Question about Linksys WAG200G Router
Internet drops in and out. seems to connect again once the landline phone is used. new filters have been brought - no difference. phone line is clear. ISP have no known problem. speed test is very low. is the router at fault?
    Novelist:
  • 222 Answers
You didn't say so but it can be inferred that you are using a DSL service. Age of telco physical plant (copper local loop) can be a factor. Speed will drop off with loop length and depends on the version of DSL used as well.
Check and make sure there isn't actual traffic causing your slowdown. An infected system can be operating as part of a botnet and congesting the link. Test one (fully patched, if Windows) system directly connected to the DSL modem. Teenagers are similar to viruses in terms of congestion and are harder to eliminate. Beagles never use the Internet.
Technically, the preferences are (in increasing order): telephone company copper wire - DSL, cable company coaxial cable and fiber optic cable. Customer service will usually be the dealbreaker although price and features can be critical. If they can't make one service work, someone else can, especially if they can sell you multiple services.
Consider all of your telecommunications needs together. I use the local telco 'triple play' called FibreOp, which gives television, telephone and internet together (all of these are delivered over the Internet Protocol anyway). It can be a bit expensive so I will switch back to the cable company next year unless 'customer retention' can lower the price.
Posted on Apr 12, 2014
  • 56 Answers
If it is connected to a DSL modem then chances are that it is the modem dropping the connection every time a spike in line voltage occurs. Might want to try directly connecting to the modem and seeing if it still happens, if so then it is the ISP that you need to contact. If not then your router may be on the fritz.
Best of luck
Posted on May 24, 2011
Kx-tge474 Why do my new phones have static on all 4 hand sets?
if you are using a land line and have a modem connected to the same landline , it is possible broad band or ADSL interference frequency
there are filters that connect in line to the phone base station to overcome the problem
Oct 30, 2017 | Lands Phones
WHY DOESN'T MY 2 WIRE WORK ON MY NEW HOUSE PHONE
The usual service drop contains two pairs. The old phone was connected to one pair; the new phone connects to the other.. I have my DSL line connected to the second pair bit still am able to use that pair as a phone line
Feb 10, 2013 | 2wire Computers & Internet
I wish to use one line for both my landline and fax how is this done
Connect the line in the fax (LINE JACK) AND THE landline in the fax jack MARKED AS TEL.
Dec 17, 2012 | HEWLETT-PACKARD HP 2140 Fax
My Belkin F5D7633-4A ADSL2+ modem with wireless router is disconnecting from the internet with increasing frequency. To reconnect I pull out the power cable feeding into the back of the router and after 10...
There could be a number of things going on. I'll list some of them that you might check:
  1. Your wireless network does not have security enabled, and your neighbors are using it to download files using P2P networks. These P2P network connections are crashing your router. In order to resolve this issue, enable WPA or WPA2 security on your router per the user manual.
  2. One of the filters on your phone line has been removed or is failing and needs to be replace. Remove each filter on each line one-by-one and run your Internet connection for a while to see if it fails. Do this one-by-one for each filter.
  3. You recently started using 2.4GHz cordless phones in your home. Get rid of these cordless phones and buy DECT 6.0 compliant cordless phones that use a different radio frequency.
  4. Check the wiring of your telephone jacks to make sure that the connections are solid and that there is no corrosion on the connection. Verify that all jacks and cords are undamaged
  5. Call your DSL provider and complain that their service drops-out on a regular basis.
Hopefully one of these suggestions will fix your issue.
Good Luck
Dec 30, 2010 | Belkin (F5D7230-4) Router (587009)
It is very difficult to get my Huawei HG520s modem to connect to talk talk broadband. i have tried all the configerations suggested by talk talk and no matter which filter is used or how many filters or...
must be your inside wirings. if you have a microfilter make sure you properly connect it. your modem suppose to be connected to your microfilter and your telephone line suppose to be connect on a different wall jack .
if your using a spliter to connect you phone and internet connection make sure splitter is connect properly to wall jack then the first line is for yor microfilter to your modem then the other line is for you phone line only.
Nov 12, 2008 | Computers & Internet
Have new lexmark 4800....wireless printer etc How do I receive fax w/o a phone line attached to equipment??
you cannot, you have to still have a landline connected to the fax, as the broadband is a different thing altogether, just get a double splitter adaptor from your wall socket and then connect the landline in one and your broadband filter in another, or just unplug the broadband and plug in normal phone line when you need to fax
Sep 01, 2008 | Computers & Internet
No ring on phone
check that you have master type socket
Jun 02, 2008 | Lands Phones
Which 1 to use
If it is a RJ-45 connector yes you can use it, The landline uses a RJ11. If the cale fits in the connector then it is a RJ45 connector and you can use this connection. If it works with your internet connection take the netwotk card you bought back. Hope this helps.
Jan 10, 2008 | Packard Bell 1580509280 Network Adapter
Noisy phone line with 2wire rpoter
if the line is clear, just use a line filter only where you have a phone fitted and nowhere else, that way you can try the different filters if you are using more than you need as it sounds as if one may be faulty. Also check any extension leads you may have or remove and check you phone line again for noise. If there is noise it would normally stop you from connecting to the internet also.
Jul 01, 2007 | 2wire (1000-400108-001) Router
Can only get dsl if i use landline
Hi, Rob just studied ur problem.Iam a tech which handles this kind of issue. I talk to verizon,at&t,bellsouth,qwest daily for such issues. Well i can suggest u onething u can get the efficient speedstream 4100 series modem which comes with a 1 yr warranty. And also checkout with verizon clearly abt ur distance from the central office.Bcos might be ur dsl circuit may be not technically feasible i:e NTF. For further clarifications plz get back to me.
Jun 07, 2007 | Westell Wirespeed LiteLine 6100...
Linksys WAG200G Router  Logo
89 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
