Question about Car Audio & Video
No am radio reception. Amp good, FM good. - Car Audio & Video
    Sergeant:
  • 167 Answers
Put a small 5inches copper wire to the am antenna slot at the back then try again
Posted on May 24, 2011
Very poor radio reception
FM reception depends upon having a good antenna matched to the radio. What type of radio are you using, and what are you using for an antenna?
May 02, 2015 | Golf
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
2012 cvo streetglide, loss of clarity and amp for rear speakers
Swapping the amp will have no effect on FM reception. I'm shocked that the factory would even recommend that. It's probably just a bad tuner pack in the radio. Get it replaced
Oct 08, 2012 | Harley Davidson 426290 AM/FM Radio
Am fm reception bad
FM reception is weak
What to do
• Extend the power cord as much as possible. The FM antenna is in the power cord.
• Move the power cord to adjust the FM antenna
• If you still have problems with FM reception, you may need an external antenna.
* Call Bose®Customer Service to request one.
The external antenna on your radio is a coax (round) design It needs an adaptor and an antenna which are cheap.
Easy to make, radio shack "F" connector 90 degrees or straight, to 300 ohm wire connections. Attatch a 300 ohm flat ribbon antenna cable to those two screws and plug into radio and see how your reception is. You will need to position the antenna wires to get best reception. I have hid them in back of paintings and so on.
Cheapest solution next to putting an extension cord on radio power cord.
Jan 03, 2011 | Bose Wave Radio
Will I get good reception in a metal factory building I get spotty fm reception with my current radio
With old radios it worked to connect the antenna to some central radiator or (metallic) water pipe. Some old wire was used to connect it;
Feb 22, 2010 | Grundig S350 AM/FM/SW Radio
FM reception for Sony ICF-CD513?
The electrical cord acts as an antennae for this radio. Uncoiling the cord will give the best reception for FM. Rotating the radio (and built in ferrite bar antennae) will give the best reception for AM listening.
Jan 31, 2010 | Sony ICF-CD513 Clock Radio
Improve reception
HI there,
Well Yes you can improve the reception, please follow the below steps -
Improve FM Radio Reception -
1. If you don't have an antenna connected to your FM receiver, purchase a simple dipole antenna--a simple T-shape flexible wire-- and connect it to the FM antenna inputs on the receiver. Because FM signals are directional, you'll want to experiment with the positioning of the wire to find the best reception of the station you're trying to receive.
2. If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
3. If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
4. If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
5. Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
Improve AM Reception -
1. Gradually rotate the radio 360 degrees. Leave it in the position where it sounds best.
2. Reverse the AC plug if it isn't polarized. (If you can flip the plug over, then it's non-polarized.)
3. Plug the radio into a different AC outlet.
4. Move the radio closer to a window.
5. Experiment to learn if appliances and powered products in your home are causing interference: computer monitor, television, electric blanket, light dimmer, fluorescent light, hair dryer, air conditioner, smoke detector. If possible, turn off the offending item. Otherwise, move the radio to another room.
6. Upgrade to an external antenna if your receiver, tuner or radio has a place to connect one.
7. Buy a passive AM antenna that doesn't need to be connected to a radio or receiver.
Good Luck!!
Thanks
Dec 29, 2009 | RCA RP5430 Clock Radio
Bad reception fm radio signal
usually batteries...am takes less juice.....battery strength will affect fm signal strength
Nov 08, 2009 | GPX RDT4004SP AM/FM Radio
How good is fm tuner reception? We live approx 50 miles from transmitters and have trouble getting clear signals. Is Bose just good sound quality, or does tuner provide superior reception?
I live in Vail Az about 110-120 miles from Phoenix Az I can pick up 60% of the stations decent. The power cord acts as a fm antenna. Plus this Bose Wave CD/MP3/FM
Aug 16, 2009 | Bose Wave Radio
Bose wave ratio sucks. I paid $500 for the radio
GO TO RADIO SHACK AND GET A FM SIGNAL AMP THIS SHOULD HELP YOUR PROBLEM THEY ARE UNDER 20 BUCKS
Apr 04, 2009 | Bose Wave Radio
Car Audio & Video Logo
15 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
