Question about Garden
725r bumb head cutting attachment-needs replacement for 2 cycle gas cylinder trimmer
  • 19,396 Answers
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
725r trimmer
You can buy new Line to re-spool on your existing head
Aug 17, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Replacment of starter pull cord
Remove the recoil cap cut the knot of the old cord off pull out the string. Cut a new cord the same length thread it in and knot it . rewind the spool until the cord in the spool. fish the cord out of the pull hole and tie on the pull handle
Aug 04, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Ryobi 725r 2-Cycle Gas Trimmer will not start
Is the carburetor a Walbro brand? If so, there is a 12 page PDF paper that describes theory, and maintenance. Go to:
http://www.drystacked.com
Jul 24, 2009 | Ryobi Factory Reconditioned 18" 40cc...
2 Cycle Gas Trimmer will not start
it is normal to see air bubbles in line when pumping the bulb. to make sure what the problem is, try starting several times, remove spark plug. if dry, yes no fuel, remove the carb. if wet, place plug on engine block and look for blue spark. no spark means you need new plug, plug cord or ignition module
Cannot disassemble Troy-bilt trimmer head
There is a round, rotary black part between the metal piece to which the cutting head attaches and the outer plastic seat of the cutting head. There are two square slots, each about a quarter inch wide, on opposites sides of the black piece. Slide an Allen wrench or something similar firmly into the slot. Holding the Allen wrench in a stable position, turn the outer plastic ring of the cutting head (it has scalloped edges that can be gripped firmly) counter clockwise to unscrew the cutting head from the bolt on which it is mounted. Be careful with the tool (e.g. Allen wrench) used to hold the black piece steady, as it is plastic and could be damaged by the edge of the tool.
Jun 07, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Replacing Drive Shaft for a Ryobi 725r
The lower flex shaft should cost around $40, unless you order it online and have to pay shipping. You should be able to get one from your local MTD dealer. (Ryobi is owned by MTD)
May 25, 2009 | Ryobi Garden
The pull rope broke on my ryobi 705r/725r gas trimmer. I have all the screws off but it seems to be held on by the center shaft that spins. What do I do now?
I have the same issue of clutch removal on a Ryobi 725r. Actually the clutch finally died after many years of use.
Instead of using a screwdriver to hold the piston I recommend using a piece of clothesline rope. It will be easier on the internal components and won't scratch up the cylinder walls or piston. Just be sure to leave a small amount hanging out of the spark plug hole so you can pull it out afterward.
Apr 15, 2009 | Garden
Ryobi 2 cycle gas trimmer 705r/725r
The gas nipple that come out I have...whats goes in the other hole?
Aug 28, 2008 | Ryobi Garden
Garden Logo
77 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
