Question about Toshiba CF36H40 TV
I need the microprocessors. How can I get them
    Problem Solver:
  • 10 Answers
The best way to obtain the processors would be an online auction site, and then to purchase a non working unit. Another option would be to contact the company directly and see if they can sell any.
Posted on May 25, 2011
Powers up but only cd function and volume function works manually
I worked in a Sony warranty center for years...these units had a manufacturing problem that would cause many problems to arise...the grounds inside the unit would not make proper connection and cause all sorts of problems...this sounds like it may be the problem, of course there may be other causes too...simply put, if you know how to solder, then you can try to fix the unit yourself...you need to find the grounding screws that ground the circuits inside, then you will need some pieces of wire to "bond" all of the grounding points together. If that does not solve the problem, then the problem may be either in the switching IC or possibly the microprocessor...If the microprocessor is bad then I wouldn't even consider fixing as the cost of a microprocessor is veery high
Dec 19, 2010 | Sony STR-DE345 Receiver
Need the specs for HP DV7 Laptop motherboard #486542-001. Most interested in what AMD Turion X2 cpu's this motherboard supports
Microprocessor 2.26 GHz Intel Core 2 Duo Processor P8400
Microprocessor Cache3 MB L2 Cache
Memory 4096 MB
Memory Max8192MB
Hard Drive 320 GB (5400 rpm)
Take care.
Jun 01, 2010 | Computers & Internet
I want to try to Instal a second AMD Microprocessor
sorry not posible theres only one slot on the motherboard for the chip.
apart from that theres a heat issue and power supply and .....
if you manage to do the upgarde there will be no space to allow proper cooling,
two chips will definately need cooling .
New body might be required to accomodate all the extra parts too,
Cheers Misterdj
Apr 09, 2010 | AMD Sempron 3000+, 1.6 Ghz (SDA3000AIO2BA)...
Display Panel Microprocessor No.
is a programed microprocessor (microcontroler) , only the jvc has correct version.
Jan 17, 2010 | JVC THD-50 System
Define microprocessor
microprocessor, integrated circuit containing the arithmetic, logic, and control circuitry required to interpret and execute instructions from a computer program computer program, a series of instructions that a computer can interpret and execute; programs are also called software to distinguish them from hardware, the physical equipment used in data processing .
..... Click the link for more information.
. When combined with other integrated circuits integrated circuit (IC), electronic circuit built on a semiconductor substrate, usually one of single-crystal silicon. The circuit, often called a chip, is packaged in a hermetically sealed case or a nonhermetic plastic capsule, with leads extending from it for
that provide storage for data and programs, often on a single semiconductor semiconductor, solid material whose electrical conductivity at room temperature is between that of a conductor and that of an insulator (see conduction ; insulation ).
base to form a chip, the microprocessor becomes the heart of a small computer computer, device capable of performing a series of arithmetic or logical operations. A computer is distinguished from a calculating machine, such as an electronic calculator , by being able to store a computer program (so that it can repeat its operations and make
, or microcomputer. Microprocessors are classified by the semiconductor technology of their design (TTL, transistor-transistor logic; CMOS, complementary-metal-oxide semiconductor; or ECL, emitter-coupled logic), by the width of the data format (4-bit, 8-bit, 16-bit, 32-bit, or 64-bit) they process; and by their instruction set (CISC, complex-instruction-set computer, or RISC, reduced-instruction-set computer; see RISC processor RISC processor [Reduced Instruction Set Computer], computer arithmetic-logic unit that uses a minimal instruction set, emphasizing the instructions used most often and optimizing them for the fastest possible execution.
). TTL technology is most commonly used, while CMOS is favored for portable computers and other battery-powered devices because of its low power consumption. ECL is used where the need for its greater speed offsets the fact that it consumes the most power. Four-bit devices, while inexpensive, are good only for simple control applications; in general, the wider the data format, the faster and more expensive the device. CISC processors, which have 70 to several hundred instructions, are easier to program than RISC processors, but are slower and more expensive. Developed during the 1970s, the microprocessor became most visible as the central processor of the personal computer personal computer (PC), small but powerful computer primarily used in an office or home without the need to be connected to a larger computer. PCs evolved after the development of the microprocessor made possible the hobby-computer movement of the late 1970s, when
. Microprocessors also play supporting roles within larger computers as smart controllers for graphics displays, storage devices, and high-speed printers. However, the vast majority of microprocessors are used to control everything from consumer appliances to smart weapons. The microprocessor has made possible the inexpensive hand-held electronic calculator calculator or calculating machine, device for performing numerical computations; it may be mechanical, electromechanical, or electronic. The electronic computer is also a calculator but performs other functions as well.
, the digital wristwatch, and the electronic game electronic game, device or computer program that provides entertainment by challenging a person's eye-hand coordination or mental abilities. Made possible by the development of the microprocessor , electronic games are marketed in various formats, such as hand-held
. Microprocessors are used to control consumer electronic devices, such as the programmable microwave oven and videocassette recorder camcorder combines a video camera and VCR in a single handheld machine.
The first commercially successful VCR, which used a Betamax format, was introduced in 1975. A competitive format, VHS (Video Home System), was introduced in the same year and became the dominant system.
; to regulate gasoline consumption and antilock brakes in automobiles; to monitor alarm systems; and to operate automatic tracking and targeting systems in aircraft, tanks, and missiles and to control radar arrays that track and identify aircraft, among other defense
Mar 30, 2009 | Computers & Internet
Denon 1508
This should resolve your propblem... taken from the Denon USA FAQ...
You’ll rarely need to "initialize the microprocessor" under normal operating conditions. In a few cases, the microprocessor will temporarily freeze or "lock up" just as your home computer does. When this happens, just follow the guidelines in the back of your owner’s manual to "unlock" the microprocessor and restore normal operation. (This is directly comparable to rebooting your computer. It’s an electronic wake up call to your unit’s temporarily paralyzed microprocessor "brain.")
If you experience some unusual behavior -- a channel that’s suddenly silent, "forgotten" level adjustments, some eccentricities in your unit etc. -- you may need to reset the microprocessor. Of course, you should check all connections carefully first. But if you’ve eliminated these items as a source of potential problems, you may need to go through the initialization process.)
Initialization is easy. Please refer to your owners manual for instruction on reseting the microprocessor as each unit may have its own individual protocal for reset.
What causes these problems? Several things can -- a jolt of static electricity, a current surge through an antenna input, etc. But don’t worry, the microprocessor is well shielded from any permanent effects.
When you do initialize the microprocessor, remember that this erases any setup instructions you may have previously programmed into the unit. However, the on-screen menu will quickly get you through a new setup. And, if you write down your preferred settings BEFORE you reset your unit’s microprocessor, you’ll have an even easier job!
If in the event you do intialize microprocessor reset please refer to your owners manual for instructions on setup..
Sep 20, 2008 | Denon AVR-1508 Receiver
Smarset clockradio
Sorry it took so long to answer your question about the Clock/Radio. This look like a problem with the Clock/Radio's Microprocessor. You will need to reset the microprocessor by removing all power sources to the microprocessor. This means removing the Clock/Radio from the A/C power source and removing the internal battery (CR2430). After removing all the power sources from the Clock/Radio, let the Clock/Radio set for a period of about 3 hours. This will let the power completely drain from the microprocessor and reset it to the factory settings. You can then reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio should have reset and the functions returned to normal operations. If The Clock/Radio functions have not returned to normal. You will need to let the Clock/Radio's microprocessor drain off the power again and put a new internal battery (CR2430). Then test the Clock/Radio's functions again. The Clock/Radio functions should have returned to normal operation. If you are still having problems getting the Clock/Radio to return to normal operation. You can call the Emerson customer support at this telephone number 1-800-909-1240- Call them between the hours of 8am to 4:30pm central time USA. Give them the make and model number of your Clock/Radio and ask them for their assistance. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
Apr 29, 2008 | Emerson Smartset Clock Radio
Alarm 1 won't go off when set to AM
Nov 19, 2007 | Emerson Smartset Clock Radio
Mitsubishi VS50605
Can I ask you why you think the microprocessors bad? I have never in all of my years of repairing Mitsubishi TV sets ever had a bad microprocessor. Did a tech tell you this? Let me know what the symptoms are.
Jun 12, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
