Question about Western Digital Passport 320GB External USB 2.0 Hard Drive
320 GB Passport External HD recognized as drive F get i/0 error when try to access I have tried other usb ports with same results tried 2 different chords with same results Is this just toast?
  • Western Digital Master
  • 27,725 Answers
Click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Posted on May 24, 2011
Trying to add on a wd passport hd thru usb port...plugged in on both ends, and drive sitting there making a clicking noise
sounds like the drive went bad have also try a different usb port make sure you are using one directly connected to the laptop/pc not thru a usb hub
Mar 27, 2011 | Western Digital My Passport Essential 320...
I have a Hitachi Simple Drive Mini x 320 GB that I've been using as an external for my macbook pro. I have been using it without problems for over a month now, but last week it didn't eject properly from...
does the usb cable you are using have 2 usb plugs so you can plug it into 2 usb ports at the same time.
If not, you could try using one, sometimes my external HD will not work on some pc's if i just plug it into 1 port
Sep 10, 2010 | Hitachi 120GB Hi-Speed Mobile Disk USB 2.0...
Can't figure out how to copy info from Passport to my hard drive
the question here is how did you manage to get the info saved into your passport portable hd in the first place? I don't mean to sound like a smartass but if you did save the files onto your portable hard drive before you wiped your pc's hard drive it should work the same way backwards if you want to access and restore the files back on to your pc from your portable hard drive.
now to answer your question you should simply...
1. plug your portable hard drive (I mean power and usb cable both).
2. turn on your passpost portable hard drive (if needed).
3. your computer should see your portable hard drive now being connected to the usb ports, wait a few seconds for the computer to recognize it and give you access to it.
4. if you don't a pop up asking you what to do with the new device you just connected (passport port. hd) simply go to start>my computer and under removable devices category you should see your portable hard.
5. double click your portable hard drive and you should be staring at the contents of your passport hd.
6. you can copy some or all the folders you find in your portable hd on to a folder that resides in "my documents" folder which is a folder that resides in your pc's hard drive. (if you are not accoustumed to move folder around from one device to another, please ask the help of someone that is familiar with this task or simply select a folder, right click on it, select "copy", then go to the target location, right click on an empty space and select "paste")
if you are not able to do this 1-6, you may have not completed setting your system, and it's possible that you may still need to install drivers for you usb hub (for instance) to have your system being able to work with usb devices.
post back with your findings and any details of any problems encountered along the way.
hope this helps!
Apr 22, 2010 | Western Digital Passport 320GB External...
WD External Drive-USB recognize, but no icon, can't access
1. Right click on My Computer > Manage;
2. On the new window click on Disk Management, on the right side, right click in the USB Volume and chose "Change Drive Letter and Path..."
3. In the new window click on "Add..." to assign a letter to your USb drive.
Best Regards
Jun 24, 2009 | Western Digital Passport WDXML800UE...
External Hard Drive will not show up. Tells me to format it.
I have a Western External Hard Drive 320 and when I plug it in the computer will recognize it and allow me to access my files but after a short while if I go to click on a file t open it the WD 320 will click off for a minute and then reappear in the auto run mode.
Jun 20, 2009 | Western Digital Passport 320GB External...
My old computer does not recognize my new 250gb wd passport I get an error that my Z drive is not logged on
Are you sure your 'old' computer has USB 2.0 support and not only USB 1.1?
You can try accessing the BIOS of the computer and see if you can change the USB version there.
Once it is recognized, Windows (XP?) should recognize it and install the drivers. If you are running an older OS, you probably need to install drivers for it first. But those would come with the drive (on a CD maybe).
Also check out:
http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Jules
Feb 26, 2009 | Western Digital Passport WDXML800UE...
Ibm t43, xp pro won't recognize my WD 320 passport
Well, that IBM is from 2004, the usb port and drivers is to old for the WD 320 who requries USB 2.0. Thats why your IBM dosent recognize it, your IBM getting wrong signal from the WD thrue the old usb port.
I dont think you gona make those items to work properly togher M8, sorry
Nic
Feb 06, 2009 | Western Digital (WD3200JS) 320 GB Hard...
WD Passport 250GB External cannot be recognized.
Go to BIOS (Press DEL or F2 to enter BIOS). Check if the Power state is in S1. Ensure that USB setting is in Hi-Speed.
Restart the computer and try using the device. this should fix. Let us know the result.
Thanx
Jan 16, 2009 | Western Digital Passport WDXML800UE...
My MAC won't recognize my WD 80 GIg External HD
Some computers (especially Mac laptops) don't send enough power through the USB port to power a passport, so you need to get an extra power cord, one that combines 2 USB ports into one to get a little extra juice. Wish I could give you a website where you can buy that extra cord but I am currently looking for one myself at this moment in time.
Nov 16, 2008 | Western Digital Passport WDXML800UE...
Western Digital Passport 320GB External USB 2.0 Hard Drive Logo
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
