Easy touch tv wont turn on and shows no power light tryed the fuse in plug and nothing
5 Suggested Answers
  • 41 Answers
SOURCE: Vizio 42 in L42HDTV10A no power no lights no nothing
Yeah if you don't have any power at all, no lights or anything its the power supply.
Posted on Oct 08, 2008
SOURCE: POLAROID TLA 04641C AFTER VGA PLUG TV WON'T WORK
i am having the same problem.. did u ever got it fixed?
Posted on Aug 07, 2010
paul4265
  • 592 Answers
SOURCE: TV will not turn on. Red flashing light, nothing
Hi.
This sounds like you are experiencing the same thing as thousands of other tv owners right now.
Your tv is suffering from " capacitor flu".
The capacitors that control voltage regulation, convergence, or the ones on the main board have failed.
This is not due to anything that you have done, it is because about 15 years ago, some companies chose to put profit ahead of quality.
There were about 20 electronic component manufacturers in the mid-1990's that mass manufactured capacitors, and they were done so with the wrong formula for capacitance gel. They used a formula which was later determined to be harmful to the capacitors, but instead of pulling those off of the market, they ignored the massive failures and left then out there on the market anyways.
All together, the companies made a combined 50,000,000 capacitors that were junk, and instead of lasting the 25-30 year design like they were supposed to, some of them are only lasting a few months to a few years, at best.
Now, that isn't to say that this means that your tv should be tossed in the trash, but if you take it to get it repaired at places like BestBuy, Fry's, or Staple's...you will want to get an estimate of repair costs before actually having it done.
The reason for this is because to get the proper capacitors put in your tv is a time consuming, and expensive repair.
You may find that the cost of repair is more expensive than the cost of replacing the tv, or you may find that it reasonably priced to get the repair.
That is why I recommend getting an estimate first.
This way, you will know ahead of time which way is the most economically feasible venture for you.
I hope this helps you understand what is going on with your tv, and that it gives you some insight as to how to remedy the situation.
Good luck to you, and have a good day.
Posted on May 31, 2011
You can look at the various module failure symptoms and service / replacement options for the L42HDTV10A here:
http://www.coppelltvrepair.com/search?Q=l42hdtv10a&As=false&Pf=&Pt=&Sid=false&btnsearch=Search
Posted on Apr 25, 2013
My Veon 32'' tv wont turn on
Usually fuse near cord interior in case. Teardown. Careful..VOLTAGE danger even unplugged. Touch nothing else.
Apr 17, 2016 | Televison & Video
Power wontcome on
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD PLASMA TV FIX ... 1. soft reset - is just turning tv off & back on 2. hard reset - unplug power to tv for 1 minute then connect power to your Flat-Screen
TV Will Not Turn On - Troubleshooting Help for Finding ...
? 2:32
https://www.youtube.com/watch?v=kEDVc-BXf0I
May 1, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV that Will Not Turn On - Troubleshooting Tips for finding ... I get a center led light when its plugged in showing power. ... I have a dynex 42 in and it dose not have stand by but turning on on the light but nothing happens ....Repairing Flat Screen TV - Blacked out with blinking red light ...
i have a 32" rca rlded3258a tv. The red light in the bottom ...
Dec 09, 2015 | Televison & Video
My polaroid lcd tv, wont turn on, its 16 months old, any ideas?
Try plugging it into another outlet - one which you are certain is working. If that doesn't work, you might have a bad fuse inside your TV. If that isn't it, the power supply board may have failed.
May 25, 2014 | Polaroid Televison & Video
Olaroid FLM-3732 wont turn on
Have someone inspect the power supply board for bad or puffed up caps--getting any parts or boards for this brand is not real easy.
Aug 30, 2012 | Polaroid Televison & Video
Mitsubishi wd 57731 wont power up
There is a lamp cover on the back that only requires a few screws to remove. the lamp is behine there, you will need a standard screwdriver to remove the lamp and inspect it. If indeed the lamp is bad you will see it shattered and/or burned at the tip. The timer light flashing for 30 seconds is normal as the TV is going thorugh a boot up process. One word of advise, don't touch the glass part of the lamp pnly the case.
Nov 26, 2007 | Mitsubishi WD-57731 57" Projection HDTV
TV Won'T Turn On
A fuse is not your problem. this TV has a safty feture that when it senses a problem it cuts the power to prevent any fouther damage, when you un plug it the TV resets and it will turn on agian. I have the same TV Check the CRT light guns there are 3 of them. If one goes bad it will cause your problem.
Sep 22, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Power surge I think
If you do not get any clicking or sound when trying to turn on the TV set, most likely the main fuse went out. This is almost always due to something else blowing out along or making the fuse to blow out. DO NOT SIMPLY REPLCE THE BLOWN FUSE! If there is other shorts inside the set, and you replace the blown fuse, you can cause more damage to the TV set. The best way to test this set if the fuse is blown would be to hook up a 100 to 150 watt light bulb across the blown fuse, and if there is a short in the TV set the light bulb will glow bright and stay bright. If the bulb lights up and goes dim maybe just maybe you got luck so replace the fuse and see what happens. If the light bulkb stays bright, there is a short in the set somewhere and if you do not have a service manual and a good multimeter and a knowledge of how the TV power supply works, you really should call in a pro to assist you in the repair of this TV. there is just too much High Voltage inside these TV sets to be experieenting around inside of it. Good Luck.
Mar 14, 2007 | Toshiba 36A43 36" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
