Epson r360 will not reconize ink cartridges - Office Equipment & Supplies
  • 1 more comment
  • dougwhite Oct 29, 2008
    error message reads:
    Ink cartridges cannot be recognesed. Make sure ink cartridges are correctly installed.
  • Anonymous Jan 08, 2009
    Got exactly the same problem
  • tudwich Mar 30, 2009
    The problem is that my R360 now refuses to accept "any" ink carts
    even originals. I have tried a reset tool for waste pads etc.
    this is a different problem.
    Problem Solver:
  • 5 Answers
R360 Inkpad/page counter Resetter
Call me and ask
entangled@bigstring.com
Posted on Nov 15, 2010
Epson Artisan 1430 Inkjet Printer ink cartridges not reconized
If it is not reading one particular cartridge please try the following as it has worked for us 90% of the time.
  1. Remove all ink cartridges
  2. use a pencil eraser on the chip of the unreadable cartridge.
  3. install the cartridge you just used eraser on.
  4. if printer accepts cartridge, turn off printer.
  5. turn on printer and install remaining inks
This should solve the unreadable problem.
This is fairly common problem, usually effecting compatible units.
Jan 27, 2015 | Epson Office Equipment & Supplies
Epson workforce 520 won't recognise ink cartidges
When replacing ink on the Epson Workforce 520, Ensure the cartridges have the correct/same number of gold contacts. Ive seen them with 7 and 9 gold square contacts and they were otherwise identical, and the ones with 9 contacts threw an "cartridge not recognized" error on the printer's dispay.
Feb 24, 2012 | Epson Workforce 520 Printer
Does not reconize non epson ink cartridge. I remove and reinstalled and it printed but now its back to not reconize cartridge.
You did not say if you were using "New-Epson Ink Cartridges", or actually using "Non-Epson Ink Cartridges" [Generic or Third-Party ink cartridges] in your printer. I'm assuming that you are probably using Non-Epson Ink Cartridges, because those are what normally cause that problem, with a printer not recognizing an installed ink cartridge. Unfortunatly, there is no way to make your Epson Printer use or accept that Non-Epson Ink Cartridge, if it cannot actually recognize it. Its even possible that some Generic or Third-Party brands, may not always be recognized by the newer models of Epson Printers, because of the inexpensive [cheap] and or incompatable Electrical Chips that are mounted on the actual ink cartridge. Sometimes you will even get Error Messages up on your Monitors screen, telling you that you are actually using a Non-Epson Ink Cartridge, or that your printer cannot recognize the cartridge that you installed. Sometimes the Ink Level Indicator, on your Status Monitor, will not show an actual ink level, but may indicate a cartridge error or problem instead. Not all Generic or Third-Party ink & ink cartridges are made the same and none of them actually contain the right formulation of ink, for the Epson Printers [formula is patented by Epson Company]. Some are probably close and seem to be better than others, but some simply can clog-up or even damage the Printhead Assemblies on Epson Printers, or simply won't be accepted at all. Epson Ink Jet Printers are one of the few printers on the market that seem to have so many problems with non-manufactors inks, especially the newer models made in the last couple of years. Its because the Epson Printers use a completely different printhead inking system than most other brands of printers. Most, if not all of the other manufactors, use thermal or bubble jetprint heads and because the other brands use a totally different system, they don't seem to have as many problems using refilled inks or non-manufactor's ink cartridges. Printer manufacters do not make available their ink formulation and in most cases, the formulation is patented. Any difference in the ink formulation can actually cause clogging in the small printhead nozzles or damage other critical components. One individual printhead nozzle is so tiny, that it will not accept a human hair, so you can see why they can get clogged so easily, or even why the nozzles can be so easily damaged...Even if you were actually using a New-Epson Ink Cartridge, its always possible that you got a bad cartridge. At this point, the only thing I can suggest is that you try a different New-Epson Ink Cartridge, or at the very least, a different brand of Non-Epson Ink Cartridges and see if that helps...Good Luck!
Jun 09, 2010 | Epson CX8400 All-In-One InkJet Printer
My epson stylus photo R360 printer has suddenly decided just to print in green and red.I've checked cartridges,cleaned nozzle heads,done all the usual things.Not getting any error messages.
Did you use Epson Genuine Cartridges?
Epson Requires Genuine Epson Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 21, 2010 | Epson Office Equipment & Supplies
Epson R360 service required
Reset waste ink counter. Use R360 adjusment. Find at indoreset.blogspot.com. Or contact me.
Jun 21, 2009 | Epson Stylus Photo R300 InkJet Printer
Ny epsom r360 reads ink pads saturated
don't replace the ink pads install a external waste ink tank instead, then reset the printer using reset program . . search on eBay for epson waste ink tank it incudes the reset program.
Jun 07, 2009 | Epson Stylus Photo R320 InkJet Printer
Epson R320 printer will not recognize any of the ink cartridges
I tried two things of which one solved the problem. I am not sure which. Secondly, I have an R260 printer which is a less featured member of the printer family uses Claria inks like R360 and R380. I called Epson and they simply sent me replacement cartridges for the two black ink cartridges with which I had a problem. My printer did not recognize these new cartridges either. I noticed that both the ones I bought and the replacement ones have a slot hole near the green chip on the cartridge. The empty cartridge did not have this slot. They just had some circular depressions. So, I put a piece of masking tape over the slot and tried again but still no luck. However, when I removed the cartridge, this time a small piece popped out. This piece connects to pins on both sides. So, it is obviously an interface between the cartridge and the printer. I pressed this piece back in, replaced the cartridge with the tape on it back it and, voila, it works. Most likely this interface piece was loose and simply pressing on the cartridge didn't get it in far enough or who knows. You maybe able to take thiis piece out and replace it or merely push down on it with a pen but first, flash a light on it first to see if it is not sitting awkwardly.
Dec 18, 2008 | Epson Stylus Photo R320 InkJet Printer
EPSON R360 ERROR MESSAGE.
i will kill you understood do not ask again mothers abuse
Jun 03, 2008 | Epson Stylus Photo R300 InkJet Printer
EPSON 360
download a ink pad reset utility at epson.com/ipr or there are some other 3rd party s/w for ink pad reset
Feb 19, 2008 | Epson RX620 All-In-One InkJet Photo...
169 people viewed this question
jasbo
jasbo
