Question about Coleman Retro Rechargeable Battery Powered Lantern Family Size
Coleman retro 5312 lantern, same problem already reported by tessmore. after charging, still doesn't turn on. do i need to replace bulb
    Problem Solver:
I think the switch can be replaced. Here on amazon you can purchase parts: Amazon com Coleman retro parts I hope this helped. Cheers
Posted on Dec 06, 2014
HOW DO YOU CHANGE THE SWITCH ON THE COLEMAN 5312 SPIRAL BULB LANTERN. NIGHT LIGHT WORKS ;WHEN SWITCHING TO HI, BULB WILL FLICK AND INSTANTLY GO OUT. LOW DIESN'T WORK. SOME TIME RTHE LANTERN WILL LIGHT AND STAY ON. AFTER SWITICHING OFF AND ON SEVERL TIMES IT MAY REMAIN ON . BELIEVE THE PROBLEM IS THE SWITCH... FRANK
Posted on Sep 05, 2013
I am having the same issue. After charging. Night light c9mes on then switch to high bulb flickerso. But won't stay on.
Posted on Apr 28, 2016
4 Suggested Answers
joboo1
  • 257 Answers
SOURCE: how to fit a mantel to a coleman propane lantern
Hi, First remove the knurl nut on the top. Remove the top and then the glass globe. There are several types of mantels most of which tie with a string that is part of the mantel top. The newer ones have a wire clip in place of the string. Which ever type you had on before you need to remove the old pieces completely. Since the mantles burn to an ash they will disintegrate when touched but if it had the metal clip you need to remove it. Tie or clip the new mantle over the lip on the output orifice being careful with the screen underneath. Replace the glass globe and top, put the nut back on finger tight. Remember that the mantel turns into ash when it burns for the first time so keep the gas low to start it till the mantle forms properly ( in the first minute) Good Luck, this should Fixya!
Posted on Mar 16, 2009
CarlGlas
  • 283 Answers
SOURCE: Coleman rechargeable lantern: Charged overnight -
Check the battery with a volt meter to make sure you have the correct voltage. If not, replace battery. If correct voltage, bypass switch to determine if it is good or not. If not, replace. There really isn't much to go wrong on the lanterns except the bulb or battery.
Posted on Jul 21, 2010
al_kupchella
  • 843 Answers
SOURCE: In the Coleman 5312 Retro Series Lamp is it
Brentonb, In the event that you don't get a direct answer (which is likely, since this is a pretty obscure question) I suggest you troubleshoot it this way. Remove the bad battery. Use the charging device that came with the lantern and wire it temporarily to the device in place of the battery. This will supply the correct voltage, but takes the possibly shorted battery out of the circuit. If you are certain you have the polarity correct and you know that the charger works, then you have your answer. good luck.
Posted on Dec 03, 2010
I have a coleman 5317 RC series lantern that wont go into the dim mode what can I do
Hello. I've just looked at several Coleman lamps, some have krypton bulbs (mainly battery powered), some spiral fluorescent bulbs (mainly mains powered/charged). If this one is yours http://www.coleman.com/Parts/100/parts-lanterns/5317-702/remote-control-pack-away-family-size-lantern# then it appears yours has a spiral fluorescent bulb. Gas discharge bulbs commonly are fired up by an initial high voltage pulse then followed by a continuous ac medium voltage (say 80 volts or so) to give a FIXED LIGHT OUTPUT.
THIS DOES NOT ALLOW CONTROLLED DIMMING. Dimming can usually only be done on an INCANDESCENT TYPE bulb eg an older type tungsten filament bulb. These are however much less efficient.
So in summary, if you do have a fluorescent bulb, I don't know why your remote indicates you can dim it. You could try switching the bulb for an incandescent type, but this should only be attempted by qualified persons. Check over the user manual again. Good Luck.
Jun 17, 2014 | Coleman 5317-700 lantern - 8d square...
Does not switch on after fully charging night light works if charger is plugged into power point
will the main light come on when plugged in? it might just need a new bulb. if so it might be a dead battery
Mar 11, 2014 | Coleman Retro Rechargeable Battery Powered...
Charge Time for 5312 Lantern Battery?
Charge time is 18hrs. If you left it on and it was flat, imediately charge for 40hrs.
heres the manual.
http://r1.coleman.com/Manuals/5312R.pdf
Feb 12, 2014 | Coleman Retro Rechargeable Battery Powered...
Manual for coleman lantern model 5348-700
simple unscrew the top clockwise and you will see how the tubes are removed,
Nov 22, 2011 | Camping, Backpacking & Hiking
Tried to charge my Coleman Retro Lantern, the red light for charging is on but after 24hrs charging, I take the charger off and try to turn the lantern on, it wont work. How can I fix this...
I just bought a retro rechargeable sealed battery,recently. I charged it for 18 hours,the lights all worked,but I don't remember the green light comming on.i put the lantern away for 3 months or so.i decided to check the the battery light out first week of june, the light was there,then I said let me charge it up again, I never seen any green light come on showing it was fully charged. I took the battery out and checked the wires to see if there was a break. None that I could tell. After you take the battery out ,there is another section square that covers where the bulb is located,but I didn't touch that part yet. Stuck" on this one. Help"
Sep 15, 2011 | Coleman Retro Rechargeable Battery Powered...
In the Coleman 5312 Retro Series Lamp is it supposed to work off the mains charger even if the battery will not charge. Battery is confirmed dead but lamp will not work on mains nor on 12v car lead. Don't...
Dec 03, 2010 | Coleman Retro Rechargeable Battery Powered...
Coleman rechargeable lantern: Charged overnight - not working, replaced bulbs - not working. What could it be:
Jul 20, 2010 | Coleman Camping, Backpacking & Hiking
How do you relamp the GE model 17000 lantern
Visit the Coleman site to locate your particular lantern.
http://tinyurl.com/2a9j2xx
Jul 02, 2010 | Coleman Retro Rechargeable Battery Powered...
Coleman Retro Rechargeable Battery Powered Lantern Family Size Logo
4,442 people viewed this question
Top Coleman Camping, Backpacking & Hiking Experts
Jim London
Jim London
yobo007
yobo007
Ted Maxwell
Are you a Coleman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
