check out the below link which worked for most of the hp products
<a href="http://hpanswers.blogspot.com/2008/07/hp-cue-scanning-flow-component-has.html">Click here for the working solution</a>
SOURCE: 64 bit laptop not compatible with ImageClass MF 5750 to scan
I have Windows Vista Home Basic. I anm using 5750 scanner after downloading the following software MF5700_PrtDriverV300_Win_EN.exe &MF5700_PrtDriverV300_Win_EN from the Canon site. I am not an expert in knowing what are all these. But it just worked after downloading them and running.
SOURCE: canon mf4350d WONT scan out of the box
The software that comes with Canon MF4350 does not detect the absence of WIA service running. If printer is working and the correct driver is installed, the first thing to check is: 1. Check that the scanner does NOT appear under Control Panel -> Scanners and Cameras. 2. Navigate to Administrative tools -> Services (the same menu is available under My Computer -> Manage -> Services. 3. Check that service "Windows Image Acquisition (WIA)" is enabled and started. 4. If WIA service is not enabled, enable it. The scanner should appear under scanners menu (see 1.) and Canon MF4350 should work fine.
