Question about Cameras
Camera was fine when I put it down, but when I went to take a photo the next morning the lens did not come out when I pulled the slide back.
    Problem Solver:
  • 6 Answers
There is something wrong with your lens barrel. It can be anything from some sand/dirt that got inside in which you try using some canned air to blow out the particles while continually turning it on and off. Usually what it is from is the camera being dropped, even if it is in a case or inside a bag. The jostle or direct impact of the fall will break some small gears or tweak the lens off of alignment. If it was from an impact then you lens barrel needs to be replaced and in that case the repair cost are usually as much as getting a new camera. Sorry about your camera.
Posted on May 25, 2011
My lense will not auto or manual focus. It seems jammed. It worked in the morning and next time I went to use it it didnt work. I made sure the camera battery was fully charged. The other lenses work...
Is the manual focus ring not turning? If not, you're going to need to send it in for repair, shop around for local shops as they offer competitive prices. If your lens is still under warranty you can send it into Nikon, here is their contact info for repairs:
http://www.nikonusa.com/Service-And-Support/Service-And-Repair.page
Phone: 1-310-414-8107
Fax: 1-310-322-6979
7am - 3pm PST Mon - Fri
East of the Mississippi River:
Nikon Inc. Photo & Digital Service
Nikon Inc. Factory Service
1300 Walt Whitman Road
Melville, NY 11747
West of the Mississippi River:
841 Apollo Street, Suite 100
El Segundo, CA 90245-4721
Mar 06, 2011 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
I was taking photos and evertime i took a photo i turned it off,(i was on a plane) and then went to turn it on again, and it opened then lens opener (two black things) and then beeps 2 times and turns...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success
Jan 20, 2011 | Samsung WB550 Digital Camera
I have a Kodak Easyshare model dx5430 digital camera (5mp). It has worked like a champ for years. Last night I was at an event when the image display went dark at picture 31. All preceding photos were able...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 01, 2010 | Canon PowerShot A75 Digital Camera
System error
This eroor usually comes due to faulty sliding mechanism.Put a bit of force on the focussing lense to push it back into camera casing. That's the reason the sliding mechanism won't work. The lense is stuck and if you force it back in, the sliding mechanism will work again. Not responsible if your camera screws up, so try at your own risk.
Or else try out this method
Pull the lens fully out and then it will work.It will be bit tricky to get the lens out. Use your nail to "grab" between the outer glass and the little plastic cover.
Hope this will work for others too.
Aug 28, 2009 | Konica Minolta DiMAGE G400 Digital Camera
Lens will not extend
Hi:
You need to clean around the lense first. Blow high pressure air spray and get the most sand out of the lense you possibly can.
If it did not open 100%, try to pull it out NOT too hard. If the lese goes up and down and turns you should follow the lense while pulling it out.
When it is 100% out, (the way normally opens) Clean around the lense more.
Turn you camera on and off a few times. It should be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 20, 2009 | Konica Minolta DiMAGE G500 Digital Camera
Nokia 6500: Dodgy screen?
simply check the connections of the lcd to the board... or just tighten the screws... i had repaired a phone of that problem and this was my solutions.
May 31, 2009 | Nokia 6500 Slide Cellular Phone
Camera wont turn on/off
I went to another problem, knowing my camera was stepped on, I messed around with moving the lens part around, barley moving it, and then I tried holding the on/off button and the button to take the pics with, and then put in new batteries and it turned on. I would suggest doing that.
Aug 28, 2008 | Sanyo VPC-S500 Digital Camera
Auto Focus not working for Canon EFS 18-55mm lens
Pulling gently on the focus ring worked for us. Exactly what the Dr. ordered. Slight pop, maybe 1/16" movement, and the lens is working again!
Jun 29, 2008 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Lens error coolpix l6
The lens is probably stuck with a piece of dirt or something jamming it. You could gently try and pull on the lens with a slight turn in each direction to see if you can dislodge the particle.
Some individuals on the internet have felt comfortable enough to try and disassemble the camera to reveal the parts of the lens drive mechanism, clean it and put it back together and this sometimes will help (but that is beyond this response) because there are enough locations on the net that describe this.
Since it's 4 months old, you may want to return it for a replacement.
Other alternatives are:
  1. Carefully use some compressed air around the lens mechanism.
  2. Take the camera back and get a replacement, or
  3. Talk to Nikon and get it serviced.
Hope this helps, if it does, please choose FixYa!
ThankYa!
Nov 10, 2007 | Nikon Coolpix 5200 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
