Question about Hotpoint FFA90 Bottom Freezer Refrigerator
The fridge compartment is not cooling although the freezer still works. how can i start it working again
  • 93 Answers
You have two nobs. one says to get freezer colder. adjust it back to get your freezer less colder there by making your fridge compartment get mpore cold air. if that dont work then u have a defrost problem.. if that is the case then u have to manualy defrost then restart the unit then if every thing works right for a week or two then u have a defrost problem
Posted on May 25, 2011
John Lewis Fridge Freezer - Freezer compartment is working, fridge light works, but the fridge is not working. Please help!
Leaving the freezer door open for extended period of time could have caused the evaporator to freeze up and prevent cold air being driven into refrig compartment. Unplugging it for 24 hours will give it a great chance to unfreeze. You can also check the freezer temps before you do this - bet they are no where close to the ideal of zero degrees since the ice buildup is an insulator and prevents the freezer compartment from going down to the correct temps. And if the freezer is not at least 10 degrees or less your ice maker, if you have one, will not work since it has a thermostat that only cycles the ice maker at 10 degrees or less.
Jul 23, 2016 | Frost Refrigerators
Tip
My freezer compartment of my Daewoo fridge is cool (though not as cool as as it...
The fridge gets it cold air from the freezer. There is like an air tunnel that goes from the freezer (usually in the back) to your fridge to provide cold air.
What probably happened it the tunnel is blocked with ice or another liquid. The easiest thing to do is unplug the fridge for 24 hour so the ice can melt.
If that doesn't help, we will have to manually clear the debris in the tunnel.
on May 31, 2010 | Refrigerators
LG Fridge not cooling refrigerator (freezer is fine, fan is running)
those sensors do fail but if the freezer is not as cold as it should be .then the refrigerator part will also not get proper cooling . TEST the freezer temp .
Sep 25, 2015 | LG Refrigerators
Hi I have a Maytag fridge freezer GC2227CDFB The fridge compartment has stopped working, the lights still come on when door open, the motor seems to be working, when temp. setting is turned down to 0 the...
Your problems are exactally the same as mine. I have taken the freezer back panels off and fornd the elements blocked with ice, the upper and lower channels to the fridge are blocked with ice and obviously therefore no0 cold air is going the fridge, I have de-frosted the freezer and put back together and everything works great for 2 weeks when the same thing accurs. My settings for both fridge and freezer are on the lowest possible, but the wife does fill the freezer with too much food! I guess I need an expert in!!
Jun 16, 2010 | Admiral 26 cu. ft. Side-By-Side...
Fridge not working properly on kenmore bottom freezer model 596.7
I have a similar problem, although I have no cooling in the fridge section. Had a repair man indicate that the electrical panal(pcb board) needs to be replaced. It is on order ($200). Sure hope that is the issue. To me, it appeared that the freezer fan(which cools the fridge) was not working. Whether that is the result of a faulty electrical panal is yet to be determined. Good luck!
Aug 12, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Hotpoint FFA90 Bottom Freezer Refrigerator Logo
130 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
