Question about NewAir AC-12000E Portable Air Conditioner
What does error code 2 mean - NewAir AC-12000E Portable Air Conditioner
I'm looking for an error code meaning that appear on my krups coffee machine the error code is "code error 02"
You will probably get some proper help if you identify the exact model. I don't expect "error 2" to mean exactly the same on every model Krups have ever made, narrow it down a bit for us please.
Mar 22, 2017 | Krups Coffee Makers & Espresso Machines
Samsung dishwasher dms500trw. what does error code f3 mean. i just replaced the hose after e2 code now 2 weeks later i have f3 code?
Samsung DMS500TRW - ProductReview.com.au
www.productreview.com.au > ... > Dishwashers > Freestanding > Samsung
Rating: 2.4 - ‎49 votes
2.4 out of 5 stars for Samsung DMS500TRW in Freestanding Dishwashers (page 2). ... The machine gives an E2 error and will not pump water out. I have to manually cup it out. ... F3 Error. 1 out of 5, reviewed on Sep 30, 2013. Purchased dishwasher in Jan 2012. First broke ... F3 what dose this code mean? Dell asked on ...
Nov 26, 2015 | Dishwashers
What does error code dc mean?
DC error code means: "Unbalanced load". It can occur if the washer:
1. is overloaded (too many clothes inserted),
2. can't balance the load within a few balance cycles,
3. has a damaged balance sensor,
4. isn't regulated properly (vibrates abnormally).
IMHO you just overloaded the washer :)
Jan 19, 2015 | Samsung Washing Machines
My xbox has 3 flashing red lights on front. What does this mean
It means your system has the dreaded RROD Or Red Ring Of Death,
If you turn the system on and hold the sync button and then hit the eject button, You can find its code you will have to do it 4 times, 1 light means 1 2 lights means 2 3 Means 3 and 4 lights means 0.
You can usually get a code like 0020 0102 and so on, below is a link that will tell you what each error code means,
also look at the back of your system locate the manufacture date, If it's within 3 years of that date don't open the system call microsoft and have them fix it for free.
http://llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Sep 10, 2010 | Microsoft Xbox 360 Console
I have an Error Code 52030 on my WII. What does
it means that u are trying to connect to wifi but there is no wifi around so go 2 tech support for wii and enter the error code.:)
Jan 30, 2010 | Nintendo Wii Console
Error code EL 2 ?
EL 2 Error code means an erratic reading coming from the elevation potentiometer. Unfortunately that means a replacement of the motor Star Trac does not sell just that one part. But you maybe able to send the motor to be repair for aabuot 1/2 cost of a new one. Call this # 1800-496-7278 conpany's name is Nation Gym parts they can help you
Jan 19, 2010 | Startrac Fitness Products Star Trac 3900...
What is 2wire error code 2
When you got this error were you running the installation wizard disc for AT&T?
Because as far as my knowledge with AT&T (Bellsouth) this error code comes out when installing the modem using the Installation Wizard CD, this comes out on a version 3 cd. The error code means
"Failed to Upload to ISP" this possibly could mean that you are not connected to the internet.
Sep 22, 2009 | 2wire 2700HG-B Router (2700HGB)
CD disk error
ok error code 1, look for this error code on your owners manual, toyota cd players give 3 error codes, this mean error code 1, error code 2, and error code 3, they all have different meaning please check owners manuel to see what does error 1 mean i will try looking for you
May 26, 2009 | 2007 Toyota Camry
Code: C 2 ??
C2 error code means, that the drain is clutched.
Removed all dishwasher water with a cup.
Added a gallon of boiled water, waited 10 min and it worked again( so far).
Regards
Sigurd
Jan 28, 2009 | AEG 24 in. Favorit 80800 Free-standing...
NewAir AC-12000E Portable Air Conditioner Logo
35 people viewed this question
Top NewAir Heating & Cooling Experts
Donni Steen
L Pfaff
L Pfaff
Tom Chichester
Are you a NewAir Heating and Cooling Expert? Answer questions, earn points and help others
