Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Remove front panel on sony tv model kdf-we655
Tv wont turn on.power is running to it but it wont turn on
Posted on May 26, 2011
Sony KDF-42 WE655 TV. Replaced lamp and it now works; however sometimes when it is first turned on the audio and video quit for about a minute and the green light flashes. Then both sound and video...
You may have a bad ballast. Check to see if your lamp is lighting up through the back of your T.V. prior to the picture coming on. If it has done this since you bought it, it's probably the just the way the T.V. was designed. If it still comes on every time, it could also be a power supply issue, but nothing to stress about.
Jun 17, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
I want to know where is the lamp section on this tv
Need to remove lower front panel of KDF-60XS955, lamp is located under lower front cover.
Click Sony Support and download user manual, check page-17 for how to remove front cover.
If TV model is different, let me know to provide you info accordingly.
Hope that info will help.
Nov 20, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Where is the lamp on Sony LCD Model No. KDF-E60A20 located in back of TV
There are two thumb screws at lower corners of TV, lose them and take off lower front panel of TV, there you will see lamp cover, unscrew and remove it, lamp is in front of you.
Lamp replacement procedure is written in user manual, click Sony Support to download user manual copy of KDF-E60A20 if required.
Oct 19, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Changing lamp
Lamp replacement is not difficult in Sony KDF-E60A20 TV and procedure is written in user manual.
Unscrew two thumb screws at lower corner at back of TV and take off lower front panel, in approx center of lower front of TV, lamp cover is located, unscrew it, remove it and lamp is there, unscrew lamp with hex key (supplied in new lamp box) and take out old lamp, put new lamp and put things back in reverse order.
Click Sony Support if you want to download user manual copy of TV.
Thanks.
Sep 30, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
How do I replace the lamp in my sony lcd projection tv Sony Model kdf-50we655
TV has 2 thumb screws on lower corners, loose these screws and take off lower front part, there is lamp cover under that removed lower long part at TV front, remove lamp cover, lamp is in front of you, lose its screws and pull it out.
Slide new lamp and put things in reverse order, job is done.
Lamp replacement procedure is also mentioned in User Manual of TV and if you want to download copy, click Sony Support.
Thanks.
Sep 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
I wont to remove front panel
If you mean the front access panel to the projector bulb, start by loosening the screws at each end. They are facing to the back - one each end of lower corners. They are larger and look like you use a coin to turn them.
Now pull the top of the panel out. This is not easy. There are three places holding it on: middle and toward each end. Pull the ends first until they "pop" out. Then unhook the bottom of each end so they are free. Last pull the middle connector loose.
This may sound confusing, but it all makes sense once you get the panel off and see how it was connected.
Mar 24, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KDF-42WE655 "Lamp" LED Blinking
yes this is because of the lamp and these are the lamp types for your tv ,Use Sony XL-2100U or XL-2100 (for WE655 series)lamps
also here is where you can see the replacement procedure ,
it starts here at page 16
http://www.fixya.com/support/p228828-sony_kdf_42we655_television/manual-15827/page-16
just click the next page number to see step by step
and here is the lamp http://www.purelandsupply.com/GeneralSearch.aspx?search=we655
Mar 07, 2009 | Sony KDF-42WE655 Television
Sony grand wega kdf we655
Possibly dust in main fan. Blow out with duster
Dec 17, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
104 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
