.
    Oct 24, 2010 | Microtek 815C 18" Flat Panel LCD Monitor
    I have a Wrist Blood Pressure monitor MF 81 that I would like to set the Date and time on it - I don't have a manual
    Start with the unit turned off. Now hold the Power button on until it starts to blink zero (0) on the display. Wait until the display shows two zeros. Press and hold the Memory button until a two-digit number starts flashing at the bottom; this is the year setting. Press the Power button repeatedly until the year is correct. Now press the Memory button, and the month will start flashing at the top of the display. Press the Power button repeatedly until the month is correct, then press the Memory button. The day is now flashing. Set it with the Power button, then push Memory. The hour is now flashing, set it with the Power button (note that it is in 24-hour format, so 1 p.m. displays as 13). Press the Memory button to advance to the minutes, then use the Power button to set it. Finally, press the Memory button to turn the unit off. It is now ready for use.
    Sep 04, 2010 | Mark Of Fitness MF 81 Wrist Blood Pressure...
    Monitor won't stay on
    Restart the computer and tap on f8 button so u can start computer in safe mode, if u are able to restore computer to earlier tiem. IF u are unable to start using safe mode. Ur computer need to reformat. Please insert recovery disc restart computer and tab on down arrow button and follow onscreen instruction...
    Jan 19, 2009 | Liquid Video E15LCD1 15"
    Errors
    Press the following keys:
    Function
    7
    monitor key slowly 4 times
    6
    scroll down to SHIPMENT SET
    set
    Wait for the fax machine to reboot.
    Oct 21, 2008 | Panasonic Panafax UF-490 Plain Paper Laser...
    Compaq Monitor Model 7600
    Dear Lilrose: Here's how to dim your FS7600 monitor. Press
    "menu" on the front of your monitor. Now press + button until
    the icon just to the very right of the 12 0 clock position is
    highlighted. Now press select. A graph will appear and by
    pressing the minus button the screen should start to darken.
    When you are satisfied, push the menu button to escape.
    Hope this helps.
    Radial
    Jun 19, 2008 | HP Compaq FS7600 17" CRT Monitor
    Comp won't start
    maybe there is something wrong with your power supply.. i think you need to change it
    Mar 01, 2008 | Computers & Internet
    More Brightness
    on the front of the monitor there are key buttons naming menu, ok button and left & right arrow marks buttons first press menu button then go to brightness then by using arrow keys you can increase & decrease the brightness once you are finished decreasing r increasing press ok button.& there are many other settings you can change like contrast etc....
    Feb 07, 2008 | LG Flatron 775FT 17" CRT Monitor
    Computers & Internet Logo
    44 people viewed this question
    Top Packard Bell Computers & Internet Experts
    Steve Sweetleaf
    Steve Sweetleaf
    Tony
    Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
