Question about Microsoft Xbox 360 Console
GPU & CPU IS NOT HEATING UP
Hi!
my xbox360 which i try to fix by my self , i m fail & tired to fix it.
cause red light keep flashing & GPU & CPU is not heating up . i realy tight the screws.
what 2 do , help me
    Problem Solver:
  • 5 Answers
Try using a industrial blower heatgun it work for me
Posted on Aug 16, 2008
E 74 2 red light
Xbox360 is like any electronic devise that uses the BGA packages, they fail one day. there are too many BGA packages on a xbox360 motherboard but the one that always gets hot the most is the GPU chip so it is the one that mostly fails , Any trace on a electronic motherboard has two ends , a bad connection can happen on one of those two ends and for xbox that triggers an error dose that indicate the trace that has the bad connection , if that trace is going from the GPU chip toward the CPU it will trigger a CPU error code even if the bad connection happened on the GPU end of the trace and so on. so the E74 error code is indicating a bad connection on the GPU - AS you see in the attached pictures - and the only way to really and permanently fix it is by reballing the GPU chip , any other fix you hear about like x-clamp fix or towel fix ..etc are nothing more than Mickey mouse repairs that won't last if they work at all, Reballing Xbox GPU is a very advanced procedure that can not be done at home, it requires very high end equipment , high skills and a lot of hands on, one place I would recommend for that procedure is www.ps3specialist.com 5eccc8a7-1dec-40fd-8024-57c86348aad5.jpg f5d919d6-5b21-4925-9de9-cba997f3a300.jpg 87624e84-d783-4bab-b192-b96dccccdfce.jpg 7ae7e858-1161-4b3f-8890-7814879afd8b.jpg 37cbaca6-74f0-4083-acd5-11785e9ca001.jpg 9d36228c-e604-41d9-81c9-8992e47f6261.jpg Xbox360 Reballing repair service phat consoles
Mar 05, 2014 | Microsoft Xbox 360 Console
XBOX360 FLASHING RED
To fix the flashing red lights what you will need to do is stop the heat getting to the GPU and the CPU and to do this you can use a good Xbox 360 Repair guide or of course you can send it in.
Nov 05, 2011 | Microsoft Xbox 360 Console
I bought an xbox360 and i get the RED lights flashing on it and as soon as you turn it on the lights cme on. so it does'ent work what should i do?
Nearly all of the lights are caused by overheating - you may have the 3 red lights which is caused by the GPU and the CPU overheating or 2 red lights where the console will feel hot.
Then you can get freeze ups and disc reading problems as well.
How many red lights are showing on the power button?
You can fix all of these errors from home using a good repair guide or send it in.
Apr 27, 2011 | Microsoft Xbox 360 Console
3 flashing red lights x box 360
You need to have the motherboard fixed, do to this you need to take the xbox360 apart then reflow the board.
there is a great 6part video guide on YouTube to view for free. 6 videos from the same fellow, each video is a few mins long, and goes over everything for you.
http://www.youtube.com/user/ohiocitysales#p/u and its free unlike some eBook site.
I actually used the same method to fix over 450 Xbox360 units with no problems at all, barring a few (but i have done nearly 500 so you expect a few problems along the way), you just need a few things though like a heat gun and some thermal paste. sounds hard, but it's very easy once you start!
Hope this helps in some way.
I should also mention that that the 3 red light issue is covered by Microsoft for 3 years from the date of purchase under there extended warranty for 3red light and 1 red light E74 errors. so if your unit is under 3 years old and you have not opened it, then give them a call for free and have your unit fixed for free.
Jan 02, 2010 | Video Game Consoles & Games
When i switch my xbox360 on there is no ound or
are there any red lights on your xbox if so this could be the problem:
e74 or rrod error means that there is an hardware issue.
What you need to do is a very simple and cheap repair.
look on ebay for x clamp repair kits, these are just a few bucks and most sellers include a good guide in how to do the mod/fix.
what causes the rrod or e74 error is the X shape clamp on the underside or the mother board bending and mis-shaping causing the ball soldering on the gpu/cpu slightly melting and forming hairline cracks in the solder.
The x-clamp kit will apply more pressure to the gpu/cpu and a little trick of disconnecting the fans and turning on the xbox and allowing it to overheat will re melt the solder ball joints to fill the hairline cracks.
Depending on which chip is the issue you may also need a 2000 watt heat gun instead of using the over heating method (the gpu chip).
Replacing the heat pads on the heat sink with thermal paste which comes with the kit will keep the gpu/cpu cooler and you wont have this issue again.
Please make sure you buy the kit which comes with heat treated nylon washers as the steel spring washes fail!.
The repair takes around 1-2 hours
I hope this helps in fixing you xbox.
Nov 07, 2009 | Microsoft Xbox 360 Console
Red flashing lights ,3 flashing red lights ,when we turn it on.
this looks like a useful page to diagnose your problem:
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Oct 29, 2009 | Microsoft Xbox 360 Console
Why does my green circle turns red?
ill assume your talking about red flashing lights on the front this is how the xbox tells you what error u have depending on the number of flashing lights, basically if u have red flashing lights your xbox is stuffed
Oct 27, 2009 | Microsoft Xbox 360 Console
Green start button is flashing red
depending how many times the red ring flashes or how many re lights are on this could be the problem:
Bewarned that opening your console voids any warranty on it, i would recommend contacting microsoft to see if it is still under warrenty as this could be a free fix by them
Oct 25, 2009 | Microsoft Xbox 360 Console
Xbox360 error code
Here is how you interpret the LEDs to get the code number:
  • All four lights flashing - 0
  • One light flashing - 1
  • Two Lights flashing - 2
  • Three lights flashing - 3
0001 power supply problem
0002 Network Interface problem
0003 Power problem could be the PSU could be the GPU/CPU, somehow the console isn't getting clean power from the power supply.
0010 over heating
0011 over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsync screws are tightened securely to the board/heatsink holes.
0012 over heating
0013 over heating
0020 (Not yet known, possibly overheating)
0021 DVD Drive Time out - Can be caused by problems with a firmware flash. This is also speculated to sometime be caused by a problem with the southbridge chipset on the motherboard.
0022 GPU Error / GPU Overheating
0023 (not yet known)
0101 (not yet known)
0102 unknown error
Oct 12, 2007 | Microsoft Xbox 360 Console
Xbox 360 3 red red lights
1-800-4-MY-XBOX (1-800-469-9269) If you did not open your box an break the microsoft seal. They fix for free. If not you can replace the x-clamp on the motherboard for the GPU. You see the xbox360s motherboard warps because it runs so hot and the cheap x-clamps used to hold down the heat sinks are not strong enough to keep the board straight. When the board warps it losens the solder around the GPU causing the 3ROD. Just google the xbox360 x-clamp mod to find out how to get it done. If you fix yourself it will cost you like $3.00 for parts at Lowes!
Sep 23, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
112 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
