My screen doesn't respond on my viewty when I touch it, so I cannot access anything. Can I get this fixed? - Cheers, Debi
  • 390 Answers
i think there is a problem with the touch screen and needs replacement, this happens sometimes due to static charge on our bodies and when we touch the screen for activating it gets shorted and this generally needs replacement of the damaged touch screen
Posted on May 24, 2011
  • 84 Answers
This can be fixed by purchasing a new digitizer.
http://cgi.ebay.com/LG-KU990-KE990-Viewty-LCD-Touch-Screen-Digitizer-USA-/150354737956?pt=LH_DefaultDomain_0&hash=item2301d73b24
Very low priced replacement. You can then have it replaced by a tech or replace it yourself.
Thanks for using fixya.
Touch screen doesn't respond when i try to unlock screen
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Aug 04, 2012 | Samsung Galaxy S GTI9000 Smartphone
The touch screen doesn't respond to the stylist and the arrows and the x, y, a, b control buttons are not responding either.
The most common problem is that you might have disessembled your dsixl and might have damaged the wires. It wouldn't just break in the first day you get it. So i recommend you to send it to the nintedo or find a local geed to get it fixed. If you break somehting, you can't fix it by your self.
Jul 27, 2011 | Nintendo DSi XL Burgundy
My touch screen doesn't respond to touch and I am unable to make copies.
Does it respond to any touches or is it greyed out? This problem can be caused by either a bad touch pad or a defective scanner. Try accessing other options on the front such as the administrative menu. If those work, then the scanner might be bad or locked? Lift the automatic document feeder lid and check the lock on the left hand side to make sure the scanner is not locked. Restart the machine as well, could be an intermittent problem or static discharge.
Jun 06, 2011 | HP LaserJet M3035 MFP Printer
Touch screen stopped working
Have you tried to recalibrate the touch screen in the Set Menu? If so, and it still doesn't respond, then the touch screen might have gone bad. This is something you should have a dealer repair. About a $200.00 repair.
Apr 28, 2011 | Husqvarna Viking 1
Hi. The touch screen on my wee girls touch screen has stopped working. Can I fix this myself or can do I need to send away?
You can try sorting the problem yourself before you decide to send it in to Nintendo.
Most DS touch screens stop working if there is dust, hair, sand etc gets under the frame of the DS. They stop working because the particles get pushed down on the touch scream making the DS think that screens already been touched and won't respond.
Get a toothbrush with straight bristles and with your thumb gently press down the touch screen along the frame, use the touch brush to clean under the frame but be vary careful not to press down too much as you could cause damage to DS.
If the screen still doesn't work then you'll have to send it in for repair.
Hope this helps.
Regards.
Apr 24, 2011 | Nintendo DS Lite Console
Touch screen is not working
You can replace it. They run about 15 dollars from ebay and are pretty striaght forward. Here is a link on how to replace the touchscreen on the Ku990.
http://www.crackedlcdrepair.com/replace-the-lg-viewty-ku990-lcd-screen/343/
Sep 26, 2009 | LG KU990 Viewty
My LG Viewty phone has been frozen for 4 days. The only thing I can do is answer calls and make calls to numbers in my call register. Everything seems to still work perfectly, exept for the screen. I've...
My LG KU990 viewty screen has frozen....meaning...the touch screen doesn't respond when I press it.
I can answer the phone and only call numbers i've already.
Does anyone know how I can fix this
I stupidly did not get it insured
I've turned it off and left it off for some time, taken the sim card out, but this doesn't help. Does anyone have a solution?
Aug 17, 2009 | LG KU990 Viewty
Touch screen on lg ku990 seems slow
they reckon if it has a screen protector on it it is "slower" to respond. So if you do have one off... remove it. but yes I do believe my touch screen is abit delayed even without a screen protector :(
Apr 28, 2009 | LG KU990 Viewty
LG viewty Touchscreen problems
I have the same problem. But i had solved it. I use a lighter to burn on my viewty's touch screen, and it is working properly again within 30 secs. And ofcourse, do not burn the touch screen without a screen protector. Hope this solution would help.
Aug 12, 2008 | LG KU990 Viewty
Touch sensitive screen not working
I found a solution for the LG KU990 Viewty touchscreen not responding problem. After thinking about twisting my phone, I came up with another solution which actually works every time. The touchscreen works via layers of plastic that when contact is made, a signal is triggered from the coordinates of the contact. However, when the phone has pressure, these layers of plastic stick together somehow. So, to fix it.... Get a small strip of adhesive tape that will not leave a sticky residue on your screen. Apply that tape in several spots on the surface of the screen, and lift it away from the phone with light pressure. Repeat this in several areas of the screen. That's it. You're done. Your screen should function properly. Simply recalibrate the touchscreen at this point in your settings menu. I hope it helps everyone with any type of touchscreen. I know it helped me. The touchscreen phones are totally useless using only the hard keys!
May 14, 2008 | LG KU990 Viewty
Computers & Internet Logo
200 people viewed this question
David Payne
David Payne
