Question about Garden
Pressure washer challenge ABW 70P has no pressure
How do i fit a new lance to Challenge MH02-1610GO pressure washer
Just the lance or trigger gun! Best of luck to ya!
Sep 23, 2014 | Garden
Abw vc 65 parts
Yes.
I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
Jul 14, 2014 | McCulloch FH160G Pressure Washer
Marlin model 70P, serial #14388170 date of manufacture
1986
Take the 1st two numbers of the serial number, and subtract from 100.
14388170 = 14
100 - 14 = 86 = 1986
Feb 17, 2014 | Optics
Challenge xtreme 2000w pressure washer manual
Hi I have a challenge extreme 2500w pressure washer. it's tree years old , hardly used. I have come to set it up, but seem to have no power or start up after switching it on. any advice would be greatful?
Jul 01, 2012 | Garden
TerHow does the detergent tank on a Challenge Extreme Pressure washer operate? I cannot find a trigger to release the detergent into the water or does it happen automatically when there is detergent in...
The water pressure moving through the main hose siphons detergent out of the tank as long as you are pressure washing. It might take some time before you see the detergent coming out the nozzle.
Sep 04, 2011 | Garden
How to open the top of matag washer model LAT 9800 ABW
when you say top i don't know if ya mean main top or control panel so ill tell ya how to do both
CONTROL PANEL; remove the inner phillips headed screw on side and tilt downward
MAIN TOP; remove phillips headed screws from bottom of front panel,tilt panel out and off.Inside cabinet between cabinet and top will be a 3/8" headed bolt on each side,pull off hose for bleach dispenser, remove bolts and lift up top
Hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | Maytag Washing Machines
Garden Logo
213 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
