Question about Black & Decker 22" Electric Hedge Trimmer
My Hedge trimmer will start and run for 2 or 3 minutes, then it dies and will not start again until the next day. Any ideas what is wrong?
  • 731 Answers
Withou make and model it's tough to be accurate so I'll need to make a presumption that it's electric.
First clean the blades thoroughly then spray them liberally with a light oil like WD40
It sounds like the blades are binding and causing a thermal shutdown of the motor. Allowing it to sit over night resets the thermal circuit breaker
Posted on May 24, 2011
Why does my hedge trimmer die after a few minutes operation
This sounds like worn main bearings beginning to seize. Worn bearings generate more heat which causes the metal bearings and their races to 'swell," thus getting tighter and generating more heat until the drag of the bearing friction is greater than the power of the motor. Eventually you can't restart it until the engine has fully cooled down.
Apr 30, 2014 | Poulan Pro PP2822 28CC Hedge Trimmer
Where do I get a new ignition coil for my 323L trimmer
Are you sure its the coil.? Have you tried relesing the fuel cap and trying it again.? Could possibly the fuel tank vent, creating vaccum in the tank and starving the engine.
Jun 28, 2012 | Husqvarna 323L
Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
Sep 20, 2009 | Ryobi Factory-Reconditioned 30cc 18" Gas...
I have a model # RY39500 ryobi hedge trimmer 2 cycle engine. Starts fine and idles however when i try to run it it dies. Whats wrong with it?
Sounds like the air screws need adjusted on the carburator. If there are 2 the one with the L above needs to be turned althe way to the right but not to tight and then backed out 1/2 turn to left. The one with the H anove it do the same except back it out 1 and 1/4 turns to left. If it only has 1 screw dot he same but back out 2 complete turns. Hope this helps?
Ralph at woodworking57@hotmail.com
Sep 15, 2009 | Ryobi Factory-Reconditioned 26cc 22" Gas...
Remington Axcess hedge trimmer wont run at all.
Check your fuel lines. It is probably getting air into the system. Also check inside the gas tank to make sure the fuel pick up line is still attached.
If you need more assistance please provide an exact model number and I can better help you.
Kelly
May 10, 2009 | Remington Factory Reconditioned 17-Inch...
Craftsman Hedge Trimmer model 358.796353 that won't operate
The problem you are experiencing is the coil. I had the same problem and confronted a freind that works on small engines. I asked him if the coil could be the problem and he gave me one to try out of another trimmer he had for parts. It is running well. The problem I now have is the blade tang that moves it back and forth broke. Now I'm trying to locate one of them.
Mar 28, 2009 | Craftsman 22" Gas Hedge Trimmer
Cuts out after 10 minutes
Sounds like fuel tank vent problem , air has to get into tank
sometimes its vented by fuel cap but a lot of hedge trimmers use
a duck bill valve right thru tank or hooked to hose .
To test if this might be the problem loosen gas cap when it starts to die .
good luck
Jan 20, 2009 | Garden
Black & Decker 22" Electric Hedge Trimmer Logo
416 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
