Question about Curtis Televison & Video
My Curtis LED 1337A has no picture or sound. The Troubleshootingguide in the instruction manual refers to an improperly connected antenna as the possible problem. But I cannot find an antenna at all. PLEASE FIX!
  • Curtis Master
  • 19,396 Answers
Hi.
The antenna is hidden behind a panel at the back. Watching from the back it is at the right hand side, in position 1. The antenna Coaxial connector is indicated as RF:
Note: If there is no picture, in the meaning that the display is showing screen with backlight , or static, then the problem is antenna. If the screen is instead completely dark, like when TV is off, then the TV is faulty.
Regards.
Ginko
Posted on May 24, 2011
Programming a regular antenna to my curtis mathes cm27002s tv
If that is the big, old, thick picture tube style television (and I think it is) you cannot use it to get over the air (antenna ) reception with regular antennas any longer. Broadcast (antenna) television is now digital and older television sets don't decode it any longer. The good news is you can buy a converter on ebay etc. Hook the antenna to that and then connect the converter to the television.
Feb 07, 2017 | Curtis Televison & Video
How do I link up my LG LED t.v. with an LG remote?
NO you need to read the instructions again , and possibly a third time
Jan 16, 2016 | LG Televison & Video
Is a curtis mathes CM19033S TV, digital capable (with digital antenna) or only analog?
To use this TV with a digital signal you need a digital to analog converter. Here is a link for a converter and one for the TV user manual.
Hope this helps.
Bob
Samsung CM19033 User Manual
Zinwell ZAT 970A Digital to Analog TV Converter Box for Antenna Use
Jan 06, 2015 | Curtis Televison & Video
What causes a snowypicture
Low input signal strength, due to poor antenna connection; defective tuner, improper orientation of the antenna; etc; might cause a snowy picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
If the transmitter is so far away, it too can be the cause, as the signal falls at the antenna to be low. If this is the case, connecting a signal booster; between the TV set and the antenna will give better result.
Jul 30, 2014 | Sceptre Televison & Video
Why do antennas become out of order
Poor connections between the antenna and the wire that connects it to the TV is the 99% reason. The other 1% is improper direction when aiming the antenna.
Jul 16, 2014 | LG LN530B 32LN530B 32IN LED LIT 720P 60HZ...
Dark tv picture
It will be best to contact either the authorized service center for Curtis, or any experienced service technician. Sounds like a back-light inverter fault. Gopakumar Gopalan Google
Apr 18, 2014 | Curtis 19" Class LED 720p 60Hz HDTV, 1.56"...
Antenna shuts tv off when plugged in
their might be a problem with the tv tuner, what kind of antenna have you been hooked up an areal antenna?.
Sep 03, 2012 | Curtis 24" Class 1080P Led Hdtv/Dvd Player
Where is the antenna on the curtis led 1930A flat screen tvs
Check this link and download the user manual. It have all details.
Aug 18, 2012 | Curtis Led1930a-b 19-inch 720p Flat Panel...
I just bought an LCD 1933A TV. I don't have cable so I connected an indoor antenna to it as instructed ( Radio Shack indoor amplified HDTV antenna 15-254). I turned the TV on and no matter what I did...
Few things,
  1. You will have to go into your menu settings and be sure to select "Air" instead of Cable for your antenna connection
  2. Then run auto scan channel setup to find all available channels in your area
  3. Once completed be sure you are on Input Source TV you should be able to select Channel up/down on the remote to select your channel to view
If you ever see No Signal you are probably on an AV input and not on your antenna input.
The full PDF manual can be found here:
http://www.curtisint.com/html/custservice/manuals/CUR_LCD1933A_EN.PDF
I hope this helps
Magoo
Mar 11, 2011 | Curtis Televison & Video
Televison & Video Logo
118 people viewed this question
Top Curtis Televison & Video Experts
Martin Murray
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
