Question about Quartet gbc 4260X Shredder
4260X My shredder has a BAG FULL lite on when I try and shredder the paper. BUT THE BAG IS EMPTY. Can you help
Check the switch (thin shiney metal strip on the side) is in correct position with full flap bar. A schematic drawing at GBC web site can help to locate these parts.
Posted on Jan 22, 2010
The bin full light is illuminated and it beeps. We have changed the bag so that it is empty and the sound and light are still on. Help please.
Paper shredders are messy. Fine paper dust covers everything, get a can of compressed air and clean under the shredding wheels. Looking up from the bottom check for any sensors that might be plugged.
Feb 26, 2016 | Dahle 41214 Shredder
Shredder keeps stopping and the bag is not full
there are three switches on most shredders that can cause them to stop.
1) a jam
2) door ajar
3) bag full
If you can rule out a jam, and the door ajar light goes on when the door is open and off when its closed, and the shredder has not been undergoing very heavy use (they will overheat and shut off, then be fine in 15 min or so)
then its a safe bet to say that it has to do with the switch that tells the shredder that the bag is full (when you take out the bag you can see a metal flap hanging down at the back of the top opening)
the way that the shreddings fall can often trip the swtich that tells the shredder that the bag is full, shake the bag a bit so the paper resettles that often fixes it.
Nov 08, 2011 | Fellowes Office Equipment & Supplies
I can't get the door open do empty the shredding
You have probably got the bin so full it is stuck/jammed full of paper and you now can't remove it...this is a "consumer" model machine and to keep cost low they do not provide a "bag-full" light on the panel...you should regularly empty the bin so that the shredded paper does not totally jam the bin and in extreme cases then get caught back up into the cutting machanism and blow the pcb inside the machine...check your "users" instructions to remove the bin.
Aug 23, 2010 | Royal PX1000MX Shredder
How do you empty the drawer
You have probably got the bin so full it is stuck/jammed full of paper and you now can't remove it...this is a "consumer" model machine and to keep cost low they do not provide a "bag-full" light on the panel...you should regularly empty the bin so that the shredded paper does not totally jam the bin and in extreme cases then get caught back up into the cutting machanism and blow the pcb inside the machine...check your "users" instructions to remove the bin. Work the bin out a little at a time to get the paper out.
Aug 13, 2010 | Royal PX1000MX Shredder
How do I remove the wastebasket?
You have probably got the bin so full it is stuck/jammed full of paper and you now can't remove it...this is a "consumer" model machine and to keep cost low they do not provide a "bag-full" light on the panel...you should regularly empty the bin so that the shredded paper does not totally jam the bin and in extreme cases then get caught back up into the cutting machanism and blow the pcb inside the machine...check your "users" instructions to remove the bin. Try working the bin out a little at a time and trying to "fish" the paper out.
Jul 27, 2010 | Royal PX1000MX Shredder
How do I empty a Royal PX1000MX?
Jun 30, 2010 | Royal Office Equipment & Supplies
Paper getting stuck once shredded
As a test try shredding into a small box or even the cabinet itself with the bag holder and bag removed. Just to see if these are causing the problem.
The bag Full switch is activated by an arm which is pushed up by the pressure of the shredded paper in the bag as it fills.
When a sheet of paper is shredded, after the trail end of the paper goes past the "eyes" the machine should still continue to run on for a few seconds to drive the shredded paper out.
May 13, 2010 | Elcoman Kobra 300 SS4 Shredder
Paper shredder jammed
Yes....this is a consumer model....NO BIN/BAG FULL INDICATOR....to keep costs down, you will just have to try to get the bin out a little at a time and slowly reach-in and "fish out the shredded paper...once you have enough out the bin will come out...hopefully the backed up paper has not jammed the machine and blown the PCB inside.....if it has give Royal a call at 1-800-524-0799 for parts assistance.
May 01, 2010 | Royal 150MX Cross-Cut Shredder
Powershred 380-c
Possible door switch or the bag full plate under the machine jamed ot switch bad. Also All shredders need the wheels oiled with shredder oil now and then...
Jun 16, 2008 | Fellowes Powershred 420 Shredder
GBC Quartet Shredder - Service manual
try this customer service number for help 800-541-0094. I believe that Acco is the parent company for GBC.
May 09, 2007 | Quartet gbc 3270M Shredder
Quartet gbc 4260X Shredder Logo
195 people viewed this question
Top Quartet gbc Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
