Question about Daewoo DWC063R Air Conditioner
No cold air coming out ,all modes seem to be working, model dwc-063r if freon is neede ,who in the08260 area will service?
  • 1 more comment
  • anthonyvaran May 24, 2011
    i hope so, will contact local repair pers.
    still can't find someone in my area who will fix daewoo products, none of your recommendations will come out.
  • 4,323 Answers
Hi
These units require service once a year; if it has not been serviced then it is recommended to get this serviced. Also the filter might be clogged causing no cold air; you can also get the Freon checked though. Please click on this link for service centers in Wildwood NJ. Hope this helps...please post back for further assistance.
Daniel
Posted on May 24, 2011
Can freon be added to a window are conditioner?
This type of unit don't need much Freon but if it known leak yes fit it and add Freon as factory spec
Aug 09, 2014 | Daewoo DWC-0820FCL Window Air Conditioner...
On my 96 yukon the air won't get cold its not
if it WAS working then gradually just seemed to not get cold it sounds like freon is low. with the compressor cycling on-off it has some freon in it. just add a small amount. i'll be honest its best to have someone with the recycler machine do this it will save you from adding too much and possibly damaging the compressor. most shops have a freon service special around 99 bucks?
Aug 11, 2012 | Cars & Trucks
Fridge not getting cold enough, freezer not cold enough ?
ck for ice in back of freezer . this wll block the air flow to the fresh food area causing it to run too warm. . if more help is needed i need your brand & model # mm
Oct 24, 2010 | Jenn-Air Refrigerators
Honda Accord LX has bad temperature control switch? I just got my A/C recharge with new freons and it is working. Before it was just blowing hot air when A/C is switch on and the A/C control knob turned to...
  1. what year model is accord?
  2. there are several doors in the air box
  3. blend door (hot cold)
  4. mode door (defrost, floor, vent)
  5. recirculation door (outside air)
  6. if the control mechanism is defective. the tech may have reached under the dash and manually opened the blend door.
  7. which control knob does not work mode or temp?
Jul 26, 2010 | 1994 Honda Accord
There is no cold air from DAEWOO Air conditioner.
this could be a multitude of things: you said it worked when installed,window unit right anything punture the coil exposed to outside, if so freon leak no freon no cool Secondly is the filter dirty these unit needs to breath to work if its dirty it wont cool. switches in the same position turn them back and forth a few times see if that helps. always look for the obvious first and work your way back from there. If this is the first time you ran it since purchase was anything punctured on install if not maybe it was a lemon take it back if possible if not charging these things are a pain, it will need taps on the high and low side this should only be accomplished by a licensed professional and could be costly. give this a try and goodluck
Jul 11, 2010 | Daewoo DWC-056CL Air Conditioner
NOT BLOWING COLD , DO NOT HAVE THE MANUAL ANYMORE
check wheather the fan is working .check the pre-filter it may be clogged.check the rated amps it drawing if the unit is working .check the blower/blade of the fan motor.
Jun 03, 2009 | Heating & Cooling
A/C just blowing air
a/c needs to be serviced, first check would to be to have gauges put on and go from there
Apr 25, 2009 | 2007 Saturn VUE Green Line
1996 cadillac deville
You need to re-fill your Freon gas, he is finished real fast...
Jul 02, 2008 | 2005 Cadillac Deville
Daewoo DWC063R Air Conditioner Logo
244 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
Craig Hill
Dan Webster
Dan Webster
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
