Question about MSI KT4V (MS-6712) Motherboard
I need the manual for the MSI KT4V MS-6712ver::10a to plug in the power switch and the led's plugs and the hdd plugs
  • 72 Answers
Hi, I found the manual for your MSI KT4V motherboard. You can download the manual from here: Click Here. The diagram for the power switch, LED and HDD plugs are located on Page 2-18.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
Posted on May 24, 2011
How to connect power switch,led,reset switch to MSI MS 7071 Motherboard?
They connect to the JFP1 connectors on the lower right edge of the board. The power LED connects to the 2 and 4 pins, The HDD LED to the 1 and 4 pins, the reset to the 5 and 7 pins and the power switch to the 6 and 8 pins. The pins are numbered up down right to left like this.
97531
08642
Aug 03, 2014 | MSI Computers & Internet
How to & where to connect Power led + - /power sw/reset sw/HDD led
Get the user manual here: User Guide
Chapter 2 Page 17.
The plugs just fit on to little pins in the bottom corner of the board.
If you connect them and hard drive indicator light on the front of the case does not come on then you need to swap the 2 connectors around.
It's an led which has to be connected the correct way to work.
Same goes for the power led on the front of the case.
Jan 26, 2012 | MSI MS-6378 Motherboard
Ms-6368 ver:2.1 manual
Cut and paste this link...select the DOWNLOAD tab, click on MANUAL.
Choose the 2.0 version of the manual. It supports 2.X versions of the motherboard. Page 2-14 has the infomration you need.
http://www.msi.com/product/mb/MS-6368.html#/?div=Manual
nqjkujcuh79+vxr3fpuimnn5x9mjblkzhq6xzkfbgdogvrhqyfssmj1awualahyhaaagmkbxweaumua4waaqgxacqaa1dlgoaaaahlwhaaatqw4dgcawgycbwbalqooawcglghhaqbqy4djaacozcbxaadumua4aabqgxacaac1ddgoaibabhwhaeata44dakcw+f8ulsndi3vv6qaaaabjru5erkjggg==
Jan 17, 2012 | MSI Computers & Internet
I need to know where to plug in my power cables on the mother board i have 5 cables that need plugged in One is RESET SW, POWER SW, HDD LED, + P LED, and - P LED can you possibly give me a picture pointing...
Can you go to the MSI website and download the manual, looking at your motherboard usually it can be found at the bottom of the motherboard, usually the right side, also you should see small abbreviations of the connection relative to the pins they are associated to. If you need more help just ask. Thanks Rick.
Jul 28, 2011 | MSI : MS-7061-020 VIAKM400/A&V&L/SATA...
How to connect power switch on msi ms6787
At the bottom right hand corner of the mobo you'll find there is a set of pins marked JFP 1 and the power switch pins are marked clearly so are the HDD Led, reset, Power Led etc. Plug in your wires which are also marked, corresponding to the marked pins.
Sep 23, 2009 | MSI P4MAM-V SND/LAN/VIDEO (6787060)...
Pin placement for ms 6741 mb
the manual for your motherboard can be downloaded here:
http://www.msi.com/index.php?func=downloadfile&dno=3812&type=manual
On page 2-17, the pin-outs for those connectors are specified in detail. They are part of the JFP2 header:
PIN SIGNAL DESCRIPTION
1 HD_LED_P Hard disk LED pull-up
2 FP PWR/SLP MSG LED pull-up
3 HD_LED_N Hard disk active LED
4 FP PWR/SLP MSG LED pull-up
5 RST_SW_N Reset Switch low reference pull-down to GND
6 PWR_SW_P Power Switch high reference pull-up
7 RST_SW_P Reset Switch high reference pull-up
8 PWR_SW_N Power Switch low reference pull-down to GND
9 RSVD_DNU Reserved. Do not use.
-Jon
Sep 01, 2009 | MSI K8MM-ILSR (MS6741030) Motherboard
Front Panel Connector: JFP1 hookup
You can go to the link below and see the directions for that. Turn to page 2-17
http://www.premioinc.com/pc/manuals/mb/m266/m266.pdf
Sep 21, 2008 | MSI MS-6390 (-6390-010) Motherboard
MSI KT4V (MS-6712) Motherboard Logo
450 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
