Question about Cuisinart CMW-100 Microwave Oven
My observation door clouds up and remains that way. How do I clean it ?
Microwave comes on in cooking mode with the door closed when plugged in. The Clear/Off button does not turn off and we have to open the door to turn off.
I have a hunch the microwave panel is going into Child lock mode and preventing you from operating the clear/off function. Not sure which is the middle switch that you replaced. I would suggest you give the panel a good wipe with a clean damp cloth to remove all grime etc. Before selecting the start/pause button press the Clear/off button for 3 secs and see if the L (lock) shows up on the display. Next press again for 3 secs to see if L goes away.
This way you have confirmed the panel is not in lock mode before you start next operation. Provide your observations in the comments section so that I can assess what the next step should be.
Aug 14, 2014 | General Electric PEM31SMSS 800 Watts...
Clouding between glass on when cooking onHigh is it OK
Yes, It's perfectly fine. It's just some water vapor getting in between the glass. Once you're done cooking You can leave the door open for a bit to allow the vapor to escape, or just ignore the non-problem
Apr 02, 2014 | Microwave Ovens
MY OVEN DOOR REMAINS LOCKED AFTER CLEANING. I GET A F1 DISPLAYED. I LEFT IT UNPLUGGED ALL NIGHT AND IT STILL SAYS THE SAME THING AND IS LOCKED. IS THERE ANYTHING I CAN DO?
I could be more specific with a model number from the range.
The F-1 code on most ranges is a bad electronic control board. The oven lock is controlled through this board.
If you replace the board you should be able to open the oven.
You may also have a blown thermal fuse behind the rear panel on the oven as a result of self-cleaning.
Self cleaning is a nice feature but is not recommended by appliance repair technicians.
Sep 04, 2011 | Maytag Microwave Ovens
Window is clouded can not see in but can from inside
Honestly, it is best left alone, Microwaves are treated to prevent radiation leakage and splitting a door would probably upset that radiation preventing shield from operating fully. If you really want the window cleaned, take it to a repairman who is can give you a certificate that the oven is safe and has no radiation leaks after completion of the job. (Microwaves can be extremely dangerous appliances)
Mar 26, 2011 | Sharp Microwave Ovens
I have a Superba wall oven/microwave. As usual, I went to clean the oven and it started normally but after a few minutes it beeped, the contro panel said F8 E0 and the oven went off. I tried a few times...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 31, 2010 | Microwave Ovens
The oven door remained locked after self- cleaning. Ran the cleaning cycle again it still stayed locked. Also tried throwing the breaker.
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 22, 2010 | Magic Chef Microwave Ovens
We have a smeg microwave and my wife slammed the door and now i doesnt work could it be the fuse?
If it's dead, it could be a fuse.
If it won't work properly, the door switch mounts or door hinges are out of alignment or broken.
The outside cover will have to be removed so the interaction can be observed between the hook-like door latches and the door switches as you open & close the door.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Aug 02, 2008 | Smeg Microwave Ovens
Constant humming sound
the most common problem with ALL microwaves is the magnatron
Dec 29, 2007 | Samsung SMH7178STD Microwave Oven
Cuisinart CMW-100 Microwave Oven Logo
Top Cuisinart Microwave Ovens Experts
William Miller
William Miller
deton8 von Splosion
Are you a Cuisinart Microwave Oven Expert? Answer questions, earn points and help others
