Question about Logitech X-540 Computer Speakers
My left speaker just out of the random was cutting in and out and now it wont work i have moved around the wires it worked for a little now no sound at all
  • Logitech Master
  • 27,725 Answers
Try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Posted on May 24, 2011
My left speaker has stopped working and gives no sound most of the time. But if i move the wire a little at the V part, sometimes the speaker works perfectly. Is there an easy way to fix this? I dont have...
This confirms that the wire is open on the inside and so the only job out for you to to have a close SURGERY to be done to rectify .
You must dissect the wire to see the inside layers, now as you tug the free state of the wire will confirm the position of the wire break. Cut and **** the wire sleeve to see the strands where it has come off, use a good soldering iron to solder after cleaning of the wires. Insulate the joints properly with tight taping and bind them together so that the fault will not recur.
Mar 19, 2011 | Sennheiser CX 300 Consumer Headphones
Front-Right Speaker Not Working
I would have a look inside, it might be a bad soldering joint that got disturbed in the move. When you get inside follow the wires from the Front-Right terminal.
Apr 05, 2010 | Sherwood RVD-8090R Receiver
Left speakers sometimes cut out and leave just a high treble soun
please check the input connecetor could be the losse conact with the wire some times it happens with this type of sound try to play the system and move the connector if the sound trun go replace the input cor
Nov 07, 2009 | Audio Players & Recorders
Speakers cut out randomly
The only thing i can think of is the amount of power surging into the speakers is too great and they are cutting of to avoid blowing out. I have a similar issue with my surround sound if i turn it up too loud.
Jun 25, 2009 | Logitech Pure-Fi Elite High Performance...
Headphone jack must be moved around to get right speaker working
You will find that sound comes from the right side speaker only when it is bent at a certain point. By trial and error you can roughly locate the point. Then you can cut the wire at that point, cut 1 inch each from both ends, strip the cables, and connect the conductors. What has happened is, due to unusual bending, the conductors to the right-side speaker has damaged (broken). After roughly locating the place and removing 1 additional inch each, you will remove the wire section with the broken terminal. Now you can strip the wires and make the connections again. If you are not good at stripping and soldering wires, better to to take it to an electrician. (You need to take only the headphone pin and parts attached to it). This repair won't cost much. Good luck!
Jun 25, 2009 | Logitech Z-2300 Computer Speakers
Jensen vm9511ts cuts out
It sounds like the phone mute is going on and off, but I'm just guessing because I don't know your grounds, speaker wire hookup configuration, etc. Look at the screen when the music cuts off and goes back on and if you see a little red phone with the cross through speaker symbol (aka mute) it's probably the phone mute feature which is supposed to be hooked up to bluetooth and mute the stereo when you get a call. Like I said I'm just guessing, but if so there's a brown wire in the back that needs to be hooked up.
Jun 19, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
One Speaker Stopped Working
I too had the left speaker malfunctioning. Luckily, i had the curage to open up the speaker and look into the problem. Before that i checked to see if the input inlet to the amp worked by plugging in the right speaker in the left input inlet. I was able to hear the speaker. If you get that response, then the left speaker is the problem. So i went ahead and opened up the speaker. Do this by taking off the fabric cover. There are those little hose plugs you need to take off with a philips head, just wiggle them out. Unscrew the 4 screws. Use a blow dryer around the edges/sides of the face of the speaker to loosen the hot glue holding the cover together. Once the speaker is warm, try prying off the cover. You can maybe use a flat head screw driver to do so but with gentleness or else you'll scratch up the speaker. So once you have that done, look at the terminal(wires that are soddered to the speaker, to check if connected to speaker. if they are not connected, then you would have to soddered them. If everything is intact, then try moving the little plastic piece connected to the speaker, opposite end of that is the possittive and negative wires connected to the cone. I scrapted/moved around the wires being careful not to puncture the cone with the screw driver to check to see if they were making contact with the terminal. I then connected the plug into the amp and fortunately i could hear the speaker once again. I hope this made sense and worked for you. I was glad this worked cuz i truly love the sound of Z-2300 system for the THX certified sound.Sure glad i didn't have to buy another set.
May 20, 2008 | Logitech Z-2300 2.1 Computer Speaker...
Altec Lansing ada885
Same issue showed up for me today very randomly...
HD comes on and off for no reason and sound cuts in and out. This fix worked for me:
1.Disconnect the left speaker from the sub woofer.
2.Take the 4 screws out on the bottom of the left speaker. (They are under the rubber matting you can just poke holes through it)
3. Remove the bottom plastic assembly from the speaker
4. Cut the 4 wires to the headset chip. Careful not to cut any others to the speakers themselves!
5. Unscrew and remove headset plug chip
6. Reassemble and plug left speaker back into sub woofer.
No more HD issues =)
Apr 04, 2008 | Altec Lansing ADA 885 Computer Speakers
Logitech x-230 - left speaker not working when used with 360
my speakers plug into my comp. by that little cord with the green end piece. and i have to figit around with it just to get one speaker to work, can i fix it or do i have to buy the whole set again?
Mar 10, 2008 | Logitech X-230 Computer Speakers
Logitech X-540 Computer Speakers Logo
43 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
