Question about Lexmark Office Equipment & Supplies
Tengo problemas con un cartucho que ya no reconocio la impresora lexmark impact se s308 y el cartucho es 108 lexmark el cual rellene pero el chip ya no lo reconocio la impresora
3 Suggested Answers
  • 53 Answers
SOURCE: tengo una impresora lexmark Z2320 recargue los
Lexmark no es compatible con los cartuchos rellenados.
Posted on May 18, 2009
  • 304 Answers
SOURCE: tengo un problema con la
49.XXXXX ERROR To continue turn off then on
A critical firmware error has occurred.
This type of error can be caused by invalid
print commands, corrupt data, or invalid
operations.
In some instances, electrical noise in the
cable can corrupt data during transmission
to the MFP. Other causes include poorquality
parallel cables, poor connections, or
specific software programs.
Sometimes, the formatter itself is at fault,
which is usually indicated by a 79 ERROR
message.
Follow this:
1 Turn the MFP off, and then turn the MFP on.
2 Upgrade the firmware.
3 Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
4 If the message persists when using different software programs and attempting specific print jobs,disconnect all of the cables that connect the MFP to the network or a computer.
5 Turn the MFP off.
6 Remove all DIMMs and flash-memory cards. Do not remove the firmware memory card that is in slot 1.
7 Remove all of the EIO devices.
8 Turn the MFP on.
9 If the error message disappears, reinstall each DIMM, flash-memory card, and EIO device individually, making sure to turn the MFP power off and then on again as you install each device.
10 Replace the component that caused the error message.
11 If the error persists, replace the formatter.
Posted on Jul 14, 2011
Que es la t c
There is no problem if the printer is still printing . The cartridges have a special chip which is special to the printer and only the manufacturer can put a new one in. It knows how much ink is in the cartridge and will inform you when it is empty. When you refill it, however, and do not replace the chip, the printer may still print normally but will give a message that the ink cartridge is empty. Just use it until the printing is bad and refill it again.
Mar 17, 2014 | Canon PIXMA Office Equipment & Supplies
Mi impresora lexmar x5470 no reconoce el cartucho lexmark 34 negro rellenado como hago para que me lo reconozca y poder trabajar con la impresora sin ningun problema
Lexmark no recomienda el uso de cartuchos rellenados. Usted puede haber tenido los cartuchos rellenados que trabajó con su impresora Lexmark, pero los que no tienen la calidad de un cartucho de Lexmark. Los contactos de los cartuchos negro # 34 pudo haber conseguido dañadas a lo largo del proceso de recarga. Lo mejor sería comprar uno nuevo - preferiblemente un genuino. Esta es también una manera de evitar daños en la impresora.
Nota: Esta es translalated con translate.google.com.
Jul 05, 2011 | Lexmark X5470 All-In-One InkJet Printer
Tengo un multifuncional x2600 y me marca error atasco de papel, ojala me puedan ayudar...ya cambie los cartuchos ya trate de sacar una impresion y no me permite hacer nada..
Quite las hojas de papel desde el alimentador. Trate de abrir la tapa de la impresora y retire ambos cartuchos. Mientras que la cubierta está abierta, compruebe si hay obstrucciones en la ruta del carro del cartucho. Compruebe si hay conexiones sueltas. Si todo está bien en el área del cartucho, cierre la tapa. Desenchufe y vuelva a conectar la impresora a la fuente de energía para restablecerla. Cuando la impresora se enciende, vuelva a insertar un cartucho en primer lugar. Cierre la tapa y comprobar que no existen errores. Si no, abra la tapa de la impresora de nuevo y vuelva a insertar el cartucho de otros. Vuelva a colocar el cartucho lo que está causando el error que aparezca. Usted también puede tratar de insertar un cartucho de diferentes conocidos trabajando para determinar si el otro es culpable.
Nota: Esto se traduce con translate.google.com.
May 20, 2011 | Lexmark X2600 InkJet Printer
Que se puede hacer cuando la impresora se cicla al encender y solo marca inicial izando sistema Samsung SCX-6122
tengo el mismo problema amigo, oye cual fue la solucion??? se que la tengo que llevar con un especialista, pero a lo mejor es algo sencillo y pueda repararse y ahorrar unos pesos, me encantaria saber cual fue tu solucion, de ante mano te mando un abrazo, Javier.
Apr 07, 2011 | Samsung SCX-5530FN All-In-One Laser...
Tengo problemas con los frenos, se me enciende la luz indicativa del ABS, y el problema es que cuando freno, al momento en que casi se detiene el vehiculo jala hacia la derecha, como si solo frenara ese la...
evidentemente la luz se enciende por un fallo, revise que el caliper o compensador del lado derecho no este muy ajustado y tambien purgue el sistema por posibilidad de aire en el sistema
Jun 08, 2017 | 1993 Toyota Previa
Tengo un plasma sanyo 50 pulgadas modelo dp50747m lo que tiene es que: no prende y le cambie los fusibles que estban quemados pero ahora se oye que prende pero no se ve nada solamente se enciende el...
Amigo yo tengo el mismo problema con el mismo plasma..y no encuentro solucion...Tu ya pudiste arreglarala?? Ojala pudieras decirme como lo resolviste o cualquier info al respecto...gracias.
Sep 05, 2010 | Sanyo DP50747 50 in. Plasma TV
Tengo problemas con un Multifuncional HP Laserjet M1522, por alguna razon empezo marcar ERROR 5 Y NO PUDO INICIALIZARSE el SCANNER , Funciona como impresora pero no como copiadora o Scaner, , parpadea la...
59c05df4-3e41-4402-8674-16fa865682b6.jpg1e27574a-853d-43f0-83e9-639f0eb8015f.jpg6f9cb0d0-efc0-4725-b485-113c15667e78.jpg639e37f6-dbca-4b87-baf4-9919d68a26d4.jpgf319f64c-35bb-4a4d-b11b-3637a94260fd.jpgdf4c7415-80c2-478b-9083-7ef214ae9172.jpg027f0e9b-f662-4bc9-916c-d62c423d9e73.jpga1eea8bc-2311-4ede-b6b1-2b036b38dc64.jpg7ada6481-ced7-4dab-b710-09760d6b9498.jpg04f42b95-4eec-4796-8556-1ef7ab6cddbe.jpgHola amigos, tambien tengo este problema con una impresora, reinstale el firmware y no funciono, lo que note es que el motor estaba quemado, lo desarme y lo rebobine, compre el alambre me parece que fue calibre 33, aprox 25 mts, 260 vueltas con una resistencia de 10ohms por bobina. bueno despues de esto lo monte y funciono un poco mejor. pero al parecer es la tajeta logica pregunte a un proveedor de hp y su valor es de aprox 3000 pesos mx, lo que hice es hacerle un agujero al escaner.
Detalles.
viendo de frente el escaner del lado izquierdo le hice un agujero de 3mm. y le puse un cincho largo(pueden usar algun desarmador, el cincho se lo puse doble para que no se doblara, el cincho debe entrar con facilidad pero no muy olgado para que no se doble, al introducirlo no es necesario sacarlo ya que el carro lo sacar, es por eso que no debe quedar apretado). esto me permite mover el carro del escaner a lo posicion "0". posicion de partida y hubicacion de la banda indicadora(Empujarlo unos 3 cm aprox, despues solo se calibra).
La finalidad de esto es de manera manual regresar el carro, se apaga y se vuelve a encender y listo. funciona nuevamente.
Este error me aparece despues de haber utilizado el ADF, el cual el carro se mueve al lado izquierdo para poder escanear automaticamente los documentos. posteriormente no puede regresar.
Aqui pues es donde le podemos ayudar a regresar a su posicion original.
Espero que les ayude en algo.
Aug 29, 2010 | HP LaserJet M1522nf Multifunction Printer...
Problemas de transmision automatica
hola que tal, tengo un saab 9000 1988 y tengo problemas con la transmicion aveses me hace los cambios y abeses no, si abansa para atras y para adelante pero me abienta los cambios cada que quiere,,, alguin tiene idea de que pueda ser?? nesesito ayuda ya estoy desesperado...
Aug 02, 2009 | 2001 Hyundai Accent
TENGO UNA HP 4355 Y ME MARCA UN ERRO EN CART.
Para empezar, quite el enchufe de la corrente como unos diez minutos
Si sigue tenendo el problema quite los cartuchos y los vuelva a poner.
Si todavia tiene el error limpie con algodon y alcohol la superficie del contacto de metal donde se pone el cartridge.
Si sigue non funcionando el cartridge puede ser defectuoso, intente cambiarlo, posibilmente con uno original.
Sep 06, 2008 | HP Officejet 4215 All-in-One Color Photo...
LEXMARK X3550
Quite los cartuchos. y asegúrese que las pequeñas cintas protectoras han sido quitadas de los contactos. Entonces examine donde los cartuchos caben en la impresora. ¿Es limpio en allí? ¿Hay allí alguna tinta secada o gotas de la tinta en allí? Si hay, usted puede apagar y desenchufar la impresora y usar una cantidad diminuta del alcohol desinfectante en un Qtip para limpiar la tinta.
Si no sustituyen los cartuchos que se los aseguran adecuado cómodamente. Ahora continúes su computadora a - Principio> Panel de instrumentos> impresoras y faxes> chasquido DERECHO en su icono de impresora y elija preferencias> servicios. Cuando usted está en servicios abiertos y mira cada opción allí. Haga cualquier prueba o limpieza de los cartuchos a los cuales esto le pregunta. Cuando usted es terminado, apaga su impresora y reanuda su computadora. Si el problema no es ido, contestarme. Espero que mi español sea comprensible. Gracias.
Aug 19, 2008 | Lexmark X3550 All-In-One Printer
238 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
