Question about Jl Audio 500/1 Car Audio Amplifier
Sleuthing a 300/4 low-ohm issue. 300/4 amp history: unknown. just connected today whole system yesterday/today: head unit, 300/4(to 4 polk 6.5" component speakers brand new) 1000/1 (4-W3's), to brand new polk door speakers (4 ohm), 1600 watt scosche wiring to dist-block, 1 farad cap on 1000/1. amp plays, no distortion, all is good...until...I begin to turn the volume up, at that point the low-ohm flashes on/off intermittently, at higher volume it blinks more often then stays on....while music plays, until very-loud now, amp cuts out. green light stays on. after short pause and lower volume, amp cuts in again. source voltage hot = 13.9v, used a grinder to clear grounding connection. meticulous detail. I have repaired amps before by replacing output mosfets (digi-key). knowing that heat affects all circuits, would it be likely that i have an output mosfet that is on its way out and due to heat, and as the amplification output increases it begins to short? I did run multi-meter to each mosfet and did not see any near-shorts. (of course thats when its all cooled down though) thanks for your input.
  • 32 Answers
Are you sure you getting enough power to push everything. I have seen when the voltage is too low coming in, the amps will shut down so they don't overheat. Once they've cooled off and the volume level is lowered they will kick in again. Low voltage and a heavy draw will create massive amounts of heat.
Posted on May 25, 2011
  • 2 more comments
  • matthew walsh May 25, 2011
    remember, its the 300/4 that's cutting out with the low-ohm indicator, not the 1000/1. It uses the same distribution block as the 1000/1 so if an amp was to power down due to low-voltage: a: the low-voltage light would activate on the 1000/1, and b: it would be far more likely that the 1000/1 drops first IMO.
    I'm thinking the unit itself has a quirky (read dying) internal component. The question is: what component would most likely be the culprit to produce this scenario.
  • ray0427c May 25, 2011
    Sorry MAW31 I've never driven that far into an amp. I would normally either return the amp if possible or get a new one. Have you tried running the 300/4 by itself unhooking the 1000/1 to see if you get the same response. Just a suggestion. It could be the 300/4 has a more sensitive heat response. If not sorry I couldn't help
    thanks for your input ray.
    Its not really a heat issue as this is reproducible right from the git-go. turn it on, get to 1/4 volume and the low-ohm indicator begins to flash...and more quickly as you get to 1/2 volume. if you turn volume back down, indicator stops blinking.
    Good luck MAW31. Let me know what happens and I'll try to spread the word.
I have a kicker ix 500.4 hookd up to polk audio 6x9 and 6.5. if you play the system past about 25 volume the subs will keep playing but the speakers will cut out for a few seconds as if its hiting the
Make sure your frequency is no higher than 80 on the low and 120 on the high. Check speaker polarity with a AA battery(Speaker pops out when polarity is correct) Make sure the speaker crossovers are working properly. Check your ohm load when you connect the speakers together with a multimeter at the amp. Ohms that are too low = heat. See what your amp is rated for. After all that, turn the gain down all the way, turn up the volume to 25-28 and readjust the gains
Dec 07, 2013 | Kicker IX500.4 4-Channel 500 Watt Car...
Had a 50w by 4 swapped for a 25w by 4 head unit 50w was connected to 500w amp and two subs now 25w is connected now it cuts out when I turn it up any ideas on how to fix will be appreciated thanks
Check your ohms on your speaker it may not be compatable if ohms is too low or not stable for that ohm it will cause the amp to over heat and temp out
Aug 15, 2013 | Audio Players & Recorders
It was turning on fine yesterday & today it won't even turn on
Hi, most of the time with these types of sets the convergence IC's goes bad (2) with some low ohm resistors and or low amp fuses with some cold solder connections....
Mar 28, 2011 | RCA P61950 61" Rear Projection Television
I am replacing the blown front door speakers in my 2001 9-3 convertible with premium sound system. The speakers are stamped 4 ohm. I believe they are subs based upon what I have been able to dig up. ...
Actually the door speakers( less than 50W) do not need high wattage speakers as they are mainly powered from the head unit. Unless you are powering with a power amp a speaker of 300 watts is not required. But if the mountings are correct , the impedance of 4 ohms is correct, then it will fit OK and work. The only main issue will be the sensitivity issue of the speakers to work with a low output.
I have considered that a highly sensitive speaker( small voltage response) will sound great like an expensive power amplifier and high wattage speakers. Jensen had some good ranges in the 80's but now we have hard suspensions with poor response.
So my final suggestion is if powered from your head unit test it , there is no damage but if there is a response problem if you are a soft listener. Other wise there is nothing to worry on as the amp will handle except your listening pleasure.
So test to decide. Credit me if this info is helpful.
Aug 20, 2010 | 2001 Saab 9-3
I just bought a jensen 9312hd head unit and it says on the back only 4 ohms. Well my front speakers are 2.65 ohms and the back are 4 ohms if I connected the head unit would it hurt anything or would I be...
You will be ok. The ohms on the unit are for the rca jacks for an amp. your only issue would be if you have really crappy factory speakers that peak at less than 20-30w. If you have am speakers then your fine with almost any head unit.
Aug 11, 2010 | Ohm 4" 40W SHIELDED WOOFER, 8 Car Speaker
When i turn my system up past thirty my amp shuts off is it because of the ohms or what.How big of an amp am i allowed to use and how many ohms does the amp need to be? Thank You
Key things to check.
1. Make sure you have a good power and ground. Make sure you have a large enough power cable(4 gauge is a good start). The ground should always be attached to bare metal(remove paint from contact area).
2. Ensure your amps crossover is set to low pass and at about 80hz. Turn any bass boost off, and start with low gain.
3.Your enclosure should be 1.25 cu sealed, or 1.75cu ported. If you are too far off these numbers it can cause distortion and clipping.
4. For the single woofer your best amp solution would be a 300 RMS 2ch bridged to 4 OHMs. As long as you're running the sub at 4OHMs you shouldn't have a problem. Under-powering can be worse than overpowering.
5.If your head unit has high and low pass crossovers, set your low pass at 80hz as well. If the head unit doesn't have crossovers, then turn your EQ to flat.
If none of this helps, it could just be the amp.
Hopefully it helps, Plz Vote & Rate
Mar 15, 2010 | Jl Audio 12W1v2-4 Car Subwoofer
I have polk amp that is powering 2 12' subs but itis flashing up with low amp/short light with a little buzz noise?
you must check your wiring from head unit back to subs even take subs out of box to make sure no wires are lose 99.9 of the time a wire has come lose which can be bad if your bridging sups as it changes ohms with 1 or 2 subs hope that helps oh and check volts from you batt and check volts at fuse spots and after fuse to make sure your geting at least 12 to 14 volts cheers i just had a ***** of a prob my subs worked but **** bass found out head unit sub out craped out
Oct 16, 2009 | Polk Audio C5001 Car Audio Amplifier
Jl audio 300/4 low ohms light wont go off
If the low ohms light is on then you have your speakers wired to low. I need to know some more info like what type of speakers you have running on this amp and how many. Also was it working before and then it started doing this? Check the ohms with a volt meter if you know how, if not just get a volt/ohm meter and set it to the ohms setting and then take the positive(red probe) and touch it to the positive terminal on the speaker and then the negative(black probe) to the negative terminal and see what it reads. Make sure you check how low in ohms your amp is capable of handling. If you don't know just google the model of your amp and you will find a site that has a manual or just go to JL audios web site and you should find out there with no problem. Let me know what you find so I can assist you more if need be cause I also repair amplifires for a living and have many years experienc and I'm the cheapest amp repair business you will find any where. Good luck
Aug 15, 2009 | Jl Audio 300/4 Car Audio Amplifier
Low ohm light on with no speakers connect??
This can happen if the amp has an internal fault such as a shorted output transistor.
Dec 26, 2007 | Jl Audio 300/4 Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
138 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
