Question about Nokia E52 Smartphone
My Nokia E52 won't charge. When plugging in my charger, I either get a message "not charging" or it will charge for a few seconds and then stop.
  • 943 Answers
This problem can be traced to only a few causes. Listed below are the causes and possible solutions to this problem.
1. It is most likely that your battery may not be having proper contact with the terminal that does the main work for charging it. The three terminals that can be seen perform different tasks and as such, when that which is responsible for drawing power from the battery to operate the phone is in good contact, the phone might work normally but refuse to charge when that which is responsible for charging the battery is not properly in place. The easiest way to solve this problem is to turn off your phone and remove the battery. Try to clean the battery and all of the phone's terminals without using any liquid and then re-insert the battery.
2. Your phone may be having a faulty charging port and as a result cannot perform the complete task of charging the battery. In this case, the only thing that can be done is to try to dust the charging port and try to charge again. If this actually happens to be the exact problem, you might have to take the phone to a repairer so as to open up the phone and do a proper scan through on the phone.
3. lastly and most unlikely, the battery may have been damaged and needs replacement. This also depends on how long the battery has been in use. If it has been in use for more than 3 years, it is advised you replace the battery. Also, you can try connecting the phone to another power source to see if that helps too.
Hope this solution was helpful?
Posted on May 24, 2011
Hp pavilion dv6 2117ax will not power up
Since you already got a new charger, then the problem could be the power jack of the laptop and/or the connections inside the laptop.
Try to plug the power adapter slowly and try to wiggle it. It you feel that the power jack is wiggling, then the problem is a loose power jack that is why it won't charge. And you need to have a tech tighten that up for you.
Replacement HP Pavilion DV6 AC Adapter 65Watt 18.5V 3.5A Option
Oct 28, 2012 | Computers & Internet
My Nokia E73 won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 15, 2012 | Nokia E73 Mode Cell Phone
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
My Nokia e52 won`t start
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 16, 2012 | Nokia E52 Smartphone
Phone won't charge
First Option:
Second Option:
Jul 28, 2012 | Pantech Pursuit Cell Phone
Hiii , How are you today ? I have phone model is Nokia N86 ,My problem is after charger my battery full , maximum after 3 hours i receive message from my phone ,The message is Power saving mode...
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
May 18, 2011 | Cell Phones
My nokia E52 does not charge. At times it shows "charging" then after afew minutes, it shows "unplug charger to save.." And does not charge any further. This started when I did a...
the possible problem are : i would be your battery is on defect or the phone itself...to determine if the battery is the problem, try to change your battery.
Apr 27, 2011 | Nokia E52 Smartphone
Nokia E52 it's not charging! everytime I plug it in, instead of the "charging screen", it says "not charging", and then "unplug charger to save power" or something along...
This often happens when your battery is not having perfect contact with the terminals and as a result, it prevents the power from your power outlet ot easily flow into the battery and charge it.
The easiest way toi tackle this problem is to follow the following instructions.
1.switch off your phone and remove the battery,
2.Use a dry lintless cloth to clean the battery terminals and the points of the battery that comes in contact with the terminals on the phone.
3.replace all parts and try again.
if this doesn't solve your problem, then your battery could be completely dead and needs replacement but contact a technician first.
hopw this was useful? Please dont hesitate to comment for more information.
Jan 13, 2011 | Nokia E52 Smartphone
Can not turn E53 on. will not charge, even with the charger plugged in.
First Option:
Second Option:
sir, rate my answers too.
Dec 31, 2010 | Nokia E52 Smartphone
I have 10 day old Nokia e52, will not charge, battery charged message comes up after 10 sec's ,
The best thing to do is go back to your dealer.
Check a new battery ,ifnot try a different charger ifnot ask for a different phone!
Dec 27, 2009 | Nokia E52 Smartphone
Nokia E52 Smartphone Logo
1,198 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
