Question about Dryers
My LG Tromm dryer started purring today. It is a constant noise while the dryer is running and sounds like a large cat purring.
  • Anonymous Mar 13, 2014
    After a technician came out and installed a new thermostat (?), it sounds like there is a chain turning in the dryer if it starts up. That noise comes and goes..is not constant.
  • 1,056 Answers
The guide that the drum sits on may have been damaged or worn or maybe a piece of fabric or some foreign material is lodge in between. The top cover of the dryer can be remove so you can examine it. Of course makes sure it is unplugged before doing any of that. Most of the time the drum guide is made of plastic material and wears out too. Good luck
Posted on May 24, 2011
LG Tromm electric dryer model DLE5977B is making an extremely loud humming noise.
Humming is caused when the slow start capacitor on the motor fails. Better to buy a new dryer as the motor is usually around $160. Yours is $145. I suggest you take professional advice on such a high outlay rather than risking the advice of someone who hasn't physically checked the machine. I have two pro dryers in my hotel fail, and they buzzed.
LG Dryer Model DLE5977B Parts
Feb 02, 2017 | LG Dryers
How may belts on lg tromm dryer
The start button is a momentary start button. It energizes a relay type switch to keep power on. Try holding the start button in for awhile and do not let go. If the machine keeps running, then for sure, the relay type switch is defective and needs to be replaced with a new one.
May 24, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Squeaking sounds
slipping belt drive on drum , have it checked.
Mar 22, 2014 | LG DLE1101W 7.3 cu. ft. Ultra Large...
Lg tromm DLE5977 won't start the tumble
Sounds like loose belt. If the drum spins by hand, it's almost guaranteed to be a bad belt.
Nov 27, 2013 | LG DLE5932W Electric Dryer
Tromm dryer
I don't know if your warranty is up but its covered if not. I have gone and swapped out dryers for same problem and they were LG's and It always seemed.to be those rubber wheels
May 29, 2013 | Dryers
My LG Tromm Dryer is making a horrible squeeking noise when running. I turned the Drum manually to see if I could still hear it and the faster i turned the clearer the noise. Any advice would be greatly...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 12, 2010 | LG DLE5955 Dryer
LG Tromm wm 1814cw makes loud noise
You will need to remove the back cover plate of the machine and locate the large pulley at the end of the drum. Remove the belt, then the pulley and you should see a bearing housing. Some models require a bearing and housing replacement, while others can simply be repaired with a bearing replacement alone.
Go here, and find the nearest Dealer for your part.
http://www.1stsourceparts.com/contact_us/branch_info.asp
Or you can try ordering direct from LG. If you are as handy with tools as you say, this should be a fairly easy job.
Mar 23, 2010 | LG WM1814CW Front Load Washer
Lg tromm dryer making a thumping noise when running. What could this cost me to do myself or pay specialist to fix?
heatman101
ssgf
Feb 07, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My MacBook is making a purring noise.
it can be the cooling system, but you will have to show your machne to a reparator.
Jan 13, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Dryers Logo
109 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
