Question about Maxi Aids Braille Remind-O-Timer
I can't get my remind o timer to vibrate when it should
My fridge started getting really loud when it cycles on, and seems to have a vibration when running
If it ismaking a steady noise, the motor that runs the defrost timer may be making noise. I f the timer motor is making a loud noise, then you should replace the timer.Vibration noises are often caused by dishes or containers vibrate on a shelf inside.
Sep 16, 2013 | Refrigerators
Tip
Eaton Home Heartbeat Reminder Sensor Description
The Reminder Sensor can be used as a "reminder alarm clock". Choosefrom one of 29 preset alert messages and a time interval and theReminder Sensor will do the rest. Click the sensor to start the timer.Then when the time is up, you'll get a reminder alert. Then simplyclick the sensor again to restart your timer.
Important Note: Use of this product requires the purchase of the HOMEheartbeat Starter Pack
Review the User Manual at FixYa
on Jan 03, 2009 | Eaton Home Heartbeat Reminder Sensor
Defrost timer starts running when freezer door is opened
The defrost timer motor is weak and the simple vibration of opening the door gets it working again...replace the defrost timer and you'll be good again.
Feb 04, 2012 | Refrigerators
HOW DO I RESET THE 'MAINTENANCE NEEDED' LIGHT?
SERVICE INTERVAL REMINDER
If equipped with a service reminder flag, the oil and oil filter service interval reminder flags will activate after every 7500 miles of operation. To reset indicators, insert ignition key into slots below indicator flags at lower right corner of instrument cluster. Push key in until reminder window changes from Red to Green.
Jul 04, 2011 | 1991 Honda Accord
Thinking of getting the TI150 3-in-1 Timer - Can it set to repeat a countdown over and over?
Review at Amazon seems to say the timer can repeat the same countdown each time button is pushed and countdown is activated.
Amazon review says:
http://www.amazon.com/General-Tools-TI150-Visually-Impaired/product-reviews/B001TOJG7Y/ref=dp_db_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
The timer is easy to set. You just set the time, then hit the big "start/stop" button and the little "H" and "M" on either side of the timer display flashes.
To clear the timer, just hit both the "h" and the "m" buttons simultaneously. (so time has to be cleared)
To stop the alarm or to turn off the timer before the alarm sounds just hit the "start/stop" button.
On the back of the timer, there are 4 different on/off switches: flashing light alarm, sound alarm, vibrating alarm, and one for hours/minutes or minutes/seconds.
When I set the timer on my desk, it moved around when the alarm went off but when I turned off the vibrating function, the timer didn't move around.
If you need to turn off both the sound and vibrating alarms and use only the flashing light alarm, the light is quite noticeable by itself if placed nearby in your line of sight (within a foot or so). This would be very handy if you're near a sleeping baby! :) But if you clip it on a breast pocket, I would use both the flashing light and vibrating alarms. The vibrating alarm does make a sound, but it's not as loud as the ringing alarm.
Dec 27, 2010 | General Tools Hardware & Accessories
My phone wont vibrate even its been activated
you need to return this phone and get a new one the vibration motor is shot
Jul 19, 2009 | Nokia 6300 Cell Phone
Reminders!
the phone has to be taken to a service center and have the either ringer replaced or it could be a software issue and then it would have to be reflash for the calendar reminder to work.
Sep 16, 2008 | T-Mobile Dash Smartphone
Motorola rockr E6
Seems like a reminder setting, I would check your missed call, or message reminder settings to see what they are set to.
If all else fails a master reset should clear this.
Jul 21, 2008 | Motorola Mobility ROKR E6 Smartphone
E6 Beeps/vibrates every 30 mins
it just reminds u about any missed calls or unread messages.
Jun 05, 2008 | Motorola Mobility ROKR E6 Smartphone
SPH-M300 continuous vibrate
I can solve this problem drop the phone on the floor, the problem is that the programming of the phone has messed up and is keeping the vibrating going so either buy new phone or keep dropping the phone till it stops vibrating
Jan 26, 2008 | Samsung SPH-M500 Cellular Phone
Maxi Aids Braille Remind-O-Timer Logo
49 people viewed this question
Top Maxi Aids Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Maxi Aids Hardware and Accessory Expert? Answer questions, earn points and help others
