Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500
I have a Ariens ST622 Model# 946501... gas was leaking around the gas filter ball, so I replaced the rubber gasket, but it won't start, unless I prim it & it will start & then shut off.. any suggestions?
4 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: my chainsaw leaks at the gas cap from a hole in
I suspect your saw is a bit long of tooth. The hole is your tank vent. There is usually a one way valve that only allows to enter the tank. Perhaps it is a victim of ethanol degradation as are many rubber parts in older saws. If you can find a new cap it should remedy the problem at least for a while.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jan 08, 2011
Knucklebstr
  • 222 Answers
SOURCE: there is oil in my air filter and pooled around
Perhaps you tipped your mower over to clean underneath it? If you tip it the wrong way, yes, the oil will run up and into the carburetor, then out the carb and into the air filter. An oil leak would not cause this to happen due to gravity. If this was caused by tipping the mower, then let it set upright for a time and let everything run back to where it's suppose to go. It will take a bit to start it, but should work then. I'm hoping this is what your problem is. I hope this helps.
James
Posted on May 27, 2011
lfconrad566
  • 15 Answers
SOURCE: poulan 446t Will start, won't continue to
Have you tried adjusting the idle? On my 42cc, the adjusting screw is in the hole right above the primer bulb. Turn it clockwise to increase idle speed.
Posted on Jul 28, 2012
Oil leak from oil filter housing
Your oil filter is too tight,causing the rubber gasket to tork and not seal,I've done it on my 85 nissan 720.Everytime I do a oil change,I have to make sure I don't over tighten filter.Loosen a little bit,wipe all oil up so you will know if it's fixed.You may have to replace filter if gasket is messed up from overtightening.
Sep 19, 2012 | 1989 Ford F 250
Change oil filter
Just the filter: You need a filter wrench that fits your size oil filter. There are 3 or 4 different sizes, so buy the wrench when you buy the new filter to get the right size. Unscrew the old filter. Use the wrench just to loosen it and then you can use your hand to run it off. Have a drain pan to catch the inevitable drips and spills, and to lay the old filter in.` Use a rag and clean the block where the filter's rubber gasket mates to the block. Make sure the old filter's gasket came off with the old filter and is not still on the engine. Where the filter goes on you should see only clean shiny metal.
Before you start the new filter on, it is very important to put clean oil on the rubber gasket on the filter's base. Just dip your finger in oil and run it all around the rubber gasket-if you don't do this it will surely leak there. Now start the filter onto the threaded stud -the mounting stud for the filter-and turn it on down until the rubber gasket is touching the shiny metal base ring on the engine block. Now with only your hands, and not the fil;ter wrench, you need to turn the filter another 3/4 of a turn so it will seal tightly. If you get it half a turn and it gets tight, just squeeze a little harder=get as close to 3/4 of a turn as you can.
You are done. Pat yourself (wipe your hands clean first.). When oil is put in and car is started, check for leaks at the filter.
Good luck.
Jun 17, 2012 | 1999 Dodge Dakota
I have husqvarna 136 that won't start. If you put gas in carb it will start but won't keep running.
Replace the fuel filter in the tank, check the fuel hose up to the carb for signs of leaking, if so replace the line, between the cylinder and the carb back plate is a rubber induction tube, make sure this has no split.
Oct 14, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My mower is about 2 months old. Haven't had any issues until last night. I think I ran out of gas (maybe not, it was getting dark). I filled it up, and won't stay running. Barely starts unless it...
It sounds like there is sediment in the carb bowl. Remove the gas line from the carb and plug the line with a phillips head screwdriver. Remove the bolt in the bottom of the bowl and carefully tap on the bowl to loosen it without damaging the rubber gasket. Clean the bowl, and blow the ports in the bolt out. Raise and lower the float inside the bowl space to make sure that it is working freely. Re-assemble making sure to seat the rubber gasket properly.
If there is sediment in the bowl, you might also consider an inexpensive in-line gas filter ($6 at Lowe's, etc.).
Best regards,
--W/D--
Jul 08, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Don't have engish manual, machine won't drain
A make and model would really help here. However, I'll take a blind guess at your problem.
This is simply a problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. Your repeat of the rinse/spin cycle is giving it extra empty time and then the spin works OK.
You need to locate and clean the filter. Depending on the model (not sure which with the model you mention) there is either a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) or, you will need to access the debris trap from the back of the machine.
If there is no filter at the front, pull the machine out and you will see a roughly oval panel at the bottom of the rear of the machine. Unscrew the 3 or 4 screws and unclip. Directly below the drum, you will now see a rubber "Cup" like bulge in the black pipe, with a plastic tube connected to a plastic pipe. The cup is held in place by a large jubilee clip. Unscrew the clip, pull off the rubber boot to expose the debris trap (A conical plastic cage with a ping pong ball in it) Take out the ball and the plastic trap, clean out the debris and replace the trap and the ball (Note that the cage may have a slot in it that locates in the rubber boot, make sure it lines up, or it won't reassemble correctly). Now push the boot back onto the fitting at the bottom of the drum where it came from and tighten up the jubilee clip, making sure that it is fitted correctly (it too may have a small slot out of it that fits around a protrusion on the bottom of the housing).
Jul 06, 2011 | Washing Machines
2001 Durango acts like the gas tank is full during filling cutting off the pump. The only way to fill tank is to pump gas really slow
Chrysler and Dodge have a fuel vapor filter that allows air out of the gas tank but filters the harmful fumes. Usually the problem happens from topping off your gas after the gas pump stops due to the automatic shut off and then putting more gas in the tank (to make the bill an even $50. or to the next $5 increment, or pumping more in just because it fits). Anyway the filter gets saturated with gas, is not able to breath, and causes a vacuum in the tank. Because of this, the anti-siphon ball is not able to float around and sits at the opening of the fuel fill tube and won't allow any more gas to be put in (acts like the car is full). If you pump super duper slow like put a nickel to hold the gas pump handle, it will trickle in without a problem, but it takes forever! Solution, get the filter replaced and don't over fill the tank.
Sep 11, 2010 | 2001 Dodge Durango
My DC25 Animal is making a howling, whistling noise. Primarily when turning off (winding down to shut off)
if it started after you cleaned the filters, it is because when you smack the filter that is in the ball like they tell you to, it pushes the gasket in so air can sneak past it. take it back out and pull the rubber gasket away from the filter so there is about 1/16-1/8" away all the way around, then put it back in. it will seal it and stop.
May 13, 2010 | Dyson DC25 All Floors Bagless Upright...
I have a Homelite Super XL chain saw model 100454. Gas leaking around cap when turned on side to cut. Cork gasket look fine and surface is flat where cap in screwed on. Any help?
Just because that cork gasket "looks fine" does not mean it is working properly. Replace it with a polypropylene (oil and gas resistant rubber) gasket. That will clear up your fuel leak problem.
Dec 15, 2009 | Garden
Need parts for Ariens ST 622 string trimmer
MY ARIENS ST622 starts but then dies down quickly any ideas?
May 04, 2009 | Garden
Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500 Logo
245 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
