Question about Garden
LI want to take the weed eater carborator out and repair it and replace it, I need instructons on how to do this. I am 80 years old.
    President:
  • 1,545 Answers
The carburetors are very temperamental and have some very small parts. Small springs are inside too. These parts are easily lost. It is a little tedious to do even for younger folks. I am not saying you can't do it, but due to the nature of working on them; I would suggest a replacement carburetor. I can also better serve you if you tell me the manufacturer and the model number for your machine. That way, I can locate a replacement carburetor and/or a rebuild kit for it. There are 2 kinds of kits. One is called a gasket and diaphragm kit and contains only a few replacement parts (but these parts enable it to run again); the other kit is a FULL rebuild kit that costs more and has many parts that you may not USE or even NEED. Please reply to this solution and I will be happy to assist you further.
Posted on May 25, 2011
Echo LT-200P Weed-eater Carborator problem
1. Carb is dirty and should be cleaned correctly
2. low speed/high speed carb screws incorrectly adjusted
3. incorrectly put together or rebuilt
Jan 21, 2013 | Garden
My refrigerator sounds like someone is running a weed eater behind it. if i turn it off and then back on it stops. this refrigerator is probably 20 plus years old. is it dying?
Your refrigerator compressor is making such noise.The compressor supplies the cool air to the freezer and then freezer it goes to the refrigerator.The vibration is transfered to the plastic boards on the refrigerator and it makes the weed eater noise type.
The coil in the compressor has been worned out.You have to replace it.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 18, 2010 | Kenmore Refrigerators
I have a weed eater trimmer that i replaced the gas lines but now when i pump the top of the carborator no gas gets to the carborator and the trimmer will not start.
REVERSE THE TWO FUEL LINES .. OTHER THINGS TO LOOK FORCHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 24, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Need to thread the cord on a poulon 031pro
Remove the side coverto get to reel Remove any broken cord. Turn reecounter clockwise till it nestops then slowly let turn back till the hole li nes up then use a c clamp to hold the reel. Feed the cord through hole about 3 to 4 inches and tie a double knot in cord. Release c clamp very slowly to take up cord. Measure old cord if possible and subtract about 1 half inch cut it and thread it through the handle. replace the side cover.
Apr 30, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Very weak spark.....how do I check the points under the fly wheel.....How do I get the fly wheel off? I just picked any weed eater product cause there was no link for my weed eater ride on mower with a...
Unless your engine is more that 25 years old (not possible for an Enduro), there are no points. The ignition is solid state, which means that a weak spark will require a new ignition module. Not the end of the world - they're cheap and easy to find.
Change the plug first!
Feb 17, 2010 | Poulan/Weed Eater No. 5000p 952711612 Pole...
I have a snapper S31SST weed eater. It is 4-5
Remove spark plug and check for fire with a spark tester. (some inline models are also available and safer since the spark plug stays in place using those types)
If no spark:
Remove covers and unplug small kill-circuit wire(s) from ignition coil...Test for spark.
If you have spark the switch needs replacing.
If you have no spark the coil needs replacing.
Hope this helps.
Sep 26, 2009 | Garden
Need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Jun 01, 2009 | Garden
Where can I find a manual for the PE550 weed eater
You can download one online at... http://www.poulanpro.com/poulanpro/indexAction.do?id=default Scroll down the right side to 'Download Manuals'...then enter your model #.. you can then download the owners manual or parts manual. Dwain
May 21, 2009 | Poulan Garden
Garden Logo
75 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
