Question about Roland Spd-S Sampling Percussion Pad System
Audio very minimal. Happened just one day I turned it on - all volume knobs at max, from both headphone and main output. Tried factory reset. There is more idle buzz than I remember hearing, and when I strike a pad, I can hear the sound very faintly coming through.
  • 1,056 Answers
Seem like a problem with the internal amp this an electronic circuit problem.
Posted on May 24, 2011
My reciever turns on and works fine apart from a mains buzz that comes out of the speakers and headphone output and gets louder when the volume is increased
Check if your system has dolby NR.(noise reduction) system, If yes then turn it on. Secondly minimize treble control.
Dec 29, 2014 | Pioneer VSX-455 Receiver
Why could my volume knob be stuck on max volume and not adjusting?
There is probably grease or dirt on the contacts inside the unit. Here's a video that shows you how to fix it:
http://www.youtube.com/watch?v=y4XF9PoidJQ
Hope this helps!
Aug 08, 2014 | Marantz SR-4320 Receiver
No sound thru headphone jack
Please confirm that the sound from the main output is working. if it is functioning then check if there is not a seperate Headphone volume or mix control adjustment.
Jan 31, 2014 | Pioneer Audio Players & Recorders
Onkyo tx-ds656 stand by power light comes on volume control knob rotates to max but display or unit wont start
Try factory reset: while holding the(CD) button on front panel,press (POWER) button.
After "Clear" is displayed the unit should be back to its factory default. :) If this dont work for you take the unit to be checked by service . :)
Jan 24, 2014 | Onkyo TX-DS656 Receiver
How can I connect Senheiser wireless headphone to Yamaha RX773 without using front headphone jack as this mutes speakers, I have hearing problems, my wife doesn't, I tried both av audio outs in the back...
Your receiver has Zone-2 functionality. For Zone-2, it has both speaker (powered) output and pre-out line outputs. According to Yamaha FAQ, these pre-out outputs are independent on the main volume settings. So if your wireless headphones have their own volume settings, you can change the volume independent on speakers volume.
If you want same volume for speakers and headpohones, use the PRE-OUT FRONT outputs on the back. If you want different volumes (and listen to headphones even with speakers muted), use ZONE-2 OUT outputs on the back.
Oct 02, 2013 | Yamaha RX-V773WA RXV773 7.2-Channel A/V...
Macbook pro headphone audio
Go in to the "applications>utilities" folder. Run the "Audio/MIDI Setup" program. Insure the audio out is actually going to the headphone out.
Mar 21, 2013 | Apple Computers & Internet
How to connect sansui HT 2501 5.1 home theater to pc
In general, the PC's soundcard and video capabilities will determine the answer to the question. And which direction you want to run. Is the PC a source or the end-unit or both? Your PC hardware and software documentation would describe various scenarios.
The PC is a common source of audio. Any PC should have a minimal headphone output, which would be functionally the same as the analog L/R speaker output. Simply adapt the cables for RCA connection to your audio system, get into yourt PC's sound controls (usually proprietary), max out the volume and set its output for something like FULL range speakers.
Run it to any available Line Level input on the HT.
Digital outputs, same same.
Sending sound TO the PC will depend on IT and the software it uses.
Jan 13, 2011 | Sansui Audio Players & Recorders
A new DM7 drum set line out has very low output. It is connected with drum combo Stagg EDA40 and if combo drum inputs are used there is practically nothing to hear . With combo maximum volume there is...
The sound on all the stock kits I found to be too low. What I did was create a custom kit and altered the dynamics of all the pads and cymbals - once you're in the dynamics settings, just hit the pads/cymbals the hardest you normally would and save that setting!
Dec 29, 2010 | Alesis DM7 USB Electronic Drum Kit
Initially the main speakers would not shut off when the headphones were plugged into the headphone jack. I reset the audio settings to the factory default. Now the headphone jack does not work. How do I...
If you right hand mouse click on the louspeaker icon, click on open volume mixer.
You can set the headphone volume and speaker volumes from there. (depending on your OS and set up preferences)
Nov 17, 2010 | Toshiba Tecra 8100 Notebook
Audio from tv is not restored by turning off power on headphones
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections.. your current “work around” is your only solution.
Best of luck
Dec 31, 2008 | Sennheiser RS 120 Consumer Headphones
Roland Spd-S Sampling Percussion Pad System Logo
163 people viewed this question
Top Roland Audio Players & Recorders Experts
Electric Dime
Electric Dime
Vito Vacirca Jr.
Greg Cann
Greg Cann
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
