When composing e mails, symbols are often not what they are shown as on the keypad. For example, shift 6 gives me a question mark and shift colon gives me an e with an accent over it. There are others that are messed up as well. The problem seems to come and go, for no rhyme or reason.
  • lyle646 May 24, 2011
    system restore worked, couldnt get other idea to work.
    Genius:
  • 1,570 Answers
Hi
If your laptop keyboard types wrong characters, it is rather a software issue than an hardware one. This can happen if you accidentally press certain keys on your keyboard, which enable a certain kind of function.
Try the following steps in case your laptop keyboard displays wrong characters:
1.Go to the control panel option
Click ? 'Regional and Language Services' ? 'Languages' ? 'Details' ? 'Key Settings'
2.Select the option 'Switch Between Input Languages' and click on 'Change Key Sequence'
3.Ensure that all the check boxes are unchecked in this window and do the same for 'Switch to...(Keyboard Type)'
4.Click 'Ok' 'Ok' 'Apply' 'Ok'.
This should solve your problem
If not, try to run the SYSTEM RESTORE,
Go to START
Choose ACCESSORIES,
Choose SYSTEM TOOLS
Choose SYSTEM RESTORE
And then choose previous RESTORE DATE THAT YOUR COMPUTER WORKS FINE. If still not restore the correct setting. Try other restore dates.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Posted on May 24, 2011
How do you use the 'at' symbol when composing an email on the sandstrom SKBSWITCH1 bluetooth 5 keypad
The @ sign may be above the 2 on the numeric pad and you will need to use the shift key or it may be another key
on the alphabetic keyboard. If it's above any other key you
will need to use the shift key.
Jan 05, 2018 | Symbol Computers & Internet
How to reset time
To set the clock, press
"Clock"
once
or
"Timer/Clock"
twice
(depending
on your keypad)
The colon symbol (:) will flash.
Enter time of day.
The time appears
in the window; the colon continues
to flash.
Press
"Clock"
or
"Timer/Clock"
again - colon stops flashing; time of
day is set !
Nov 16, 2015 | Panasonic Microwave Ovens
Dell manuals
I have Dell N 017F9Y keyboard, which has several keys with up to 4 special characters (e.g., ;, : apostrophy and degree symbols on one key) on them. The problem is - what keys (shift/alt/Ctrl or specific combinations of these) should be used to get appropriate character. There are 6 keys with 4 characters, 6 with 3 characters. Another example is when I try to put question mark using Shift lock it gives me ( ^ ) this character. The help is urgently needed.
Thanks..Kumar
Jan 10, 2014 | Computers & Internet
Setting the clock on a microwave what is the last action after setting the time. Everything I've tried results in the error message coming up.
According to the manual this is how to set clock.
To set the clock, press "Clock" once or "Timer/Clock" twice (depending on your keypad).
Enter time of day. The time appears in the window; the colon continues to flash.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set.
If you need the manual it is on link below.
http://service.us.panasonic.com/OPERMANPDF/NNH624-SET%20UP.PDF
Good Luck
Nov 08, 2010 | Panasonic NNH965BF Microwave Oven
I NEED A MANUAL TO SHOW HOW TO GET MULTIFUNCTION KEYS TO WORK. FOR EXAMPLE HOW DO I GET THE ALTERNATE USE OF THE "NUMERIC 6 "KEY ie THE" QUESTION MARK" FUNCTION
You must have a different keyboard selected other than the standard US keyboard My numeral 6 has ^ on it and the numeric keypad 6 has a right arrow. One generally uses the SHIFT key to access symbols that are written above the main alpha or numeric key. The numeric keypad on side of PC has a button labeled key marked NUMLOCK that is engaged to allow use of the numerals as a calculator or to also be inserted into text.
Please rate my help++++Thanks for using FIXYA
May 09, 2010 | Acer NSK8458AN Keyboard
For some reason, I can no longer type a colon. I can type a semi colon ;, but shifting does not give me a colon. Can you help?
Has it always been like this? or you noticed it recently? The thing is, sometimes the characters on the keyboard are not where they're mentioned. So check all the other keys while holding down the 'Shift'. I am sure you will find your 'colon' under a bracket or a number.
Oct 18, 2009 | Dell SK8110 Keyboard
Unable to type question mark i getÉ colon è
Nothing. You just need to change the keyboard layout. For help Start > Help and support > (type keyboard layout) and press enter.
Aug 25, 2009 | Toshiba Portege 3500 Tablet PC
Keyboard symbol keys now showing as accent keys
Or maybe you can try to hit the control en shift button at the same time and then try again.
Jan 26, 2008 | Logitech Cordless Desktop MX3200 Laser...
Computers & Internet Logo
David Payne
David Payne
