Question about Hobart H600 Stand Mixer
Hello, How do you repair the "stub" that holds the arm attachments on the shaft of the mixer. It just slides throught the hole in the shaft and will not stay locked inside to hold the attachments. Thanks!
  • 10,319 Answers
The housing must be removed to replace the pressure retaining spring
this website may have information for the part you need
http://www.webstaurantstore.com/search/hobart%20parts.html?parts=Y
Posted on May 25, 2011
How do I install the shredder?
You need to access the accessory attachment point, it's behind the silver KitchenAid logo on the front of the mixer. You'll need to unscrew a set screw (black knob at the very front of the mixer head), newer mixers have a hinged cover, on older mixers, it just pulls out. Unscrew the set screw a bit and fold up or remove the cover.
Now you will see a hole with a hollow square shaft inside, this is where the various optional items attach to the mixer.
Specifically for the shredder, you will need to attach a slicing drum to the drive shaft provided with the shredder, insert it through the drum, and raise the little bar in the rear of the slicer assembly.
Insert the whole assembly into the front of the mixer so that the square drive shaft shaft fits into the square hollow in the mixer, then lower the little bar to lock into place.
Dec 31, 2015 | KitchenAid kitchen aid"" classic stand"
I can't get the dough attachment off my Kitchenaid stand mixer. I have tried oil, filling up the bowl with soapy water and letting it stand overnight, pouring teapot after teapot of boiling water ove
Hi Georgette
You need to encourage movement between the beater and the silver shaft it locks on to. There is nothing that you can unscrew to make it easier. Get a can of CRC and try & get it around the silver shaft at the top of the beater plus you should be able to get a bit in that side slot where the beater engages with that driving pin. Rock (twist) the beater side to side and slowly the grip will loosen and you will be able to encourage it off. Once you have it off you will need to clean out the CRC and polish up that silver shaft. Next is the more difficult part, you need to polish up that hole in the beater. What you are trying to do is remove the build up of flour in the hole so that it is pretty much shiny in there again without being significantly bigger than it was originally. I use a rat tail (round) file to do this job, you are just removing the darker build up in there. When done a good wash and dry and it will be like new again. Keep the hole clean of flour and it may not happen again.
Nov 30, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Kithchen Aid mixer K45SS reassemble after greasing. Followed all the web site instruction. The last reassemble step is the problem. When sliding the lower housing back on so as to put the pin in to the...
This is not an unusual happening. The pin has, over time, distorted the hole in the shaft so that is a little lip at each end of the hole. You can probably feel this if you run a finger lightly over the hole.
If the distortion is not too big, putting a thin screwdriver of rod into the hole when the planetary is in place may enable you to pry the shaft into position so that the pin can be put in place.
In the case where this cannot be done, the "sides" of the hole need to be smoothed with a medium to fine file (just at the immediate area of the hole).
Although it does not cover this situation, the Service Manual can be found at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Aug 25, 2017 | KitchenAid K45SS Classic Stand Mixer,...
I seem to have lost the instruction manual for my mixer. I would like to use the immersion blender, but I can't figure out how to attach it to the mixer body. The shaft on the blender is too short to...
Hi
The blender does not attach to any of the two holes for the whisks.
You need to push back the sliding cover in the center, bottom part between and behind where the whiskers attach. This will uncover a third attachment possibility, where you insert the blender and twist it a quarter turn into place.
Dec 13, 2010 | Braun M880 MultiMix Hand Mixer
Mixer has come off of stand
It will go back in if you back off the screw that was supposed to lock it in place. Look at the mixer part of the unit and make sure that the pin slides thru the hole. If not then turn the screw ccw a turn of so. Now make sure the pin slides easily thru the two holes in the stand part of the mixer.
Now carefully line up the top and bottom halves - look thru the hole in the stand until you can see the mixer's hole line up, then slide/tap the pin into the hole
Now turn the mixer on its side and look for the screw in the mixer casting. Turn it clockwise until tight and the pin will not come out again . . . . for a longer time hopefully . ..
Mar 22, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
I am having the same problem
There should be a pin in the hole. Above it, a washer and a spring.
Jul 22, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Need to replace cord on vintage Sunbeam Mixmaster Junior
For mixmaster junior, but should be relevent to many old sunbeams:
That's not the power cord going to the speed switch. You don't need to get those screws off.
To replace the cord:
Cut the old power cord near where it enters the blender.
remove the two front screws, pull off front housing.
remove 1/4" nuts found in recesses of exposed front plate.
pull speed handle out far enough to get a screwdriver under exposed front plate, and pry gently. It'll come off as it's a friction fit.
cooling fan blade is now visible, you need to remove it.
pry up gently on the teeth attaching it to the motor shaft.
Work your way around the 4 sets of teeth, it'll come off. Don't lose the two washers.
unscrew the electrical contacts.
take off the speednuts holding the brush assembly in place.
gently pull up on the brush assembly with a needle nose, until it comes out.
now remove the screws holding the motor coils in place. They're the same ones the speednuts attached to, and have hex heads you can get at with a needlenose.
once those are out, pull on the motor coils gentle, and wiggle them out of the housing.
You'll see the stub of the old power cord at the back of it.
Get a round replacement wire of the right diameter, thread it through the cord hole in the blender, and connect it up to the coils.
-I had to drill the power cord hole 1/16" larger than it was to get a modern cord to fit through it.
On the stub of the old cord, you'll see a metal ring which serves to anchor the cord in blender body. remove it (screwdriver + needlenose and pry), and attach to new cord at the righ position.
Put everything back together, being careful not to bust the carbon brushes.
Congrats, you now have a functional blender with a cord that won't try to electrocute you.
Mar 10, 2009 | Sunbeam Food Mixers
HOBART H600 Leaks oil.
There's an o-ring that goes around the attachment shaft,if you get a flashlight and look into the hole you will see a screw (left handed threads),remove screw and pull out shaft.Put the o-ring on and install the shaft and screw.
Feb 24, 2009 | Hobart H600 Stand Mixer
The attachments move up on the shaft
There is a retaining clip part number 9703680 illus no 25 on pg 5 of this part diagram http://www.goodmans.net/images/dmg/ka_diagrams/KP26M1X.pdf that part slip down the shaft on my mixer. I use a pair retain clip pliers to put back in place in the grove on the shaft and was back in business. if the clip is not on the shaft then you need to get a new one.
Jan 15, 2009 | KitchenAid KP2671 Professional 6 Series...
Hobart H600 Stand Mixer Logo
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
