Question about Keurig Special Edition B60 Coffee Maker
I get the message saying "prime" and the light on the bottom of water tank is blinking even if there are full tank of water
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 07, 2011
Says to prime
Lift the reservoir, then reseat it. This will clear the prime message. If it repeatedly comes back then your machine is dead. If in the year warranty, call Keurig they will ship you a replacement.
Jul 17, 2014 | Keurig Platinum B70 Coffee Maker
Why does the power light keep blinking
The blinking light is wrongfully indicating that there is not enough water in the tank. The sensor is a small magnet that is floating in a compartment at the bottom of the water tank. (The black square in the corner) You shold be able to see it. Check if it is stuck at the bottom and if it is floating in its chamber. If that is OK, the sensor inside the coffee maker that is reading the magnet might either have come faulty or dispaced (due to a shock?). That would need a disasembly of the coffee maker.
Villi
Jul 05, 2014 | Philips Senseo HD7820 Espresso Machine
Keruig coffeemaker blue water tank light starts blinking even though tank is full. Remedy????
On the side of the tank the magnet is stuck in the empty position and is causing it to give you the fill tank message...
heatman101
Aug 24, 2011 | Coffee Makers & Espresso Machines
Getting the message "prime" and blue light is
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Apr 15, 2011 | Keurig Platinum B70 Coffee Maker
Blinking blue light won't shut off even when the water is full
you need to prime the machine. if the instructions for priming don't work (as they didn't for us), then try this:
johnshami had this solution on another post, and it worked for us when the manual's instructions to "prime" the machine resulted in no water leaving the tank to enter the machine:
  1. make sure the water in the tank is stone cold -- which is a no brainer since it will not heat h2o unless it's primed.
  2. take off steamer wand cover, turn the steamer knob clockwise till pump starts.
  3. then s*ck (as you would on a straw, with your lips sealed around the end of the steamer wand) the tip of the end of the metal tip hard until pump stops
  4. may need to do it a couple of times. yes this seems crazy, but it works! you are flushing out the vapor lock in the pump.
Jul 14, 2009 | Saeco Starbucks Sirena Espresso Machine
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
Water light can't be reset
The problem is that the manual says "Press the on botton, the light will blink and priming will begin" but this is completely inaccurate. If priming is needed the machine will turn on, the "water" light will blink and nothing will happen.
What needs to be done is to turn the machine on and move the steam/hot water knob clockwise. The pump will activate and churn away and then stop. Just repeat this step until water flows to finish priming. HTH
Jan 20, 2008 | Coffee Makers & Espresso Machines
Solis Palazzo - stuck in descale mode?
Are you refilling the tank during this process? You need to let in run dry, and then the buttons flash. Then, refill the tank with clean water, and let the tank run dry again.
Dec 11, 2007 | Bosch Benvenuto B30 Espresso/Coffee Maker
Keurig Special Edition B60 Coffee Maker Logo
87 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
