Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
How much salt is needed for 1,800 gallon pool (12ft x 30 in. intex metal frame )
  • 297 Answers
SOURCE: Ive had the pump and salt water system going on
What is the appropriate amount of salt? The manual is only a starting point.
You need a salt test kit that reads in #'s not color
Get your pool to as close to 3000ppm
as you can any lower than 2800 and you will not generate enough chlorine any higher than 3700 and you can become cloudy and bad tasting
Yes the pump is weak and will create problems in the future with your system turning green
You need to continually use a non foaming algaecide along with a stabilizer to help hold the chlorine level
chlorine is consumed in many ways heat,sun,sun tan oil,rain,#of swimmers and so on so there may be days you need to generate 5 hours and sum 12 you will get used to what is good for you
Also clean the junk paper cartridge every day intex pumps are not even close to being sufficient for the size pool it comes with
I will use generic #'s for this illustration since I do not know your gallons of water or pump size
any pool needs to be turned over at the very least 3-4 times in a cycle
if your pool is 5000gl and you have a 1500gl ph pump you see that it takes 10 or so hours to filter at the minimum now add in that the pump slows down a bit when the paper filter gets loaded
A cartridge filter can look clean but be clogged with little particles that you do not see
Hope all of this is some help
Just remeber filter filter filter
Posted on Jul 12, 2010
KMusselmann
  • 247 Answers
SOURCE: Water loss in pool, but no hole in liner
The only problem is that ther is a leak in the liner. Generally at the bottom where a rock or debris has made a small hole. They can be patched but the pool will need to be drained. Call your local pool service company.
Kurt
Posted on Mar 23, 2009
  • 77 Answers
SOURCE: Looking for an intex filter pump
The best solution to this problem not to find a replacement intex pump/filter. I suggest getting a system with a 50 square foot cartridge filter and a 3/4 hp pump such as hayward or pentair offers. You will be amazed at the difference a little quality can make.
Posted on Apr 28, 2009
  • 297 Answers
SOURCE: Hayward pump hose and intex pool
Im thinking that hot glue would not harden completly in a direct sun situation not to mention the potential mess
What I did was go to my local hardware store and bought rubber o rings ( sorry dont remember what size) put them on the fitting slipped the hose over it and clamped on top of that area. Has been fine all summer
hope you figure it out
Posted on Aug 05, 2009
thepool
  • 78 Answers
SOURCE: help with pool filter
instructions are here http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?source=intexstore
Posted on Apr 21, 2010
How much salt to put in 18x48 pool frist time
Frame Set or Easy Set?
If Frame Set = About 6,400 Gallons
If Easy Set = About 5,450 Gallons
Salt levels in a pool for a generator to operate efficiently...
2700 ppm Minimum to 3400 ppm Maximum, 3200 being Ideal.
So...
In pool water with NO Salt reading at all - 0, then you will add 2.67 lbs. of "Pool Salt" (which is almost Food Grade Quality! - NOT Softener Salt!) per 100 gallons of capacity.
This chart has lots of useful info: take a look
https://www.hayward-pool.com/pdf/manuals/Salt&SwimChemistryGuide.pdf
Jun 19, 2014 | Intex 18' x 48" Easy Set Pool Package
Have a intex 18x48 above ground pool, how much salt to add to it for the first time
If you have an Easy Set pool, should be around 5500 gallons, then the initial salt add should be approximately 135lbs...
If you have an Circular Metal Frame pool, should be around 6400 gallons, then the initial salt add should be approximately 160lbs...
Make sure you only run the pump for 24 hrs to properly dissolve the salt, then you can set your chlorinator to desired time... Start high and work your way down... 10 hrs pump and 8 hrs chlorinate...
Check your chlorine level after the first two days and see if it starts to climb above 3ppm, if it does, lower your cycle time until you can maintain the 3ppm level...Hope this helps you?
Good luck and enjoy your pool!!!
Aug 25, 2011 | Intex Automatic Salt Water System for ...
I have a 15x 42" intex metal frame pool an i also
Most likely you are not. The manual is very conservative!!! I have a 14000 gallon pool and I run my intex salt system during the summer at 10 to 12 hrs pump and 8 to 10 hrs chlorination in between those 12 hrs and my pool stays very clear. But..... If you don't clean the unit and let it alarm for low flow, low salt or not run the unit log enough, you WILL HAVE GREEN WATER!!!
Hope this helps, If it does, please rate the tip!
Jul 22, 2011 | Intex Automatic Salt Water System for ...
HOW MUCH WATER IN INCHES AND GALOONS DOES A 10FT ROUND AND 30 INCH HIGH METAL FRAME POOL HOLD ?
It will hold ~1175 gallons assuming it is filled to 24" deep. The formula is pi x radius x radius x depth x 7.48.
John
Mar 14, 2011 | Intex "" Metal Frame Pool Set (56998e)...
What is the best model filter pump for an 18' X 48" intex metal frame pool?
No doubt about it the Intex Krystal Clear Deluxe Saltwater System & Filter Pump. No more chemicals to add and no more money to spend. Just buy salt. Could not be easier. I own one myself. http://www.intexcorp.com/saltwater_02.html
May 31, 2010 | Intex "" Metal Frame Pool Set (56998e)...
How much salt to start with a 15ft round pool
Assuming you have the Intex salt water system and the easy set pool, here's what the manual says:
15x33" - 65 pounds (80 for metal frame)
15x36 - 65 pounds (100 for metal frame)
15x42 - 80 pounds (110 for metal frame)
15x48 - 95 pounds (N/A for metal frame)
hope this helps!
May 28, 2010 | Intex Automatic Salt Water System for ...
How do you set the panel on a salt water intex pump mdl no.8110 and how much salt do use
to set the system, hold the down button until it beeps, then hold the up button until it beeps. Now the system is ready to set. Push the up button to the desired number of hours you want it to run. Now, hold the down button until it beeps, then the up button until it beeps. It should be locked and ready to start working.
Without knowing how large your pool is, I can't give you an exact amount of salt to use. If you know how many gallons your pool holds the formula is Gallons x 0.025 = pounds of salt to start up. When you need to add salt, its gallons x 0.0067 = pounds of salt to add when needed.
May 20, 2010 | Intex Automatic Salt Water System for ...
I lost my manuel & don't know how much salt I am supposed to have in it. My pool is an Intex 16 X 48.
I checked the manual.
For an Easy Set you need 110 lbs of salt
For the Metal Frame you need 125 lbs of salt
If you go online to the IntexCorp website, you can download an additional manual for free, takes a while to do but that way you'll have all the info in case you have any more problems.
Good Luck!
Jun 15, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
576 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
