Question about Kitchen Ranges
I have an EBAC D-850 dehumidifier that I removed the plastic casing from in order to clear a blockage. Now the casing won't slide back down all the way.
  • 63 Answers
When you removed the casing, it most likely had a hose attached to it to a drain.
Check to see if the hose is laying in the way of the casing.
If this is not it, then there must be another abstruction laying in the way.
Disconnect the dehumidifier from the electrical outlet, before you go
inside to take a look. It has to be something that was there to let you know
that it was full of water or empty.
Posted on May 24, 2011
Can i get user instructions for ebac Z850E
This site might be able to help you. For the ebac 2850E manual. I could not find a "Z"850E
Dehumidifier Instruction Manuals User Guides
Nov 16, 2016 | Ebac Dehumidifiers
Where can i get a filter for an Ebac 660 Dehumidifier
perhaps thru EBAC or where you bought it .
May 15, 2016 | Ebac Dehumidifiers
We need a ebac 200e sircite board how much is it
Depending on what supplier you buy from you can expect anywhere from 20.00-60.00.I would recommend that you try e-bay.Sorry I can't be more help. Thank you
Jul 28, 2011 | Ebac HD880 Dehumidifier
MY FRIDGE IS LEAKING WATER FROM THE BACK. EVERYTHING ELSE IS STILL WORKING
I'm presuming that this is a self defrosting fridge. When it defrosts, the water runs down the back of the fridge inside and collects in a gully, just above the vegetable drawers (If you have them), it runs through a hole in the centre of the gully, down a pipe to a plate which is positioned above the compressor at the back. The compressor gets warm and the water evaporates.
The hole in the gully is probably blocked with debris or mould, as a result, the water overflows onto and into the drawers. MOST fridges have a dip stick like device in the hole, which you can use to jiggle up and down and clear any blockage. If you don't have such a dipstick, a soft wire or bit of plastic tie will do to clear the pipe. Worst case, you may have to pull the fridge away from the wall and check at the back. The compressor, plate and drain hose (about the thickness of a pencil and usually clear plastic) should be clearly visible. Sometimes, the hose gets dislodged so it doesn't drip onto the plate, sometimes the blockage will be at the end of the hose that runs out onto the plate, rather than inside the fridge. You can try blowing into the hose, which should be free and clear to blow through, or pushing a soft flexible wire down the entire length of the pipe to clear any blockages in places you can't see.
Jul 08, 2011 | Westinghouse Refrigerators
I cannot get the plastic shell back on the unit after removing to clear blockage in water drain/pan. Repeatedly hangs up, will not slide down last 1.5 to 2" to line up screw holes. Please advise...
  • Make sure the drain pan is in all the way.
  • The plastic housing gives many people trouble when reassembling. It has to be put on just so. Make sure you are clearing everything when sliding it back on.
  • This housing has to be fiddled with when reassembling a bit. It will go back on.
Regards, Tony
May 24, 2011 | Ebac AD850 Dehumidifier
My ebac 2000 is making a noise and not collecting water
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 23, 2011 | Ebac Dehumidifiers
Ebac xl Dehumidifier not collecting water
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Oct 11, 2009 | Ebac CS60 Dehumidifier Dehumidifier
Documentation for Ebac 2400E required, please.
Is it possible to download -PDF the Instruction Manual for the Ebac dehumidifier model 2400
May 19, 2009 | Ebac Dehumidifiers
Should I buy a new Ebac dehumidifier?
Unfortunately, Ebac has discontinued their HD line at the moment. The only other bucket style dehumidifier that they currently manufacuter is the CD35 dehumidifier.
Jan 31, 2009 | Ebac HD880 Dehumidifier
User instruction
Here is the link for the Owner's Manual off the Ebac website:
http://www.ebacusa.com/technical/Manuals/HD.pdf
Jun 30, 2008 | Ebac HD880 Dehumidifier
Kitchen Ranges Logo
47 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
