Question about Magic Chef 9122 Gas Single Oven
Have an old MC oven seems like suddenly there is no gas coming through ? I used in a day ago
    Problem Solver:
  • 7 Answers
Check regulators, and valves, on the regulator pay close attention to it's vent, (usualy a small brass bolt with a hole in the top) many times these vents become clogged with grease and other sediment, the easy fix is to buy a new regulator, the right fix is to extract the vent system from the regulator and boil it out.
Posted on May 24, 2011
I got cannon double oven cooker. Both over work v.good bt top bit gas no coming in burner it was working alright minute ago bt no gas in burner bt gas coming in both ovens
If it has a glass top that closes when burners nit in use then there us a little button that disconnects the gas as a safety feature, this will be located at the rear of the job. Check it isn't stuck.
Jan 13, 2016 | Ovens Ovens
I have a frigidare gas stove I have changed the ingnitor bar and it still wont light, it seems if there is no gas coming in to the oven. Altough the top burners still work
Good day!!!
Your pilot light might have gone out. If this is the case then you have to re-light it. If the pilot light won't stay lit, then you might have to adjust the thermocouple or move the pilot light closer to the burner.
I hope this information will be helpful..
Thanks for using fixya..Have a nice day!!
Aug 27, 2011 | Explorer Appliances Ovens
Gas oven ignites only intermittent
I assume you are saying the oven will not light but you can see the igniter glowing....if this is the case you will still need to replace the igniter, igniters need to be drawing a certain amperage before the will open the gas safety valve. in this case your igniter is glowing unevenly orange and is old - it is not pulling enough amps to open the valve. Replace it and you should be good to go If you have any other questions please feel free to comment. Good Luck!!! Mike
Aug 18, 2009 | Ovens
Oven does not heat. Broiler and stove work. NO gas smell.
could be the oven thermostat, get a plumber/heating engineer out, but make sure you can trust him, cause he could try and say u need a new cooker when it MIGHT only be a new oven thermostat.
Feb 02, 2009 | GE Ovens
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Gas Double oven (Built in)
It is definately not possible to change a gas to an electric. There are very few options for double gas ovens as electric is far superior. IF you have to go with gas , check out the local Habitat for Humanity store. You should be able to buy a used gas oven. It probably won't have the self clean feature. You would be better off trying e bay or a local scratch and dent outlet for a nice electric convection oven. It will need a seperate 220 volt circuit probably 40 amps. This isn't as expensive as you would think. Use the installer from the dealer you purchase the oven from. They are usually a lot cheaper than a union electricial worker. The 4 sizes available for built in ovens are the old standard of 24" the newer standard of 27" and the most common and useful 30" This is the current standard but you will also still be able to get 27" There is also a custom standard of 36" which would be for the very high end lines. These are all width measurements. The height will vary with the model. Most cabinets are made to accept various heights by removing one or more drawers underneath.
Jul 15, 2008 | Equipex PZ-330 Electric Single Oven
Creda convection oven wont heat up
my ge profile double electric oven, bottome convection wont heat up
Feb 19, 2008 | Ovens
Magic Chef 9122 Gas Single Oven Logo
70 people viewed this question
Top Magic Chef Ovens Experts
Sal De
Oloyede Monsuru
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
