Question about Harman Multimedia Harman Kardon HK 3490 Stereo Receiver
Hk3490 check amp amp protect why does this occur?
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on May 24, 2011
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 65 Answers
This amplifier can go into protection if one of the low ohm resistors on the power module that is soldered to the transformer is defect. Check out R951 and R952, they are both 0R47 (0,47ohm). They are often broken and measure some kilo ohms.
Posted on Nov 27, 2013
  • James Chavez
    James Chavez Jan 04, 2016
    Are these resistors linked separately to the left and right channels? My receiver goes into amp protect mode only when a speaker is hooked up to the either spk 1 or 2 right channel. I've tried this with many different speakers, including the ones that I can hook up to the left side without it going into amp protect.
    Thanks!
  • berggei Jan 04, 2016
    This resistor are commen for both channels. So not linked separately to left and right channel. I would check and see if you have DC on right channel speaker output.
    New Friend:
Hi I have same problem what could be the issue?
Posted on Mar 03, 2013
Best way to hook up Bose 901 series VI to a Harman Kardon HK3490
According to the HK site, "Stereo pre-amp outputs let you connect the receiver to an external power amplifier." So it's easy. Connect the Bose equalizer in the pre-out / amp in loop.
Nov 07, 2015 | Bose Audio Players & Recorders
When I turn on my unit, a Harmon/Kardon Model HK3490, the red light turn to white, then turns back to red after a couple of seconds. Nothing else powers up. Any suggestions as to what the problem is
This sounds like a safety problem. The unit might have developed a short in the main amp section and so shuts down to prevent damage. One thing that might cause it is wiring problems to the speakers. Possibly a two wires touching or a break in the cable.
Jan 28, 2015 | Audio Players & Recorders
I have a 600 watt diamond audio amp hooked up to 2 pioneer 10s the amp comes on but slowly shuts down speakers have sound at first but gets lower as amp light dimms. What's going on. Also I have a boss 20...
Short circuited component/s at amps' audio output stage circuit. Contact any service technician to get it repaired. Short circuit protection circuit is built inside this set, and it will detect the internal short circuit, when it occurs, and will shut the set's power OFF, to protect the speaker and other components. That is happening here.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 06, 2014 | Car Audio & Video
We installed the amp with more than enough gauge wire, and a fuse. and after resetting the ground strap we got the amp to start working after about 3 minutes at medium power we was adjusting the sound via...
In car audio always make sure that you are feeding your amplifier with the voltage that it requires, usually 12v to 14v (some amplifiers can do 12v to 18v). If you have a voltmeter, check your voltage reading if its reading 12v above, if it reads 11.9v below & just stays there & keeps on going down then your problem is with your voltage.
The possible causes of the protect light to turn on in a amplifier is: 1. low voltage - the amplifier is not running on its required voltage / is not getting enough voltage 2. thermal protect - too much heat, usually this occurs when an amplifier is in a tight space & the voltage keeps going down this will cause heat. 3. shortage - wire's are touching each other 4. poor ground - always make sure you ground your amplifier to your vehicles chasis
Hope this helps your concern. Have a blessed weekend.
Apr 24, 2011 | Sony XMGTX1852 Car Amp
Red light flashes - will not work - could it be dust in the amp?
hi,
its not because of dust. AZUR 640A offers loudspeaker protection if the output of the amplifier goes to a high constant voltage (DC) because of some internal fault. This is a rare fault although detecting it could just save those expensive loudspeakers.
Due to the necessary sensitivity of the DC protection circuit, hard clipping of the amplifier may cause DC protection to be triggered. If this fault occurs switch the unit off, power up again and check
operation with a reduced volume level. If the DC fault occurs again contact your dealer for service.
ok
Dec 29, 2010 | Cambridge Audio Azur 640A Amplifier
Need to connect Bose 901 + JBL TL260 to HK3490 and swap for classical / rock..
For analog stereo sources, place the Active EQ in a Tape Loop and only select that loop when your'e using the 901's. If you use a digital source and activate a Tape Loop you will kill the source.
If you have a sub, WATCH OUT as the EQ WILL AFFECT its pre-out.
The best solution would be to get a separate amp for tthe 901's and, using Y-cables, share the Pre-Out-Main In with the Active EQ, which would feed the new amp. That would give you HK-controlled volume for the 901's. This eliminates any undesirable Active EQ getting back into the receiver to affect the sub or JBL's..
Nov 11, 2010 | Bose 901 VI Main / Stereo Speaker
What is the maximum amount of electrical energy that can be delivered durning a short circuit for low voltage 230v/400v
Tom, Not sure if what you're asking relates to the Maximum electrical energy (Voltage and Amps) that can occur during a short circuit through a properly protected electrical circuit (protected by a circuit breaker, etc.) or if the question is for the maximum amount you could potentially get from a short circuit on a 230V or 400V electrical line to ground OR another electrical line/supply.
IF the circuit is a 230V-AC circuit protected by a double circuit breaker, you could see the entire Voltage (230V-AC) and up to the full Ampere rating of the circuit breaker, (20, 30, 40, 50, etc Amps) during a short circuit condition to Ground.
IF the circuit is a 400V-AC circuit protected by a double circuit breaker, you, again, could get the entire Voltage (400V-AC) and up to the full Ampere rating of the circuit breaker protecting the circuit, when shorted to Ground.
Now, IF the short condition involves one of the above line voltages AND you are having it shorted against another Voltage/Amp circuit, the total potential Voltage and Amps you could experience, would basically be the sum of the two Voltages (and Amps) of the two (2) circuits being put into a short condition. So you would/could see a potential short circuit of whatever voltage is available, depending on what and where the short circuit is occurring.
By way of example, I've seen a 240V-AC 60 Amp circuit shorted to another 240V-AC 60 Amp circuit and the resultant "short condition caused enough damage, due to the voltage and Amps provided, to melt and weld the machinery's electrical connections, rendering the unit a total loss, not to mention that the person that caused the short to occur, received a face-full of melted copper metal bits all over their face and body. Thankfully they were wearing safety glasses, and their eyesight was saved, albeit, with some temporary blindness caused by the extremely bright flash and explosion.
The examples provided assume a properly working/functioning circuit breaker protection. However, if the circuit breakers are faulty, it is possible to recieve much higher vlotages and Amps, since there would be no protective circuit breaker that could trip the power off. In that case, the Main circuit breaker becomes the fail-safe protective device and that could have a much higher Amp rating, thus the maximum Voltage/Amps would be limited by the Main electrical ciruit breaker and electrical supply available at the location where the short circuit occurs.
This could be MUCH higher Voltage and extremely high Amps, depending on the situation and equipment involved.
If you have more information about the particular situation, please post a follow-up comment and I'll provide you with some more info.
I hope you find this Very Helpful and best regards!
Nov 17, 2009 | Square D Qob120 1pole 20amp 120v Circuit...
SONY STR-DE125 READS PROTECTED
protection is designed to protect the output transistors from, shorted speaker wires, shorted speakers, too low speaker impediance,make sure the amp is well ventilated.
turn the amp off for 1 to 2 hours to allow thermal reset if this fails most likley some internal damage has occured and the unit will need to be serviced
Sep 02, 2009 | Sony STR-DE135 Receiver
I have a relatively new (less than 3 months old) Harmon Kardon Receiver HK3490. It turns on but immediately turns off. You can hear a clicking sound like a breaker is disengaging. The problem started...
It is a relay clicking. You will need to obtain a schematic to troubleshoot this but they are available online. The protection circuits have been degraded from the short circuit but it is still alive and the discrete components are easy to replace. I used to use Sam's Fotofax but googling your HK model will get you alot of results. Harmon Kardon is a great brand and definitely worth fixing. ~Steve Medley
Nov 08, 2008 | Audio Players & Recorders
Car amp
The most common reason for this is shorted output transistors. To confirm that the problem is in the amplifier, disconnect all speaker wires and the RCA cables. If the amp still goes into protection, check the DC voltage across the B+ and ground terminals. It should not drop below 11 volts. Also check the remote voltage.
If the amp continues to go into protect with no external connections (other than B+, remote and ground) and the voltage remaiins above 11v, the amp is defective.
Nov 05, 2007 | Car Audio & Video
Harman Multimedia Harman Kardon HK 3490 Stereo Receiver Logo
2,601 people viewed this question
Top Harman Multimedia Audio Players & Recorders Experts
Steve
berggei
Are you a Harman Multimedia Audio Player and Recorder Expert? Answer questions, earn points and help others
