I have a whirlpool washer. Model GVXW9959KQ2. When I push start on this machine, it jumps fill and goes into wash mode. The motor runs for about 2 seconds and stops. The unit will not do anything after that.
  • 4,323 Answers
Hi
As it fills and starts the wash cycle however, will stop after 2 seconds so that issue is with the motor that is bad and should be replaced. Everything else seems to be working fine as the washer fills and its not making any other noises. Hope this helps...please post back for further assistance.
Daniel
Posted on May 24, 2011
Estate by whirlpool model SM8280867. Filled, then stopped. What's wrong?
Charla, By what you have stated, it sounds like a lid switch failure. I recommend checking the screws for the lid hinge first.The lid has to be closed for the motor to run in the washer. If the lid switch is faulty, it will act as if the lid is open. A quick check you can do is to run a cycle with the lid switch jumped. If the washer operates, the lid switch needs to be replaced.
To jump the lid switch you need to unplug the washer and open the console.Once you have the console open, locate the connector for the lid switch. Place an insulated jumper between the gray and white wires. Not the green it is a ground and will cause a short. After inserting the jumper make sure it will not touch anything metal, plug the washer in. Then start the washer in a cycle, and let it go. If the washer completes the cycle, you need to replace the lid switch. Remove the jumper and order the part. The jumper is only of the test do not continue to operate after test.
Whirlpool Appliance Parts
Whirlpool Appliance Parts Whirlpool Appliance Parts from Easy Appliance...
http://www.repairclinic.com/Shop-For-Parts/a11b5/Whirlpool-Washing-Machine-Parts
Mar 05, 2016 | Whirlpool Washing Machines
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Model SM8280867. Why does it fill, then spin without washing?
1.try to unplug your unit then wait for 5 minutes
2.plug back your unit
3.program back your unit and start
Sep 05, 2015 | Whirlpool Washing Machines
Washer does not fill; goes right to wash mode
The pressure transducer is defective it as built into the water temp switch and must be replaced.
Jul 18, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
Does not go into wash mode but jumps to rinse and drain
Perhaps you already know how to do this; but if not, check out this video and learn to run a diagnostic test for error codes:
http://www.youtube.com/watch?v=yoCTzbl4FPs
Let me know.
Jan 11, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer start to run water the it just stop
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Feb 20, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool thin twin stacked,won't agitate or spin
whirlpool washers have a drive coupling in between the motor and the transmission to replace this remove the top and disconnect the lid switch set it aside remove the front panel then remove the 2 clips that hold the pump on then push it out of the way then remove the 2 screws that hold the motor clamps on and then remove the upper and lower motor clamps remove the motor then replace the three piece "motor coupling" one piece goes on the motor the other three pronged plastic piece goes on the transmission and the rubber isolator goes between them and now just put every thing back together
Mar 31, 2010 | Whirlpool LTE5243D Top Load Stacked...
Washer fills and empties,but agitator does not move in centre of machine? Washer goes through timer cycle, I suspect drive belt is broken?
If it will not spin either, but the motor does run, the motor coupler has failed. It is also possible the transmission has a problem, but the motor coupler is more than likely the problem. This model does not use a belt, it uses the coupler instead.
Jan 06, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine Whirlpool Lsn1000pq1
My washer is doing the same thing. I put it up on blocks so I could see where it was leaking from. On mine it was leaking from the pump which a big white piece of plastic in front of the motor. The pump has two hoses connected to it the **** the water out of the tub and pump it out the drain hose. Disconnect the two hose clamps, remove the hoses (use force). There are two spring clips on top and one bottom. I laid mine on it's side to remove them. There two slots one top, one bottom for you to use when prying the clips off. Place screwdriver under clip and between grove and push/pull until they come off. Carry pump to the sink, fill with water and see if it leaks from somewhere, should be obvious.
Jun 01, 2008 | Whirlpool LSN1000LW Top Load Washer
Doesnt wash properly
Check the inlet screens on both sides of the pipes. (Plug off the wall first) Open your inlet full before wash. Check outlet filter to clean out, check to see if any debris in pump. Is this machine second hand? If so you can download a manual.......
Nov 30, 2007 | Whirlpool LHW0050PQ Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
