Question about IBM ThinkPad Z60T Notebook
Z60t laptop won't work with new battery
My laptop wasn't working with its original (2 year old) battery, so I bought a new one. Charged to 100%. Battery info says it's in good condition. When I unplug the AC adaptor, the laptop shuts off.
What's wrong?
ank you for any help!
Deb
  • debK123 Aug 20, 2008
    Thanks for the advice, though I have no idea what "flash the bios" means! : ) Nor do I have an ohm meter.
    What seems to have worked was a tip I found elsewhere to find a small piece of hard plastic above the battery contacts (in the laptop) and poke it in a little bit. I have no idea WHY that worked, but it did.
    Good luck to anyone else with this problem.
    Genius:
  • 2,028 Answers
This could be a couple of things. Start by checking the power supply with an ohm meter for the proper output. 1 volt over or under will need a supply replacement. The system could have glitched by being ran with a bad battery. Go to IBM's support site, download the bios or any updated bios version, and flash the bios. If this doesn't correct the problem, then it's going to be a failure with the power management system on the motherboard. You can take it in for a diagnostics to find the exact problem area, but most likely they will tell you motherboard replacement. Motherboard replacement is generally the only option with a failed power management system
Posted on Aug 20, 2008
I bought a new battery for laptop and it still wont charge
Dell uses proprietary equipment. IF the laptop wont work when plugged in and it is the original Dell charger, you need to check the charger, if the charger wont work then the battery wont charge. Note that it might be the connection on the board inside the laptop especially if the cord got pulled on while plugged into the laptop.
Oct 05, 2015 | Dell Computers & Internet
My HP G72 laptop wont power on, even with a charged battery from another hp, The light wont come on when its plugged in.
Your motherboard has gone bad. The best thing to do is buy a new laptop. You can find a replacement motherboard online but after the cost of the part, shipping, and the pain of removing 100 screws, it just isn't worth it.
Oct 21, 2012 | HEWLETT-PACKARD G72250US Laptop
Lap top is not charging
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 16, 2012 | HP Computers & Internet
R530 switchesoff
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the battery dropsoff to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Mar 12, 2012 | Samsung R530 Notebook
Laptop lasts for less than an hour after charged
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 04, 2011 | Computers & Internet
My laptop will not work on the battery and i need to keep it plugged in although the battery say 100% charged, why
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
May 24, 2011 | HP Computers & Internet
My laptop wont charge.when its running low at 10% i plug in my battery adapter it says its plugged in but not charging. I can only use it when my adapter is plugged in and i've left my computer sit shut...
May 02, 2011 | Computers & Internet
My aunt recently bought a secondhand scooter shoprider us pat no 4798255 without a users manual and the scooter will not charge please could you help?
Kathryn Was the scooter working when she bought it? If the batteries were fully charged and now it won't charge then I would suspect the charger. If the scooter wasn't charged when she got it and won't charge then I would replace the batteries Hope this helps
Apr 25, 2011 | Health & Beauty
I bought a replacement hp battery for my HP Pavillion zv5000 a year ago. It was working fine for about 6-8 months. Then, it seemed to stopped storing energy even when the charging light stopped and...
Feb 08, 2011 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Battery doesn't stay charged
The problem is with the battery. All Lithium batteries last for around 1000 charges or so. Since the laptop is 2-years old the battery needs to be replaced.
I Hope this solves your problem. Kindly Accept my solution.
Regards, Arjun
Apr 01, 2009 | HP Compaq Presario C306US Notebook
Computers & Internet Logo
145 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
