Question about Dishwashers
How to work my dishwaher - Dishwashers
  • 8,197 Answers
May i get the make and model # to get you the manual or tell you how to use.
Posted on May 24, 2011
Dishlex 300 blobal dishwasher. have set dishwaher for normal wash as usual. All lights are one but dishwaher will not start. help please
It is likely the door switch is not engaging properly. Check the gasket is set properly and the door is closing when you shut it. Also confirm if it is not on delay start.
Feb 13, 2011 | Electrolux Dishwashers
There is a brown film all over inside of dishwasher. I have to put it on power scrub for my dishes to get clean.
I had a similar problem with my Whirlpool dishwaher, and it turned out that my water softener was not working. Once that was resolved, I found that I have to use a rinsing agent in the dishwaher to completely eliminate spots on the cleaned dishes.
Dec 03, 2010 | Dishwashers
Kenmore elite dishwaher 1646 not cleaning dishes.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
jklfryyr
Jul 06, 2010 | Kenmore 24 in. 16462 / 16464 / 16469...
I have a ariston dishwaher which is boiling water but not filling machine
I called an engineer who dismantled the pump and found a rawl plug in it. Now working fine again.
Apr 14, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
Asko D3122 dishwasher will not fill with water and will not turn off
you may have water under the dishwaher ... have any plumbing work done lately?
if the dishwaher overflows or leaks it will trip a float switch under the dishwasher... as long as it is triped it will run the drain pump.. and not let any water into the tub...
the water will have to be removed and the leak stopped before it will run a cycle....
Hope this helps if not let me know more about your problem..
Mar 20, 2009 | Asko D1876 Dishwasher
Where is the drain screen at in my My frigidaire dishwasher
generic reply normly in the center and looks like a plastic grating, but is your drain hose kinked?
Oct 25, 2008 | Frigidaire Dishwashers
I accidently bought jet dry cleaner and not jet dry rinse aid and i put it in the rinse aid. what will happen to my dishes. How can i get it out. I have 3 young children i do not want harmed from using my...
jet dry cleaner??? im thinknin its also a dishwasher detergent???if so i wouldn 't worry about at all, no way to empty the dispensor, it will dispence on its own over the coarse of a month. but yea so long as its a dishwasher detergent i would not worry about harm to family
Apr 08, 2008 | Dishwashers
Dishwaher
Generally, you need only hot water. It is advisable that the drain line be a little lower than used by a washer. Drains usually go into a modified portion of the sink's j bend in the drain. This sits at about 18 inches off the floor. You should fuse your electric line for 20 amps at 120 volts or 15 amps at 240, depending on your location. North American units are at 120.
Mar 15, 2008 | Dishwashers
Beko dishwaher
Some problem. Here I have a Kenmore quietguard that washes the dishes fine but it does not heat up and dry the dishes when it completes. Any idea.
Nov 08, 2007 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
