I have a new battery and now a new a/c adaper and it still wont charge while laptop is up only when shut down and closed...what could be the problem?
  • Lala Alonsi
    Lala Alonsi May 24, 2011
    Did you do the charging procedures for you lap top..when you first installed in onto your laptop?
  • softpillowz Jun 24, 2011
    Thank you
  • 1,056 Answers
That means that female connector where you connect the end of the charger to the laptop is has a cracked solder joint. This will require opening the laptop and soldering it again. A very tedious and delicate job. The reason why it will only charge when it is off is because of poor connection, but when you turn on the computer, it requires more "juice" and the poor connection cant handle it anymore so it quits charging. If you decide to open your laptop be very careful and pay attention to details. Never force anything. Good Luck.
Posted on May 24, 2011
Testimonial: "Thank you for your advice i may take it in and have a expert open it up and see"
  • 89 Answers
Some of the laptops have built in safety so that they can only be charged when off. But the computer should operate when hooked to ac power.
Tip
Charging of laptop while shut down may cause the corruption of operating system....
Charging of laptop while shut down may cause the corruption of operating system. While shut down battery level will store in the memory and in the shut down mode, if you are charging, it will store in another memory location. After that if you are switch on the system, it will compare both values. If both are not equal, it may be corrupt the operating system. I had affected by this. It wont happen in all times ..Once happened for me after that for knowing purpose i did the same for three more times.. But not the same result. Better to save laptop life, please dint charge while shut down
on Dec 05, 2009 | Computers & Internet
Laptop wont boot up
Hello,You must not have anythinghooked up to the computer not a printer telephone cord for modem nothing.
You must remove the battery and the poweradapter.
You hold the power button down for two minutesto purge out the residual memory and power.
Then you plug only the power adaper in and tryto boot up.Sometimes you have to hold the power button down a little longer toget it to boot.
If it does not boot then try unplugging the cordand hold it down another two minutes.
Try again with just the battery.
If neither work you may have a bad battery aswell as power cord or possibly just a bad power cord that is not charging thebattery.
Pleaselet me know if you have any further questions or concerns.Alsoplease rate it if you like the answer it helps alot.Thanks.
Apr 19, 2012 | Toshiba Computers & Internet
I brought anew battery and new charger for my
We offer all kinds of laptop batteries. such as apple battery ,Asus battery
and so on.
May 14, 2010 | Acer Aspire 3680 Laptop
I keep the ac adaper in but the charger doesnt
you can see the problem if the battery in not charging or not loading some current. you can do this by unplugging the adapter on the outlet. if the unit turned off then the battery is defective. replace it. now if the problem is the adapter, you can see by removing the battery then plug the adapter to the unit and in the outlet. if the unit didn't turn on, the the adapter is defective. replace it.
Apr 10, 2010 | Acer Aspire 6930-6771 Laptop
Problems
Hi, i think the battery has completely run down, i suggest you get another battery and ensure you don't allow the new battery to completely run down before yo charge.
As`soon as it shows low battery, you try charge or shut down to save and give your battery long life span.
I wish best of luck
Jan 06, 2010 | ASUS Eee PC 900 Notebook
Power issues on HP DV1000
It is possible you have two dud batteries. Recharageable batteries have a limited life, they have a finite number of charge and discharge cycles.
With the battery removed and only the power supply connected and the laptop powered up, when you touch the connector on the laptop and the laptop does not shut down then the laptop connector is OK.
If you can verify your new battery is OK the the fault could be the power supply adapter, if may not produce enought current to run and charge the battery. Try charging the battery overnight by turning off the laptop and leaving on the mains t charge. Borrow a mains adapter and test it on your computer.
You can also check the BIOS setting for power management, ie. hibernate, low power shut down etc.
Dec 03, 2008 | HP Pavilion dv1000 Notebook
Lens wont shut completely
hello, as you said lens cover does not shut it means camera is in working mode so naturally it drains the batteries. Actually the problem is in the lens assy. so go to samsung shop. good luck...
Jul 27, 2006 | Samsung Digimax S500 Digital Camera
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
