Question about HP Compaq Presario V2000 Notebook
COMPAQ V2000 BATTERY NOT CHARGING - HP Compaq Presario V2000 Notebook
    Problem Solver:
  • 6 Answers
Time to purchase a new battery or new charging cord. You should make sure that when you plug the cord into the computer that it goes in easily. If it seems difficult to insert it might that something got stuck in the hole.
Posted on May 24, 2011
  • 1,056 Answers
Get a meter and see if the laptop adapter is putting out 19 volts dc. Other than that it is a bad plug connection on the adapter plug or in the laptop. Examine the end of the plug to see if it is damaged or extremely worn and loose.
  • 24 Answers
Try to isolate the problem first. See whether it's a laptop issue or an adapter issue. If the adapter has a light, see if the light is coming on when you connect it. Also see if the laptop works if you remove the batteries and connect the adapter.
There could be several issues here:
1. Your adapter's light may be coming on, but it still might not be delivering power to the pin. If you have a multimeter, connect it to the terminals of the charger and see if you get a voltage reading; if not, there may be a problem with the cable running from the adapter to the laptop or the adapter itself may not be giving the right voltage.
2. The second possibility is that the adapter is OK, but the laptop's power connector is faulty. This will require a technician to remove the old connector and solder a new one into place.
3. If both the adapter and the connector are fine, then the problem is most likely with your charging circuit, which is inside the laptop. This circuit powers the laptop through the batteries, and will once again have to be inspected by a qualified technician.
Hope this helps
4 Suggested Answers
ted1430
  • 339 Answers
SOURCE: laptop compaq presario v2000 is not charging the battery
This is probably either a bad power supply brick or a bad system board. Try to borrow a power brick from somebody else to see if this fixes the problem so you can isolate it as this is a much less expensive problem to fix.
If you have a travel charger, be sure to press the button on top to put it in charge mode.
Posted on Aug 28, 2009
  • 62 Answers
SOURCE: Compaq V2000 works on ac , but wont charge battery.
Try to update bios n check it out..
Posted on Sep 02, 2009
arjoon
  • 113 Answers
SOURCE: Compaq V2000 "Press <F1> to resume, <F10> to Setup
re install the operating system.insert the recovery disk and follow the instructions.
Posted on Feb 21, 2010
Feb 20, 2010 | HP Compaq Presario V2000 Notebook
COMPAQ V2000 service manual
There is also a BIOS battery but this would not stop it working.
Feb 14, 2010 | HP Compaq Presario V2000 Notebook
Battery problem with HP Compaq Presario V2000 laptop
When batteries fail, they usually lose the cells inside them, which means that the cell is no longer able to function as a holding cell for power and therefore cannot do its job anymore, when a battery fails to hold and refuses charging it is bad and needs to be recycled. The flashing is telling you to purchase a new battery. The larger the number of cells in the battery, the longer and better it will perfrom,,RE: 6 cell, 9 cell, 12 cell.
Jan 13, 2010 | HP Compaq Presario V2000 Notebook
Laptop compaq presario v2000 is not charging the battery. It is functioning well on external power supply. The battery has been replaced with new barttery but it is not showing the charging status but...
Aug 28, 2009 | HP Compaq Presario V2000 Notebook
Compaq presario V2000 doesn't start
you might have shot out your battery because if electrical curent is goging in to the computer (te orange light is going on) but the computer wont turn on it might be a problem with your battey
please rate
May 30, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario v2000 notebook reduced battery life
you may try:
1) check the battery alarm at windows power managment, to set 5-10% alarm level.
2) discharge the battery to the empty then charge longer time, you need monitoring how long it charged (see charge lights change), need to change new one if charging time much less then before(less then 10-20 minutes)..
3) plug-in AC adapter monitoring charging current,
this step you need a current meter to make a series connection in the circuite, the battery is over life cycle if the current less then 500mA.
May 02, 2009 | Computers & Internet
Presario V2000 battery not recognized
you may need to have that battery charge for a while, until it can be seen at charge level..or simply check the connections to see that there is no junk in the connector..
Nov 21, 2008 | HP Compaq Presario V2000 Notebook
Battery not charging...but is recognized by V2000
My guess since the battery checked fine in another laptop would indeed be the charging board or charging circuit on the motherboard.
Jun 14, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
282 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
