Question about LG Dishwashers
Lgldf7810st will drain and fill then will not cycle no error lights. just stopped running
  • 4,323 Answers
Hi
If the dishwasher keeps on draining and filling however, will not work then the issue is with the drain hose that is either not in right position or the control board itself. If you have already tried to leave the unit unplugged for 15 minutes and also checked the door lock assembly and it is fine then it is the control board that should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on May 24, 2011
My dishwasher(samsung DW7933LRABB) wont fill, it will drain if i put water in the tub. supply is on.
You either have a bad water valve, or a bad case-brake assembly (in which case you should have an error code or blinking light on your console).
Mar 06, 2015 | Samsung Appliance DW7933LRABB 24" Tall Tub...
Stops mid cycle and clears
It could be the heating element is at fault not heating to the selected temperature 95 degrees 40, 30,and so on, if one of these fail to work then the washer will not continue
also maybe the thermostat may be at fault, causing the same error
Nov 18, 2013 | Zanussi ZWF1020 Front Load Washer
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Whirlpool WFC7500VW Washer
F4 message on the top drawer, fisher paykel. I clean the filters and arm every week or two.
There 2 possibilities with this error:
1)
  • Fault with water fill (only on machines with level-controlled fill)
  • Note: Lights blinking, pump running and controls dead indicates an over fill fault
2)--4 Flashes--Draining failure. Drain pump, control board OWI or water indicator defect
God bless you
May 14, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
LG TROMM Direct Drive WM0642HW when filled and started LE light comes on and machine stops, why. how do I reste or fix
LE is for a overload error. Do the following:
1) Unplug machine
2) Drain machine
3) Open machine and rotate barrel clockwise 4 times and counter-clockwise 4 times
4) Plug in, power on, and run regular cycle
Feb 27, 2011 | LG Washing Machines
Water will drain durring spin cycle
This is normal on some machines. Run it through a complete cycle it should fill, agitate, drain, some will drain down so low then start spinning as it is draining but should stop draining before it fills or stops. Check if water is coming in at the same time it is draining. If not it may be ok.
Dec 23, 2010 | Kenmore 98702 Stacked Washer/Dryer
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Dishwashers Logo
47 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
